OMNISMART750MX
OMNISMART750MX
    TRIPPLITE
    750VA 460W 120V LINE-INTERACTIVE
OMNISMART750MX 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 750VA 460W 120V Line-Interactive UPS - 12 NEMA 5-15R Outlets, Double-Boost AVR, USB, Desktop/Wall-Mount Highlights ● Protects equipment against blackouts, brownouts, transient surges and line noise ● Keeps AC power running during blackouts to allow time for file saves and safe shutdown ● Double-boost AVR maintains 120V nominal output during brownouts and overvoltages ● 12 NEMA 5-15R outlets power and protect PC, home theater or digital signage equipment ● High >98.3% efficiency and low BTU ratings save electricity and lower your energy costs MODEL NUMBER: OMNISMART750MX Applications ● Protect your PC and other sensitive electronics against power surges, line noise, brownouts, overvoltages and blackouts ● Operate essential equipment during short-term power outages using battery backup power ● Shut down desktop PCs and other equipment without data loss during long-term power outages ● Extend runtime for DVRs, wireless routers and other lowpower home network equipment Desktop UPS offers complete power protection for small network applications, including home offices, security systems and digital signage. Features 750VA/460W/120V Battery Backup for PCs, Home Theaters or Digital Signage This OmniSmart® line-interactive UPS system with AVR protection provides reliable battery backup and AC power protection against blackouts, brownouts, overvoltages, surges and line noise that can damage valuable electronics or destroy data. The 120V battery backup is ideal protection for your home office, media center or commerce components, including computers, routers, printers, HDTVs, Blu-ray players, game consoles, ATMs, security systems and digital signage equipment. Package Includes Allows Time to Back Up Critical Files During a Blackout Backup support allows you to work through short power failures and gives you enough time to safely save files and shut down your system in case of a prolonged blackout. Backup time varies according to load, but internal battery should keep a half load (230W) powered as long as 10 minutes and a full load (460W) up to 3.6 minutes. During normal operation, incoming utility power keeps the replaceable internal battery fully charged, so backup power will always be available. 12 NEMA 5-15R Outlets Protect Your Connected Components Six 5-15R outlets provide battery backup, surge protection and voltage regulation for your computer, monitor and other crucial components. The other six 5-15R outlets provide surge suppression only for printers, speakers and other desktop equipment regarded as non-essential during a blackout. In addition, RJ45 jacks protect a telephone/DSL dial-up or 10BaseT Ethernet connection. Double-Boost AVR Corrects Low/High-Voltage Conditions for Enhanced Performance A double-boost, single-cut AVR (Automatic Voltage Regulation) circuit, designed specifically for the LATAM region, protects your equipment from incremental hardware damage, data loss and performance problems caused by brownouts and overvoltages. Slight under-voltages as low as 93V are boosted by 13%. More severe brownouts as low as 78V are increased by 35%. A voltage cut of 16% reduces UPS output during overvoltage conditions as high as 152V, all while keeping the battery fully charged and ready to take over in case of power failure. 600 Joules Fight Back Against Unexpected Power Surges A 600-joule surge suppression rating protects connected components from the harmful effects of power surges. 1/6 ● OMNISMART750MX 750VA 460W 120V Line-Interactive UPS with 12 Outlets ● USB cable ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Designed for High Efficiency to Help You Save Money and Protect the Environment A >98.3% efficiency rating reduces BTU emissions, energy consumption and, ultimately, your energy costs. Combats Electromagnetic Interference That Can Harm Equipment Various electromagnetic and radio sources found in virtually every home and business can cause disruptive interference on the AC line. Known as EMI (electromagnetic interference) and RFI (radio frequency interference), this line noise is a common cause of performance problems and can lead to incremental hardware damage, data corruption and audio/video transmission problems. The OMNISMART750MX incorporates technology that filters out disruptive line noise so that it won't affect your equipment. Alarm and Diagnostic LEDs Keep You Informed 24/7 The alarm sounds to report low battery, battery replace, overload and fault condition. A set of 4 LEDs reports AC line present (green), battery mode (yellow), overload/low battery (red) and battery replace (red). USB Port Allows for Automatic Saves and Shutdowns The HID-compliant USB port connects the UPS to a computer running free downloadable PowerAlert® software to enable safe unattended system shutdown in case of a prolonged power failure. USB cable is included. Compact Housing Compatible with Easy Desktop