NPOEI-90W-1G
NPOEI-90W-1G
    TRIPPLITE
    PoE Injector Cat5e/Cat6/Cat6a
NPOEI-90W-1G 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Industrial Gigabit Ethernet PoE injector, 90W PoE++, 802.3bt, Midspan, -40 to +75, IP30 housing, Dual 24-57VDC , DIN rail, 1 Port Highlights ● Saves money by delivering 90W of power + data up to 328 ft. through existing cabling ● Extends power + data to any PoE or PoE+ device installed where no AC outlet is available ● Supports Gigabit Ethernet data transfer speeds up to 1000 Mbps (1 Gbps) ● Quick and easy plug-and-play installation with no configuration necessary ● Industrial-grade IP30 metal housing ready for DIN railmounting with included hardware MODEL NUMBER: NPOEI-90W-1G Applications Industrial-grade PoE+ injector uses existing Cat6 cable to supply 90W power + data up to 328 ft. to a PoE device connected to a non-PoE switch. ● Add a security camera to your network without upgrading to a new PoE switch ● Install a touchscreen kiosk or VoIP phone in an area without a standard power connection ● Fill in Wi-Fi dead spots in your office with a wireless access point connected to your LAN Features Now You Can Add a PoE Device to Your LAN Without a PoE Switch Add a surveillance camera, wireless access point, VoIP phone, outdoor kiosk, smart lights or other PoE (Power over Ethernet) device to your home or office network, even if your network switch doesn’t support PoE. Instead of making an expensive upgrade to a PoE switch, you can use this single-port PoE++ injector to send 90W of power, as well as Gigabit Ethernet data, through your existing Cat5e/6/6a cabling. It is recommended for outdoor applications, such as LED lights, security cameras and heater elements. Saves You Time and Money on Unnecessary Equipment Updates This compact PoE plus injector delivers 10/100/1000 Mbps (1 Gbps) of data and up to 90W of power using existing Cat5e/6/6a cables. That means, in addition to not buying a new PoE network switch, you also don’t need to install new AC power lines and electrical outlets. This cost-effective midspan injector sends DC power and Ethernet data through your Ethernet cable, cutting down on cable clutter, equipment costs and installation time and labor. Expand Your PoE Network Up to 328 ft. The NPOEI-90W-1G delivers both power and data to any IEEE 802.3af (PoE), 802.3at (PoE+) or 802.3bt (4PPoE) device up to 328 feet (100 meters) away. This allows you to install a device in a building lobby, on a ceiling, inside a warehouse or anywhere else an AC power outlet is unavailable. The PoE+ injector supports full-duplex 2 Gbps communication for sending and receiving data simultaneously. It also protects your device against short circuits, high voltage and overloads. Simple Plug-and-Play Installation Has Your Device Connected in Minutes No configuration or software is required to add the NPOEI-90W-1G to your LAN (local area network). Just connect your switch or Ethernet network to the shielded RJ45 LAN port and your PoE device to the shielded RJ45 PoE port using existing Cat5e/6/6a cable. The included terminal block offers dual primary and redundant power inputs. DIP switches and LEDs help you find the right settings for your application. The NPOEI-90W-1G automatically detects which connected devices are compatible. Designed for Installation on a DIN Rail A DIN rail kit is included for mounting the IP30-rated metal housing on a well-grounded corrosion-free rail. The fanless design is ideal for silent operation. 1/3 System Requirements Device that meets IEEE 802.3af, 802.3at or 802.3bt standards Package Includes ● NPOEI-90W-1G Industrial Gigabit PoE++ Midspan Injector ● 24-57VDC terminal block ● DIN rail-mounting kit ● Quick Start Guide 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332265920 Product Type Injector Technology Cat5/5e; Cat6; Cat6a INPUT Voltage Compatibility (VDC) 24-57 Input Frequency 50/60 Hz USER INTERFACE, ALERTS & CONTROLS LED Indicators PWR (Green) - Power; RPS (Green) - Redundant Power; ALM (Red) - Primary/Secondary power lost, PoE overload; PoE (Green) - PoE in use; NBT (Green) - Detection Mode is enabled; 93-96W (Red) - Overload; PoE Usage (Green) Injector PoE power range PHYSICAL Primary Form Factor DIN-Rail; Rackmount; Wall-mount Color Black Unit Dimensions (hwd / in.) 4.570 x 0.980 x 3.930 Unit Dimensions (hwd / cm) 11.6 x 2.5 x 10.0 ENVIRONMENTAL Operating Temperature Range -49° to 167°F (-40° to 75°C) Storage Temperature Range -49° to 185°F (-40° to 85°C) Relative Humidity 5% to 95% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3af; 802.3at; 802.3bt CONNECTIONS Number of Ports 1 Side A - Connector 1 RJ45 (FEMALE) Side B - Connector 1 RJ45 (FEMALE) PoE Type Type 3 PoE++/UPoE (60W, IEEE 802.3bt) STANDARDS & COMPLIANCE 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
NPOEI-90W-1G
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入、输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
NPOEI-90W-1G 价格&库存
很抱歉,暂时无法提供与“NPOEI-90W-1G”相匹配的价格&库存,您可以联系我们找货
