NSS-G16D2
NSS-G16D2
    TRIPPLITE
    网络 交换机 - 托管型 18 个端口
NSS-G16D2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 16 10/100/1000Mbps Port Gigabit L2 Web-Smart Managed Switch, 2 SFP Slots, 36 Gbps, Web, 8Outlet 120V PDU/Surge Protect MODEL NUMBER: NSS-G16D2 Highlights ● IP-MAC-Port-Binding, ACL, Storm Control ● Port Security, DHCP Snooping, 802.1x, L2 ● WEB management, SNMP, RMON features ● 16 ports and 2 dedicated MiniGBIC SFP slots ● Enterprise-level, security and layer 2 management ● 3860-joule surge protection rating ● Built-in 8-outlet PDU with diagnostic LEDs Package Includes Combines a Web-Smart 16-port Gigabit network switch with a basic PDU/surge protector in one 1U rackmount unit. Ideal for monitoring and controlling an LAN and powering equipment in a small-to-medium distributed network. Description The energy-efficient NSS-G16D2 16-Port Gigabit L2 Web-Smart Managed Switch does more than complete your home or office LAN. It also features a basic 120V 15A PDU to distribute reliable AC power to critical IT equipment in your wiring closet, server room or equipment rack. Two dedicated mini-GBIC SFP ports are also included for uplinking data to other switches via optical fiber or copper. This switch features 16 twisted-pair RJ45 Gigabit Ethernet ports that support auto-negotiable 10/100/1000 Mbps and auto MDI/MDIX cross-over detection functions for convenient plug-and-play capability. Easy-toread LEDs indicate connection and activity status for each port. Built-in management software lets you monitor and control each connected device via secure web-based interface. Each port supports up to 2 Gbps with full duplex. The rear panel contains eight NEMA 5-15R outlets that supply continuous power to connected devices. Your equipment is protected by 3860 joules of surge suppression, as well as front-panel LEDs that let you monitor line status at a glance. A 12A circuit breaker trips if the current drawn by connected equipment exceeds the PDU’s maximum load rating. The NSS-G16D2 supports IEEE802.3az Energy Efficient Ethernet standards. The heavy-duty metal housing mounts into 1U of an EIA-standard 19-inch rack using the included hardware. The six-foot input cord with NEMA 5-15P plug connects to a protected UPS, generator or mains input AC source. Features Enterprise Managed Network Switch16 twisted-pair RJ45 Gigabit Ethernet portsAuto-negotiable 10/100/1000 MbpsAutomatic MDI/MDIX cross-over detection36 Gbps switching capacity (2 Gbps per port with full duplex)Easy-to-read LEDs indicate connection and activity status for each portSupports 10k jumbo framesSupports MAC address auto-learning and auto-aging up to 16,000 addressesAdvanced Enterprise level, L2 management features Advanced Network MonitoringBuilt-in Ethernet network interface allows full remote access for monitoring, configuration and control and notifications via web browserVLAN, trunking and other features improve switch’s and network’s efficiency and performance Basic 120V 15A PDU8 NEMA 5-15R rear outlets supply continuous power to connected devices3860 joules of Isobar surge suppressionFront-panel LEDs indicate protection, fault, and line status40–80 dB EMI/RFI noise reduction 1/5 ● NSS-G16D2 16-Port Gigabit L2 Managed Network Switch ● Rack-mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Dual Dedicated SFP PortsConnect two SFP (mini-GBIC) transceiver modules for uplinking to other switches via optical fiber or copperLEDs indicate interface traffic Compliant with Energy Efficient Ethernet standardsAutomatically shifts unused ports to low power state without interrupting network connectionMeets IEEE 802.3ab, 802.3i, 802.3u, 802.3x, 802.3, 802.1q, 802.1d, 802.1w, 802.3ad and 802.3az standards