OMNIVSX650
OMNIVSX650
    TRIPPLITE
    LINE INTERACTIVE UPS, C13 OUTLET
OMNIVSX650 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Line Interactive UPS, C13 Outlets (4) - 230V, 650VA, 360W, Ultra-Compact Design MODEL NUMBER: OMNIVSX650 Highlights ● Correct brownouts as low as 170V and overvoltages as high as 280V without using battery ● 650VA capacity supports a variety of desktop and networking devices ● Fused C14 inlet accepts usersupplied AC power cord with country-specific plug ● Ultra-compact design saves space Applications ● Protect your PC and other sensitive electronics against power surges, brownouts and blackouts ● Operate your connected equipment during short-term power outages ● Shut down equipment during longer power outages without data loss ● Provide battery backup and power protection in locations with limited space ● Support small business phone systems, POS (point-of-sale) systems, kiosks and ATMs OMNIVSX650 provides voltage regulation, surge suppression and battery backup support for computers and other sensitive electronics. Features Protect Your Electronics with Voltage Regulation, Surge Suppression and Battery Backup Line-interactive UPS offers voltage regulation, surge suppression and battery backup support. It regulates brownouts as low as 170V and overvoltages as high as 280V back to usable levels without using battery power. All four IEC320 C13 UPS outlets offer battery backup, automatic voltage regulation and AC surge suppression. Three front-panel LEDs and audible alarm combine to indicate off/on power status, line power availability, battery mode operation, low battery, overload, battery replacement and fault mode. Operate Your Connected Equipment During Short-Term Outages This UPS supports an entry-level PC consuming 60W continuous up to 42 minutes during power failure condition and a 50% load of 180W for 6 minutes. It also enables users to operate connected equipment during short-duration outages without interruption and shut down without data loss during longer outages. All the UPS C13 outlets receive battery backup. Specifications OVERVIEW UPC Code 037332217943 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 2.8A Nominal Input Voltage(s) Supported 230V AC 1/4 Package Includes ● OMNIVSX650 line interactive UPS ● Two C13 to C14 1.5m power cables ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States UPS Input Connection Type C14 inlet UPS Input Connection Description The C14 inlet accepts included or user-supplied AC power cords OUTPUT Output Capacity (VA) 650 Output Capacity (kVA) 0.65 Output Capacity (Watts) 360 Output Capacity (kW) 0.36 Nominal Voltage Details 230V nominal output in battery mode Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Automatic frequency selection Output Voltage Regulation (Line Mode) 230V (±9.5%) Output Voltage Regulation (Battery Mode) ±10% Included Output Power Cables Includes 2 C13 to C14 power cables Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 220V; 230V; 240V Output Receptacles (4) C13 Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 1 min. (360W) Runtime Half Load (min.) 6 min. (180W) Expandable Runtime No DC System Voltage (VDC) 12 Battery Recharge Rate (Included Batteries) 8 hours from 10% to 90% Battery Replacement Description See manual for battery replacement information VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with input voltage as low as 170 and as high as 280 Overvoltage Correction Input voltages between 253 and 280 are reduced by 15% Undervoltage Correction Input voltages between 170 and 207 are boosted by 18% 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States USER INTERFACE, ALERTS & CONTROLS Switches 1 Switch controls off/on power status Audible Alarm Audible alarm with distinct tone patterns indicates low-battery, overload, replace-battery and fault-mode LED Indicators 3 front panel LEDs indicate off/on power status, line power availability, battery mode operation, overload, replacebattery and fault-mode SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 312 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower Installation Form Factors Supported with Included Accessories Tower Primary UPS Depth (mm) 300 Primary UPS Height (mm) 142 Primary UPS Width (mm) 102 Shipping Dimensions (hwd / in.) 8.70 x 5.60 x 13.60 Shipping Weight (kg) 5.08 UPS Housing Material PVC UPS Power Module Dimensions (hwd, in.) 5.6 x 4 x 11.8 UPS Power Module Weight (kg) 4.81 UPS Power Module Weight (lbs.) 10.6 Unit Weight (lbs.) 10.600 Unit Weight (kg) 4.81 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 45°C) Relative Humidity Up to 90%, non-condensing AC Mode BTU / Hr. (Full Load) 26 AC Mode Efficiency Rating (100% Load) 95% Operating Elevation (m) 0-2000m COMMUNICATIONS 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Network Management Card Description Network management not supported Communications Interface None LINE / BATTERY TRANSFER Transfer Time 6 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 170 High Voltage Transfer to Battery Power (Setpoint) 280 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Yes High Availability UPS Features Automatic Voltage Regulation (AVR); Surge/noise protection APPLICATIONS UPS Applications Home/Office Desktop STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); UKCA WARRANTY & SUPPORT Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 2-year limited warranty Product Warranty Period (Puerto Rico) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
OMNIVSX650 价格&库存
很抱歉,暂时无法提供与“OMNIVSX650”相匹配的价格&库存,您可以联系我们找货
