NGI-M05-C1
NGI-M05-C1
    TRIPPLITE
    网络 交换机 - 托管型 6 个端口 IP30
NGI-M05-C1 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 5-Port Managed Industrial Gigabit Ethernet Switch - 10/100/1000 Mbps, GbE SFP Slot, -40° to 75°C, DIN Mount Highlights ● 5 auto-negotiable RJ45 and a GbE SFP port connect devices over a LAN ● Industrial-grade switch supports operating temperature range of 40° to 75°C ● Easy-to-read LEDs indicate connection and activity status for each port ● CLI or web management allows monitoring and control of each connected device ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: NGI-M05-C1 Package Includes Industrial-grade switch expands 1G Ethernet connectivity to factory floors and other environments with space constraints and wide temperature ranges. Features 5-Port Managed Gigabit Ethernet Switch Connects Your Network Devices to a LAN This space-saving switch transmits data over a Gigabit Ethernet network. Five auto-negotiating 10/100/1000 Mbps ports send data via Cat5e/6/6a cable only to the devices designated to receive it, which improves the efficiency and potential throughput of the network. The NGI-M05-C1 also features a GbE SFP slot for uplinking data to other switches via optical fiber or copper. LEDs indicate when the switch is powered on and which Ethernet ports are showing activity. Protective Metal Housing Built to Last in Harsh Environments The compact NGI-M05-C1 adds 10/100/1000 Mbps Gigabit Ethernet capacity to industrial automation, government, military, oil and gas, mining and outdoor applications, as well as other environments with space constraints and wide temperature ranges. The IP30 industrial-grade aluminum case withstands vibration, shock and free fall. It can also operate in extreme temperatures ranging from -40 to 75 degrees Celsius (-40 to 167 degrees Fahrenheit). Monitors and Controls Devices via CLI and Web Configuration The NGI-M05-C1 supports MAC address auto-learning and auto-aging for efficient routing, as well as automatic MDI/MDI-X crossover detection for plug-and-play functionality. It also supports QoS, IGMP snooping, SFP DDMI and other device management features that fulfill the needs of high-performance managed industrial networks. IEEE 802.3x flow control allows smooth transmission of large files. Works with the Most Popular Web Browsers The NGI-M05-C1 is browser-based and works independently from the connected computer's operating system. Because switch compatibility is based on common hardware standards, rather than system software dependencies, the NGI-M05-C1 accommodates most platforms. Preferred web browsers include Google Chrome (on both Windows and macOS) and Microsoft Edge (Windows only). Pre-Installed DIN Rail Clip Allows for Convenient Installation The device may be DIN mounted using the pre-installed rail clip, which mounts firmly to any standard 35 mm DIN rail. Providing seamless operation in the event of power dips or failures, the switch features redundant 6-pin 20–57VDC terminal block power inputs to help prevent unnecessary downtime. When used with two power sources, the switch also supports alarm relay contacts that you can wire to your 1/4 ● NGI-M05-C1 5-Port Managed Industrial Gigabit Switch ● DIN rail-mounting clip (preinstalled) 1000 Eaton Boulevard Cleveland, OH 44122 United States existing alarm circuit to notify you instantly when a power disruption occurs. TAA-Compliant for GSA Schedule Purchases The NGI-M05-C1 is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and other federal procurement contracts. Specifications OVERVIEW UPC Code 037332266583 Product Type Managed Industrial Gigabit Ethernet Switch INPUT Maximum Input Amps Details 0.35A Voltage Compatibility (VDC) 20-57 Redundancy - Dual Power Inputs No Power Source 6-Pin Terminal Block POWER Power Consumption (Watts) 10.00 Power Consumption Detail 10W USER INTERFACE, ALERTS & CONTROLS LED Indicators - PWR (Green): for Power, - ALM (Red): for PWR & RPS fails, - RPS (Green): for Power by terminal block RPS, 1000 1~5th (Green): for Ethernet speed 1000Mbps, - LNK/ACT 1~5 th (Green): for data transmitting/receiving, - SFP 6th (Green): for speeds at 1000Mbps PHYSICAL Primary Form Factor DIN-Rail Color Black Material of Construction Metal Housing Form Factors Supported DIN-Rail Mountable Included Mounting Accessories Yes Shipping Weight (kg) 0.67 Unit Dimensions (hwd / in.) 5.360 x 1.200 x 4.100 Unit Dimensions (hwd / cm) 13.6 x 3 x 10.4 Unit Weight (lbs.) 1.17 Unit Weight (kg) 0.53 ENVIRONMENTAL 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Temperature Range -40° to 167°F (-40° to 75°C) Storage Temperature Range -40° to 185°F (-40° to 85°C) Relative Humidity 5 to 95% (non-condensing) Operating Elevation (m) 2000 ESD Protection ±8kV air discharge/ ±4kV contact discharge COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) Network Compatibility Details Auto-negotiable Switching Capacity 12Gbps Switching Capacity Details 1Gbps Per Port with Full Duplex CONNECTIONS Number of Ports 5 Ports 5 Ports Detail 5x 10/100/1000Mbps SFP Uplink Ports 1 SFP Uplink Ports Detail 100Base-FX/1000Base-X PoE Supported Ports 0 Network Switch Ports (5) 10/100/1000 (RJ45); (1) Dedicated SFP FEATURES & SPECIFICATIONS Jumbo Frames 10000 OSI Layer Layer 2 Console Port No MAC Auto Learning Yes MAC Addresses 8000 RMON Yes SNMP Yes Storm Control Yes DHCP Snooping Yes Auto MDI/MDIX Crossover Detection Yes Fans (Type/Quantity) Fanless STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); IEEE 802.1p CoS/QoS; IEEE 802.3 10Base-T; IEEE 802.3 Auto-Negotiation; IEEE 802.3ab 1000Base-T; IEEE 802.3az (Energy Efficient Ethernet); IEEE 802.3u 100Base-TX/FX; IEEE 802.3x Flow Control; IEEE 802.3z 1000Base-SX/LX; REACH; FCC (USA); Trade Agreements Act (TAA) 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
NGI-M05-C1 价格&库存
很抱歉,暂时无法提供与“NGI-M05-C1”相匹配的价格&库存,您可以联系我们找货
NGI-M05-C1
  • 1+3087.693821+399.44033
  • 10+2872.6214910+371.61745
库存:99