or Wall-Mount Installation The space-saving UPS fits on a desktop, shelf or any other flat surface convenient to your workstation or home theater. Keyhole mounting tabs on the rear allow easy wall installation. The five-foot power cord with space-saving right-angle NEMA 5-15P plug connects to any compatible AC outlet. Specifications OVERVIEW UPC Code 037332258175 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 10A Nominal Input Voltage(s) Supported 120V AC Nominal Input Voltage Description Supports input voltages from 78 to 152V UPS Input Connection Type 5-15P; Right-Angled Input Circuit Breakers 10A @ 120V UPS Input Cord Length (ft.) 7 UPS Input Cord Length (m) 2.1 Input Frequency 60 Hz (±3%) OUTPUT Output Capacity (VA) 750 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Capacity (kVA) 0.75 Output Capacity (Watts) 460 Output Capacity (kW) 0.46 Output Capacity Details Supports 125% load for 10 minutes, 20 seconds (load PF=1.0); Supports 110% for up to 27 seconds Power Factor 0.6 Nominal Voltage Details 120v nominal output in AC and battery modes Frequency Compatibility 60 Hz Frequency Compatibility Details 60 Hz (±3%) tolerance Output Voltage Regulation (Line Mode) 120V~ (+8% / -15%) Output Voltage Regulation (Battery Mode) 120V (±5%) UPS Output Receptacles (Surge Suppression Only) 6 UPS outlets, 6 surge-only outlets Output AC Waveform (AC Mode) Pure sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 120V Output Receptacles (12) 5-15R Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 3.6 min. (460W) Runtime Half Load (min.) 11 min. (230W) Expandable Runtime No DC System Voltage (VDC) 12 Battery Recharge Rate (Included Batteries) 5 hours to 90% Battery Access Battery access door Battery Replacement Description Replaceable internal batteries (see manual) VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 78 to 152 Overvoltage Correction Input voltages between 128 and 152 are cut by 16% Undervoltage Correction Input voltages between 93 and 108 are boosted by 13% Severe Undervoltage Correction Input voltages between 78 and 93 are boosted by 35% 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States USER INTERFACE, ALERTS & CONTROLS Switches Switch supports On/Off power control (release after 3 seconds), UPS battery-test (line mode only, release after 5 seconds), Alarm-mute (battery mode only, release after 0.5 seconds) Alarm Cancel Operation Manual alarm-cancel supported Audible Alarm Alarm sounds to report Battery-mode operation, Low-battery status, Overload status and UPS Battery test modelowbattery, fault, overload and replace-battery conditions LED Indicators 2 Status LEDs; GREEN indicates power status and operating mode / RED indicates battery-low, overload, replacebattery and fault conditions (see manual) SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 600 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL or Ethernet EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Desktop Rack Height 0U Installation Form Factors Supported with Included Accessories Tower; Ultra-compact desktop; Wallmount Primary UPS Depth (mm) 305 Primary UPS Height (mm) 105 Primary UPS Width (mm) 190 Shipping Dimensions (hwd / in.) 10.71 x 6.30 x 15.00 Shipping Weight (kg) 6.60 UPS Power Module Dimensions (hwd, in.) 4.14 x 7.48 x 12 UPS Power Module Weight (kg) 6.10 UPS Power Module Weight (lbs.) 13.45 Unit Dimensions (hwd / in.) 4.140 x 7.480 x 12.000 Unit Weight (lbs.) 13.450 Unit Weight (kg) 6.10 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 113°F (-15° to 45°C ) Relative Humidity 0 to 90%, non-condensing AC Mode BTU / Hr. (Full Load) 30.72 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States AC Mode Efficiency Rating (100% Load) >98.4% Operating Elevation (ft.) Up to 10,000 ft. Operating Elevation (m) Up to 3000m COMMUNICATIONS PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB interface cable included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management not supported Communications Interface USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time 2-6 milliseconds (typical), 10 milliseconds (max) Low Voltage Transfer to Battery Power (Setpoint) 78 High Voltage Transfer to Battery Power (Setpoint) 152 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Automatic Voltage Regulation (AVR); Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS Grounding Details Includes side-panel grounding lug APPLICATIONS UPS Applications Home/Office Desktop STANDARDS & COMPLIANCE Product Certifications RETIE (Colombia); CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; EAC (Belarus, Kazakhstan, Russia); ENERGY STAR Qualified; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 2-year limited warranty Product Warranty Period (Latin America) 2-year limited warranty Product Warranty Period (International) 2-year limited warranty 5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Mexico) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
OMNISMART750MX 价格&库存
很抱歉,暂时无法提供与“OMNISMART750MX”相匹配的价格&库存,您可以联系我们找货
