1000 Eaton Boulevard
Cleveland, OH 44122
United States
M12 X-Code Cat6a 10G F/UTP CMR-LP Shielded
Ethernet Cable (M12 M/RJ45 M), IP68, PoE, Blue,
10 m (32.8 ft.)
MODEL NUMBER: NM12-6A2-10M-BL
Highlights
Designed to withstand vibration,
moisture and extreme
temperatures in harsh
environments
M12 Connector end IP68-rated
to resist dust and endure
immersion in 1.5 m of water up
to 60 min.
Supports 60W PoE to save you
expense and effort of powering
PoE devices individually
UL CMR-LP certified to meet
high-temperature safety
standards in PoE applications
Blue PVC jacket easy to identify
quickly in field devices,
controllers and switches
Package Includes
NM12-6A2-10M-BL M12 X-Code
Cat6a 10G Ethernet Cable, M12
M/RJ45 M, Blue, 10 m (32.8 ft.)
Connects 10G Ethernet network equipment in industrial and other harsh environments subject to vibration,
humidity and extreme temperatures.
Features
Cat6a M12 Cable Recommended for Industrial and Other Harsh Environments
This M12 X-Code cable connects 10 GbE networks in wet/humid environments, places subject to vibration
and other areas where protection from harsh elements is essential, such as factories, warehouses,
recycling plants, airports, railways and machine shops. The circular M12 connector with 12-millimeter
locking thread is especially designed for washdown and corrosive applications, including agriculture,
alternative energy, communications, factory automation, measurement and control, robotics,
transportation and food/beverage facilities.
IP68 Rating Denotes Resistance to Dust and Water
The IP68 rating means the M12 connector end is not only 100% protected against dust, but also able to
endure immersion in 1.5 meters of water for up to 60 minutes with no damage or decline in performance.
Supports Power over Ethernet to Save You Money and Give You More Installation Choices
Because this Cat6a cable supports high-power 60W PoE, it can supply the power to operate compatible
data, voice, security and audio/video PoE devices, such as surveillance cameras, VoIP telephones and
access control devices. This saves you the expense and effort of purchasing, connecting and installing
individual power supplies for each device, as well as installing separate power and data cables. It also
helps you install PoE devices in areas far away from AC outlets, such as poles or ceilings.
CMR-LP Certified for Cable Installations with Increased Power Levels
UL's Limited Power (LP) certification indicates the NM12-6A2-10M-BL has been evaluated to handle the
marked current under installation scenarios without exceeding the temperature rating of the cable. This
CMR-LP-certified cable provides a simple way to prepare installations for increased power levels without
having to worry about susceptible issues caused by excessive heat.
Colored Blue to Avoid Misidentification That Can Cause Costly Downtime
This Cat6a F/UTP copper cable features a blue PVC jacket that allows easy, fast identification in field
devices, controllers and switches and helps prevent the cable from becoming inadvertently disconnected.
1/3
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332265500
Technology
Cat6a; PoE
PHYSICAL
Cable Jacket Color
Blue
Cable Jacket Material
PVC
Cable Jacket Rating
CMR-LP
Cable Shielding
F/UTP
Cable Outer Diameter (OD)
7.3 mm
Number of Conductors
4 Pair
Conductor Material
Solid Copper
Conductor Gauge
23 AWG
Wire Gauge (AWG)
23
Cable Length (ft.)
32.8
Cable Length (m)
10.00
ENVIRONMENTAL
Operating Temperature Range
14° to 140°F (-10° to 60°C)
Storage Temperature Range
-4° to 158°F (-20° to 70°C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
Power Provided to Connected
Device(s)
51W (60W @ SOURCE, 51W @ DEVICE)
COMMUNICATIONS
Bandwidth per TIA Standard
500 MHz
Maximum Bandwidth as Tested
600 MHz
Network Compatibility
10 Gbps
IEEE Standards Supported
802.3bt
CONNECTIONS
PoE Capability
60W (802.3bt)
Side A - Connector 1
M12 X CODE (MALE)
Side B - Connector 1
RJ45 (MALE)
2/3
Cleveland, OH 44122
United States
Crossover Wiring
No
Contact Plating
Gold
PoE Type
Type 3 PoE++/UPoE (60W, IEEE 802.3bt)
Connector Type
Snagless
Wiring Configuration
EIA/TIA 568B
Angled Connector
No
FEATURES & SPECIFICATIONS
Antibacterial
No
IP68 Rated
Yes
Snagless Connector
Yes
STANDARDS & COMPLIANCE
Protection Rating
IP68
Product Certifications
UL Listed; cUL Listed
Product Compliance
CE (Europe); RoHS; IEEE 802.3bt PoE++; REACH; UKCA; Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“NM12-6A2-10M-BL”相匹配的价格&库存,您可以联系我们找货
