N846B-05M-24-P
N846B-05M-24-P
    TRIPPLITE
    光纤电缆 MTP 至 MTP 50/125 16.4'(5.0m)
N846B-05M-24-P 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 40/100/400G Multimode 50/125 OM3 Fiber Optic Cable (24F MTP/MPO-PC F/F), LSZH, Aqua, 5 m (16.4 ft.) Highlights ● OM3-rated cable recommended for 400 Gb speeds up to 100 meters (@ 850 nm) ● Backward compatible with 10/25/40/100 Gb networks to facilitate future-proofing ● Tested for low insertion loss and attenuation loss that meets or exceeds current standards ● Aqua LSZH jacket allows fast, easy identification in a crowded switch or patch panel MODEL NUMBER: N846B-05M-24-P Package Includes N846B-05M-24-P 40/100/400G Multimode 50/125 OM3 Fiber Optic Cable, Aqua, 5 m (16.4 ft.) 40/100/400 GbE Ethernet cable extends high-density connections between network components in enterprise applications in wiring closets, telecom rooms and data centers. Features 40/100/400 GbE Cable Supports Higher Bandwidths for High-Density Data Networking The N846B-05M-24-P is a premium multimode fiber optic cable that supports 400 Gb Ethernet speeds for transmitting data and voice signals over short distances. It is designed to support higher bandwidths for high-density patching between data center MDFs and IDFs in enterprise installations. This multimode 50/125 OM3 cable is an ideal choice for 400 Gb Ethernet applications up to 100 meters (328 feet) at 850 nm. It is also backward compatible with 10 Gb, 25 Gb, 40 Gb and 100 Gb networks, so you can futureproof your current application for an eventual upgrade to 400 Gb. 100% Tested for Low Insertion Loss and Attenuation Loss The cable is tested for low insertion loss on the factory-terminated 24-fiber MTP/MPO connectors and attenuation loss that meets or exceeds current standards. The connectors’ slim boots allow easy onehanded installation and removal of the cable. Aqua-Colored Jacket Helps Avoid Misidentification That Can Cause Costly Downtime The OM3-rated cable has an aqua jacket to identify it as multimode in a crowded patch panel or switch and prevent it from becoming accidentally disconnected. The round low-smoke zero-halogen (LSZH) jacket limits the amount of toxic smoke emitted in case of combustion, making it suitable for poorly ventilated areas. Specifications OVERVIEW UPC Code 037332271693 Technology Multimode Optical Mode OM3 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Mode Type Multimode PHYSICAL Cable Jacket Color Aqua Connector Color Aqua; Black; Blue Cable Jacket Material LSZH Cable Jacket Rating OFNR Cable Outer Diameter (OD) 3.0 mm Clad Diameter (microns) 125.0 Core Diameter (microns) 50.0 Primary Coating Diameter (microns) 245.0 Number of Fibers 24 Cable Length (ft.) 16.4 Cable Length (m) 5.00 Cable Length (in.) 196.9 Minimum Bend Radius 20 mm (Dynamic); 10 mm (Static) Fiber Cable Length 5M (16.4 ft) ENVIRONMENTAL Operating Temperature Range 14° to 140°F (-10° to 60°C) Storage Temperature Range 14° to 140°F (-10° to 60°C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 5% to 85% RH, Non-Condensing COMMUNICATIONS Network Compatibility 40 Gbps; 100 Gbps; 400 Gbps Wavelength 1300nm; 850nm Attenuation @ 850NM 3.5 dB/km Attenuation @ 1300NM 1.5 dB/km Insertion Loss 0.35 dB CONNECTIONS Side A - Connector 1 24-STRAND MTP/MPO (FEMALE) Side B - Connector 1 24-STRAND MTP/MPO (FEMALE) Endface Polish PC Polarity Type A (straight through) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No Optical Port MPO/MTP STANDARDS & COMPLIANCE Product Certifications UL 1666 Product Compliance RoHS; CE (Europe); REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N846B-05M-24-P 价格&库存
很抱歉,暂时无法提供与“N846B-05M-24-P”相匹配的价格&库存,您可以联系我们找货
