NGI-S16
NGI-S16
    TRIPPLITE
    网络 交换机 - 托管型 16 个端口 IP30
NGI-S16 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 16-Port Lite Managed Industrial Gigabit Ethernet Switch - 10/100/1000 Mbps, -10° to 60°C, DIN Mount Highlights ● 16 auto-negotiable 10/100/1000 Mbps RJ45 ports connect devices over a LAN ● Industrial-grade switch supports operating temperature range of 10° to 60°C ● Cloud-based Lamungan platform lets you manage devices via web or mobile app ● Ideal for applications that demand high bandwidth convergence, such as IP security ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: NGI-S16 Package Includes Lite Managed switch expands 1G Ethernet connectivity to warehouses and other environments with space constraints and wide temperature ranges. Features 16-Port Smart Gigabit Ethernet Switch Connects Your Network Devices to a LAN This Lite Managed switch transmits data over a Gigabit Ethernet network. Sixteen auto-negotiating 10/100/1000 Mbps ports send data via Cat5e/6/6a cable only to the devices designated to receive it, which improves the efficiency and potential throughput of the network. LEDs indicate when the switch is powered on and which Ethernet ports are showing activity. Protective Metal Housing Built to Last in Harsh Environments The hardened NGI-S16 adds 10/100/1000 Mbps Gigabit Ethernet capacity to industrial automation, security, government, military, oil and gas, mining and outdoor applications that demand high bandwidth convergence, as well as other environments with space constraints and wide temperature ranges. The IP30 industrial-grade aluminum case withstands vibration, shock and free fall. It can also operate in extreme temperatures ranging from -10 to 60 degrees Celsius (-14 to 140 degrees Fahrenheit). Manages and Monitors Devices via Innovative Lamungan Management Platform The Lite Managed switch’s user-friendly cloud-based Lamungan platform helps you manage your network via web interface or mobile app. Three different features help you monitor connected devices, real-time traffic and link information. The Wizard is a set-up assistant that guides you step-by-step through initial management. The Topology Map with visual connectivity diagram displays network infrastructure and highlights link status. The Dashboard provides important performance and traffic-related information. A tricolor scheme – red (critical), yellow (alert), green (normal) – keeps you up to date on any network irregularities. Intelligent Connection Technology Ensures Plug-and-Play Operability The NGI-S16 supports MAC address auto-learning and auto-aging for efficient routing, as well as automatic MDI/MDI-X crossover detection for plug-and-play functionality. It also supports QoS, IGMP snooping and other device management features that fulfill the needs of high-performance managed industrial networks. IEEE 802.3x flow control allows smooth transmission of large files. Works with the Most Popular Web Browsers The NGI-S16 is browser-based and works independently from the connected computer's operating system. Because switch compatibility is based on common hardware standards, rather than system 1/4 ● NGI-S16 16-Port Lite Managed Industrial Gigabit Ethernet Switch ● DIN rail-mounting clip (preinstalled) 1000 Eaton Boulevard Cleveland, OH 44122 United States software dependencies, the NGI-S16 accommodates most platforms. Preferred web browsers include Google Chrome (on both Windows and macOS) and Microsoft Edge (Windows only). Pre-Installed DIN Rail Clip Allows for Convenient Installation The switch may be DIN mounted using the pre-installed rail clip, which mounts firmly to any standard 35 mm DIN rail. Providing seamless operation in the event of power dips or failures, the switch features redundant 6-pin 12–60VDC terminal block power inputs to help prevent unnecessary downtime. When used with two power sources, the switch also supports alarm relay contacts that you can wire to your existing alarm circuit to notify you instantly when a power disruption occurs. TAA-Compliant for GSA Schedule Purchases The NGI-S16 is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and other federal procurement contracts. Specifications OVERVIEW UPC Code 037332266989 Product Type Smart Hardened Gigabit Ethernet Switch INPUT Maximum Input Amps Details 1.5A Voltage Compatibility (VDC) 12-60 Redundancy - Dual Power Inputs No Power Source 6-Pin Terminal Block POWER Power Consumption (Watts) 12.00 Power Consumption Detail 12W USER INTERFACE, ALERTS & CONTROLS LED Indicators - PWR (Green): for Power, ALM (Red): for PWR & RPS fails, - RPS (Green): for Power by terminal block RPS, 1000 1~16th (Green): for Ethernet speed 1000Mbps, - LNK/ACT 1~16th (Green): for data transmitting/receiving PHYSICAL Primary Form Factor DIN-Rail Color Black Material of Construction Metal Housing Form Factors Supported DIN-Rail Mountable Included Mounting Accessories Yes Unit Dimensions (hwd / in.) 6.300 x 1.970 x 4.720 Unit Dimensions (hwd / cm) 16 x 5 x 11.93 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Weight (lbs.) 2.01 Unit Weight (kg) 0.91 ENVIRONMENTAL Operating Temperature Range -14° to 140°F (-25° to 60°C) Storage Temperature Range -40° to 185°F (-40° to 85°C) Relative Humidity 5 to 95% (non-condensing) Operating Elevation (m) 2000 ESD Protection ±8kV air discharge / ±4kV contact discharge COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) Network Compatibility Details Auto-negotiable Switching Capacity 32Gbps Switching Capacity Details 1Gbps Per Port with Full Duplex CONNECTIONS Number of Ports 16 Ports 16 Ports Detail 16x 10/100/1000Mbps SFP Uplink Ports 0 PoE Supported Ports 0 Network Switch Ports (16) 10/100/1000 (RJ45) FEATURES & SPECIFICATIONS Jumbo Frames 10000 Console Port No MAC Auto Learning Yes MAC Addresses 8000 RMON Yes SNMP Yes Storm Control Yes DHCP Snooping Yes Auto MDI/MDIX Crossover Detection Yes Fans (Type/Quantity) Fanless STANDARDS & COMPLIANCE 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; CE (Europe); IEEE 802.1p CoS/QoS; IEEE 802.3 10Base-T; IEEE 802.3 Auto-Negotiation; IEEE 802.3ab 1000Base-T; IEEE 802.3az (Energy Efficient Ethernet); IEEE 802.3u 100Base-TX/FX; IEEE 802.3x Flow Control; REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
NGI-S16 价格&库存
很抱歉,暂时无法提供与“NGI-S16”相匹配的价格&库存,您可以联系我们找货