Mounts Horizontally in 1U of Rack SpaceCompatible with EIA-standard 19 in. racks and rack enclosuresFanless metal housing for silent operationNEMA 5-15P plug with 6 ft. AC power cord Works with the Most Popular Web Browsers The NSS-G16D2 is browser-based and works independently from the connected computer's operating system. Because switch compatibility is based on common hardware standards, rather than system software dependencies, the NSS-G16D2 accommodates most platforms. Preferred web browsers include Google Chrome (on both Windows and macOS) and Microsoft Edge (Windows only). Specifications OVERVIEW UPC Code 037332195470 Product Type Switch/PDU Combination PDU Type Basic INPUT Input Phase Single-Phase Electrical Consumption (Max) 30W PDU Plug Type NEMA 5-15P Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P Input Cord Length (ft.) 6 Input Cord Length (m) 1.83 OUTPUT Output Circuit Breakers 12A Output Receptacles (8) 5-15R POWER Power Consumption (Watts) 30 Power Consumption Detail PDU supports up to 12A total; Network switch consumes up to 30 watts USER INTERFACE, ALERTS & CONTROLS Switches 2 included switches enable HARD factory reset and SOFT factory reset options 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States LED Indicators Power LED (Green for Power On); Two LEDs per RJ45 port (Green indicates 10/100Mbps link; Amber indicates 1000Mbps link; LEDs flash to indicate port activity); Two LEDs indicate SFP connection (Green); One LED indicates system status (Green); Set of 3 LEDs indicate surge suppression status (Green: Protection Present / Red: Fault / Green: Line OK) SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 3860 Protection Modes L-N, L-G, N-G Clamping Voltage (RMS) 330 EMI / RFI Filtering 40-80dB PHYSICAL Primary Form Factor Rackmount Color Black Housing Color Black Minimum Required Rack Depth (cm) 39.12 Minimum Required Rack Depth (inches) 15.4 PDU Form Factor Horizontal (1U) Shipping Dimensions (hwd / in.) 4.70 x 17.00 x 20.70 Shipping Dimensions (hwd / cm) 11.94 x 43.18 x 52.58 Shipping Weight (lbs.) 10.80 Shipping Weight (kg) 4.90 Unit Dimensions (hwd / in.) 1.710 x 17.320 x 12.400 Unit Dimensions (hwd / cm) 4.34 x 44 x 31.5 Unit Weight (lbs.) 8.49 Unit Weight (kg) 3.85 Rack Units 1 ENVIRONMENTAL Storage Temperature Range 14° to 158°F (-10° to 70°C) Relative Humidity 5 to 95% (Non-condensing) Operating Elevation (ft.) 10000 Operating Temperature 32 to 104 F (0 to 40 C) Operating Elevation (m) 3000 COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) Network Compatibility Details Auto-negotiable 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Switching Capacity 36 Gbps Switching Capacity Details 2 Gbps per port with full duplex CONNECTIONS Number of Ports 18 Ports 16 Ports Detail 16x 10/100/1000BASE-T; 1x Console SFP Uplink Ports 2 SFP Uplink Ports Detail 2x Mini-GBIC SFP Uplinks PoE Supported Ports 0 Network Switch Ports (16) 10/100/1000 (RJ45); (2) Dedicated SFP; (1) Console (RJ45) FEATURES & SPECIFICATIONS Jumbo Frames 10000 OSI Layer Layer 2 Console Port Yes MAC Auto Learning Yes MAC Addresses 16000 RMON Yes SNMP Yes Storm Control Yes DHCP Snooping Yes Auto MDI/MDIX Crossover Detection Yes Fans (Type/Quantity) Fanless STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 60950-1 (Canada); NOM (Mexico); UL 1449; UL 60950-1 Product Compliance RoHS; IEEE 802.1d (STP); IEEE 802.1q Tagged VLAN; IEEE 802.1w (RSTP); IEEE 802.3 Auto-Negotiation; IEEE 802.3ab 1000Base-T; IEEE 802.3ad (LACP); IEEE 802.3az (Energy Efficient Ethernet); IEEE 802.3i 10Base-T; IEEE 802.3u 100Base-TX/FX; IEEE 802.3x Flow Control; REACH; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
NSS-G16D2 价格&库存
很抱歉,暂时无法提供与“NSS-G16D2”相匹配的价格&库存,您可以联系我们找货
