N846D-01M-16EMG
N846D-01M-16EMG
    TRIPPLITE
    光纤电缆 LC(8) 至 MTP 50/125 3.3'(1.0m)
N846D-01M-16EMG 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 400G Multimode 50/125 OM4 Plenum Fiber Optic Breakout Cable, 16F MTP/MPO-APC to (x4) LC Duplex (F/M), Magenta, 1 m Highlights ● OM4-rated cable recommended for 400 Gb speeds up to 100 m (@ 850 nm) ● MTP/MPO 16-fiber end designed for next-gen 400G QSFP-DD transceivers ● Connectors tested for low insertion loss and back reflection to ensure top performance ● Plenum rated for horizontal premise applications in air ducts and drop ceilings ● Magenta jacket allows fast, easy identification in a crowded switch or patch panel MODEL NUMBER: N846D-01M-16EMG Applications 400 GbE Ethernet cable supports high bandwidths necessary for next-generation cloud services, hyperscale data centers and telecom carriers. Features ● Connect 400G fiber Ethernet networks in your cloud service, hyperscale data center or telecom application ● Connect 400G Cisco, Arista, Juniper and other network switches through air ducts and drop ceilings Package Includes 400 GbE Cable Supports Higher Bandwidths Needed for Next-Gen Data and Voice Networking As the amount of traffic in data networks grows, so does the need for next-generation devices and fiber cables to support much higher bandwidths in cloud services, hyperscale data centers, telecom applications and equipment OEM companies. This multimode 50/125 OM4 breakout cable is an ideal choice for 400G Ethernet applications up to 100 meters (at 850 nm). It has documented insertion loss and back reflection testing on every connector and attenuation loss that meets or exceeds current standards. 16-Fiber MTP/MPO Connector Designed for the Latest QSFP-DD Transceivers The MPO connector has a wide parallel optical interface for use with the latest 400G QSFP-DD transceivers, making this cable an excellent solution for your high-density network application. The MPO connector is the same size as a standard SC connector, but 12 times denser, allowing vertical stacking in switches or patch panels where space is at a premium. Pull tabs make the cable easy to install or remove with one hand. The LC duplex connectors are recommended for high-density feed-through cassettes with no splicing required. Magenta Jacket Helps Avoid Misidentification That Can Cause Costly Downtime The OM4-rated cable has a magenta jacket, which is easy to identify quickly in a crowded patch panel or switch and helps prevent the cable from becoming accidentally disconnected. The three-millimeter ruggedized plenum-rated jacket has low smoke and flame characteristics, making it suitable for premise applications in ceilings, walls and ducts. Specifications OVERVIEW UPC Code 037332258373 Technology Multimode 1/3 N846D-01M-16EMG 400G Multimode 50/125 OM4 Fiber Optic Cable, Magenta, 1 m 1000 Eaton Boulevard Cleveland, OH 44122 United States Optical Mode OM4 PHYSICAL Cable Jacket Color Magenta Connector Color Black; Green; Aqua Cable Jacket Material PVC Cable Jacket Rating OFNP Clad Diameter (microns) 125 Core Diameter (microns) 50 Primary Coating Diameter (microns) 245 Number of Fibers 16 Cable Length (ft.) 3.3 Cable Length (m) 1.01 Cable Length (in.) 39.4 Minimum Bend Radius 20 mm (Dynamic); 10 mm (Static) Fiber Cable Length 1M (3.3 ft) ENVIRONMENTAL Operating Temperature Range -4° to 140°F (-20° to 60°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 400 Gbps Transmission Distance 100M @ 850NM Wavelength Attenuation @ 850NM 3.0 dB/km Insertion Loss MTP/MPO: 0.60 dB; LC: 0.20 dB CONNECTIONS Side A - Connector 1 16-STRAND MTP/MPO (FEMALE) Side B - Connector 1 (8) LC DUPLEX (MALE) Endface Polish PC Polarity Type B (cross) FEATURES & SPECIFICATIONS Push/Pull Tabs No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Breakout Yes Trunk Yes STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N846D-01M-16EMG 价格&库存
很抱歉,暂时无法提供与“N846D-01M-16EMG”相匹配的价格&库存,您可以联系我们找货
