1000 Eaton Boulevard
Cleveland, OH 44122
United States
8-Port Managed Industrial Gigabit Ethernet
Switch - Layer 2, 10/100/1000 Mbps, 4 GbE SFP
Ports, -40° to 75°C, DIN Mount
Highlights
8 auto-negotiating RJ45 and 4
GbE SFP ports connect devices
over a LAN
Industrial-grade switch supports
operating temperature range of 40° to 75°C
Comes pre-loaded with Layer 2
network management software
for IGMP snooping
CLI or web management allows
monitoring and control of each
connected device
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
MODEL NUMBER: NGI-M08C4-L2
Package Includes
Expands Gigabit Ethernet connectivity in industrial network applications requiring managed switches that
offer hassle-free deployment.
Features
8-Port Managed Gigabit Ethernet Switch Connects Your Network Devices to a LAN
This space-saving switch transmits data over a Gigabit Ethernet network. Eight auto-negotiating
10/100/1000 Mbps ports send data via Cat5e/6/6a cable only to the devices designated to receive it,
which improves the efficiency and potential throughput of the network. The NGI-M08C4-L2 also features
four GbE SFP slots for uplinking data to other switches via optical fiber or copper. LEDs indicate when the
switch is powered on and which Ethernet ports are showing activity.
Protective Metal Housing Built to Last in Harsh Environments
The compact NGI-M08C4-L2 adds 10/100/1000 Mbps Gigabit Ethernet capacity to industrial automation,
government, military, oil and gas, mining, factory and warehouse applications, as well as other
environments with space constraints and wide temperature ranges. The IP30 industrial-grade aluminum
case withstands vibration, shock and free fall. It can also operate in extreme temperatures ranging from 40 to 75 degrees Celsius (-40 to 167 degrees Fahrenheit).
Monitors and Controls Devices via CLI and Web Configuration
The NGI-M08C4-L2 supports MAC address auto-learning and auto-aging for efficient routing, as well as
automatic MDI/MDI-X crossover detection for plug-and-play functionality. It also supports QoS, IGMP
snooping, SFP DDMI and other device management features that fulfill the needs of high-performance
managed industrial networks. IEEE 802.3x flow control allows smooth transmission of large files. The
switch automatically shifts unused ports to an energy-saving state without interrupting network connection.
Pre-Loaded with Standard Layer 2 Network Management Software
This switch supports IGMP snooping in IPv4 to limit the flooding of multicast traffic by dynamically
configuring Layer 2 interfaces. Multicast traffic is forwarded only to those interfaces associated with IP
multicast devices.
Works with the Most Popular Web Browsers
The NGI-M08C4-L2 is browser-based and works independently from the connected computer's operating
system. Because switch compatibility is based on common hardware standards, rather than system
software dependencies, the NGI-M08C4-L2 accommodates most platforms. Preferred web browsers
include Google Chrome (on both Windows and macOS) and Microsoft Edge (Windows only).
1/4
NGI-M08C4-L2 8-Port Managed
Industrial Gigabit Switch
DIN rail-mounting clip (preinstalled)
Cleveland, OH 44122
United States
Pre-Installed DIN Rail Clip Allows for Convenient Installation
The device may be DIN mounted using the pre-installed rail clip, which mounts firmly to any standard 35
mm DIN rail. Providing seamless operation in the event of power dips or failures, the switch features
redundant 6-pin 12–60VDC terminal block power inputs to help prevent unnecessary downtime. When
used with two power sources, the switch also supports alarm relay contacts that you can wire to your
existing alarm circuit to notify you instantly when a power disruption occurs.
TAA-Compliant for GSA Schedule Purchases
The NGI-M08C4-L2 is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for
GSA (General Services Administration) Schedule and other federal procurement contracts.
Specifications
OVERVIEW
UPC Code
037332268457
Product Type
Managed Industrial Gigabit Layer 2 Ethernet Switch
INPUT
Maximum Input Amps Details
1.5A
Voltage Compatibility (VDC)
12-60
Redundancy - Dual Power Inputs
No
Power Source
6-Pin Terminal Block
POWER
Power Consumption (Watts)
18.00
Power Consumption Detail
18W
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
- PWR (Green): for Power, -ALM (Red): for PWR & RPS fails, ALM (Red): for PWR & RPS fails, -RPS (Green): for
Power by terminal block RPS, -1000 1~8 th (Green): for Ethernet speed 1000Mbps, -LNK/ ACT 1~8 th (Green): for
data transmitting/receiving, - SFP 9~12th (Green): for SFP port link up, - POST (Green): Illuminated for switch is
ready or running Blinking for self testing the device when power ON
PHYSICAL
Primary Form Factor
DIN-Rail
Color
Black
Material of Construction
Aluminum
Form Factors Supported
DIN-Rail Mountable
Included Mounting Accessories
Yes
Shipping Dimensions (hwd / in.)
2.44 x 9.17 x 7.20
Shipping Dimensions (hwd / cm)
6.20 x 23.29 x 18.29
Shipping Weight (lbs.)
2.60
2/4
Cleveland, OH 44122
United States
Shipping Weight (kg)
1.18
Unit Dimensions (hwd / in.)
6.300 x 1.970 x 4.720
Unit Dimensions (hwd / cm)
16 x 5 x 11.93
Unit Weight (lbs.)
2.09
Unit Weight (kg)
0.95
ENVIRONMENTAL
Operating Temperature Range
-40° to 167°F (-40° to 75°C)
Storage Temperature Range
-40° to 185°F (-40° to 85°C)
Relative Humidity
5 to 95% (non-condensing)
Operating Elevation (m)
2000
ESD Protection
±8kV air discharge/±4kV contact discharge
COMMUNICATIONS
Network Compatibility
1 Gbps (Gigabit)
Network Compatibility Details
Auto-negotiable
Switching Capacity
24Gbps
Switching Capacity Details
1Gbps Per Port with Full Duplex
CONNECTIONS
Number of Ports
8
Ports
8
Ports Detail
8x 10/100/1000Mbps
SFP Uplink Ports
4
SFP Uplink Ports Detail
4x 1000Base-X
PoE Supported Ports
Network Switch Ports
(8) 10/100/1000 (RJ45); (4) Dedicated SFP
FEATURES & SPECIFICATIONS
USB Specification
USB 2.0 (up to 480 Mbps)
Jumbo Frames
10000
OSI Layer
Layer 2
Console Port
Yes
MAC Auto Learning
Yes
MAC Addresses
160000
RMON
Yes
SNMP
Yes
3/4
Cleveland, OH 44122
United States
Storm Control
Yes
DHCP Snooping
Yes
Auto MDI/MDIX Crossover Detection
Yes
Fans (Type/Quantity)
Fanless
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); IEEE 802.1p CoS/QoS; IEEE 802.3 10Base-T; IEEE 802.3 Auto-Negotiation; IEEE 802.3ab
1000Base-T; IEEE 802.3az (Energy Efficient Ethernet); IEEE 802.3u 100Base-TX/FX; IEEE 802.3x Flow Control;
IEEE 802.3z 1000Base-SX/LX; REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“NGI-M08C4-L2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+6635.565211+851.41803
