N846D-05M-24DAQ
N846D-05M-24DAQ
    TRIPPLITE
    光纤电缆 MTP 至 MTP 50/125 16.4'(5.0m)
N846D-05M-24DAQ 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 400G Multimode 50/125 OM4 Plenum Fiber Optic Cable, 24F MTP/MPO-UPC to 16F MTP/MPO-UPC (F/F), Aqua, 5 m Highlights ● OM4-rated cable recommended for 400 Gb speeds up to 100 m (@ 850 nm) ● MTP/MPO 16- and 24-fiber ends designed for next-gen 400G QSFP-DD transceivers ● Connectors tested for low insertion loss and back reflection to ensure top performance ● Plenum rated for horizontal premise applications in air ducts and drop ceilings ● Aqua jacket allows fast, easy identification in a crowded switch or patch panel MODEL NUMBER: N846D-05M-24DAQ Applications 400 GbE Ethernet cable supports high bandwidths necessary for next-generation cloud services, hyperscale data centers and telecom carriers. Features ● Connect 400G fiber Ethernet networks in your cloud service, hyperscale data center or telecom application ● Connect 400G Cisco, Arista, Juniper and other network switches through air ducts and drop ceilings Package Includes 400 GbE Cable Supports Higher Bandwidths Needed for Next-Gen Data and Voice Networking As the amount of traffic in data networks grows, so does the need for next-generation devices and fiber cables to support much higher bandwidths in cloud services, hyperscale data centers, telecom applications and equipment OEM companies. This multimode 50/125 OM4 cable is an ideal choice for 400G Ethernet applications up to 100 meters (at 850 nm). It has documented insertion loss and back reflection testing on every connector and attenuation loss that meets or exceeds current standards. 16-Fiber and 24-Fiber MTP/MPO Connectors Designed for the Latest QSFP-DD Transceivers The MPO connectors have a wide parallel optical interface for use with the latest 400G QSFP-DD transceivers, making this cable an excellent solution for your high-density network application. The connectors are the same size as standard SC connectors, but much denser, allowing vertical stacking in switches or patch panels where space is at a premium. Pull tabs make the cable easy to install or remove with one hand. Aqua Jacket Helps Avoid Misidentification That Can Cause Costly Downtime The OM4-rated cable has an aqua jacket, which is easy to identify quickly in a crowded patch panel or switch and helps prevent the cable from becoming accidentally disconnected. The three-millimeter ruggedized plenum-rated jacket has low smoke and flame characteristics, making it suitable for premise applications in ceilings, walls and ducts. Specifications OVERVIEW UPC Code 037332260512 Technology Multimode 1/3 N846D-05M-24DAQ 400G Multimode 50/125 OM4 Fiber Optic Cable, Aqua, 5 m 1000 Eaton Boulevard Cleveland, OH 44122 United States Optical Mode OM4 PHYSICAL Cable Jacket Color Aqua Connector Color Aqua; Black; Magenta Cable Jacket Material PVC Cable Jacket Rating OFNP Clad Diameter (microns) 125 Core Diameter (microns) 50 Primary Coating Diameter (microns) 245 Number of Fibers 16 Cable Length (ft.) 16.4 Cable Length (m) 5.00 Cable Length (in.) 196.9 Minimum Bend Radius 20 mm (Dynamic); 10 mm (Static) Fiber Cable Length 5M (16.4 ft) ENVIRONMENTAL Operating Temperature Range -4° to 140°F (-20° to 60°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 400 Gbps Transmission Distance 100M @ 850NM Wavelength Attenuation @ 850NM 3.0 dB/km Insertion Loss 24F MTP/MPO: 0.35 dB; 16F MTP/MPO: 0.60 dB CONNECTIONS Side A - Connector 1 24-STRAND MTP/MPO (FEMALE) Side B - Connector 1 16-STRAND MTP/MPO (FEMALE) Endface Polish PC Polarity Type B (cross) FEATURES & SPECIFICATIONS Push/Pull Tabs No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N846D-05M-24DAQ 价格&库存
很抱歉,暂时无法提供与“N846D-05M-24DAQ”相匹配的价格&库存,您可以联系我们找货
