1000 Eaton Boulevard
Cleveland, OH 44122
United States
400G Multimode 50/125 OM4 Plenum Fiber Optic
Cable, 16F MTP/MPO-APC to 24F MTP/MPO-UPC
(F/F), Magenta, 1 m
Highlights
OM4-rated cable recommended
for 400 Gb speeds up to 100 m
(@ 850 nm)
MTP/MPO 16- and 24-fiber ends
designed for next-gen 400G
QSFP-DD transceivers
Connectors tested for low
insertion loss and back
reflection to ensure top
performance
Plenum rated for horizontal
premise applications in air ducts
and drop ceilings
Magenta jacket allows fast, easy
identification in a crowded
switch or patch panel
MODEL NUMBER: N846D-01M-16CMG
Applications
400 GbE Ethernet cable supports high bandwidths necessary for next-generation cloud services,
hyperscale data centers and telecom carriers.
Features
Connect 400G fiber Ethernet
networks in your cloud service,
hyperscale data center or
telecom application
Connect 400G Cisco, Arista,
Juniper and other network
switches through air ducts and
drop ceilings
Package Includes
400 GbE Cable Supports Higher Bandwidths Needed for Next-Gen Data and Voice Networking
As the amount of traffic in data networks grows, so does the need for next-generation devices and fiber
cables to support much higher bandwidths in cloud services, hyperscale data centers, telecom
applications and equipment OEM companies. This multimode 50/125 OM4 cable is an ideal choice for
400G Ethernet applications up to 100 meters (at 850 nm). It has documented insertion loss and back
reflection testing on every connector and attenuation loss that meets or exceeds current standards.
16-Fiber and 24-Fiber MTP/MPO Connectors Designed for the Latest QSFP-DD Transceivers
The MPO connectors have a wide parallel optical interface for use with the latest 400G QSFP-DD
transceivers, making this cable an excellent solution for your high-density network application. The
connectors are the same size as standard SC connectors, but 12 times denser, allowing vertical stacking
in switches or patch panels where space is at a premium. Pull tabs make the cable easy to install or
remove with one hand.
Magenta Jacket Helps Avoid Misidentification That Can Cause Costly Downtime
The OM4-rated cable has a magenta jacket, which is easy to identify quickly in a crowded patch panel or
switch and helps prevent the cable from becoming accidentally disconnected. The three-millimeter
ruggedized plenum-rated jacket has low smoke and flame characteristics, making it suitable for premise
applications in ceilings, walls and ducts.
Specifications
OVERVIEW
UPC Code
037332258311
Technology
Multimode
1/3
N846D-01M-16CMG 400G
Multimode 50/125 OM4 Fiber Optic
Cable, Magenta, 1 m
Cleveland, OH 44122
United States
Optical Mode
OM4
PHYSICAL
Cable Jacket Color
Magenta
Connector Color
Green; Black; Aqua
Cable Jacket Material
PVC
Cable Jacket Rating
OFNP
Clad Diameter (microns)
125
Core Diameter (microns)
50
Primary Coating Diameter (microns)
245
Number of Fibers
16
Cable Length (ft.)
3.3
Cable Length (m)
1.01
Cable Length (in.)
39.4
Minimum Bend Radius
20 mm (Dynamic); 10 mm (Static)
Fiber Cable Length
1M (3.3 ft)
ENVIRONMENTAL
Operating Temperature Range
-4° to 140°F (-20° to 60°C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
35% to 65% RH, Non-Condensing
COMMUNICATIONS
Network Compatibility
400 Gbps
Transmission Distance
100M @ 850NM Wavelength
Attenuation @ 850NM
3.0 dB/km
Insertion Loss
16F: 0.60 dB; 24F: 0.35 dB
CONNECTIONS
Side A - Connector 1
16-STRAND MTP/MPO (FEMALE)
Side B - Connector 1
24-STRAND MTP/MPO (FEMALE)
Endface Polish
APC; UPC
Polarity
Type B (cross)
FEATURES & SPECIFICATIONS
Push/Pull Tabs
No
2/3
Cleveland, OH 44122
United States
Breakout
No
Trunk
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N846D-01M-16CMG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+2377.0465110+308.95808
