P006AB-025-HG
P006AB-025-HG
    TRIPPLITE
    25.00'(7.62m) 电源线 黑色 NEMA 5-15P 至 IEC 320-C13 SJT
P006AB-025-HG 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Safe-IT Antibacterial Hospital-Grade Power Cord, 5-15P to C13 - Green Dot, 13A, 125V, 16 AWG, Black, 25 ft. (7.6 m) Highlights ● Recommended for connecting devices to power outlets outside patient care vicinities ● Made with antibacterial material proven effective in inhibiting the growth of E. coli and staph ● 25 ft. length allows great flexibility in placing devices in relationship to AC outlet ● Tested to ANSI/UL 62 and 817 and CAN/CSA C22.2 no. 21 and 49 standards MODEL NUMBER: P006AB-025-HG Package Includes P006AB-025-HG Antibacterial Hospital-Grade Power Cord, 5-15P to C13, Black, 25 ft. (7.6 m) Hospital-grade power cord with antibacterial properties connects your PC or other device with a C14 inlet to a grounded AC outlet. Features Hospital-Grade Power Cable is a Safe Solution for Medical Facilities This Safe-IT™ hospital-grade IEC power cord is designed for computers, mobile carts, printers, scanners, monitors and other compatible hospital equipment with a three-pin C14 inlet. It features a C13 end for connecting to a device and a NEMA 5-15P-HG plug for connecting to a hospital-grade AC power source located outside patient care vicinities. The 25-foot (7.6-meter) length allows you great flexibility in placing equipment with respect to the power outlet. Provides Extra Protection Against Certain Bacteria The connectors and PVC jacket are constructed using an antibacterial material that is effective in inhibiting the growth of Escherichia coli (E. coli) and Staphylococcus aureus (staph). This added protection makes this cable an ideal solution for medical environments, such as hospitals, laboratories and clinics, and anywhere else that needs extra protection against bacteria. Designed and Tested to Strict Hospital-Grade Standards This cord is tested to ANSI/UL 62 and 817 standards, as well as CAN/CSA C22.2 no. 21 and 49 standards, ensuring it’s a dependable power solution for hospital environments. Specifications OVERVIEW UPC Code 037332266309 Device Compatibility Mobile Cart; Computer; Printer; Monitor/HDTV; Server; UPS; PDU Country/Region North America 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Maximum Input Amps 13 Voltage Compatibility (VAC) 125 PHYSICAL Plug Color Black Cable Jacket Color Black Connector Color Black Cable Jacket Material PVC Cable Jacket Rating FT2 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 8.25mm Number of Conductors 3 Wire Gauge (AWG) 16 Wire Gauge (OD - mm²) 1.31 Cable Length (ft.) 25 Cable Length (m) 7.62 ENVIRONMENTAL Operating Temperature Range -4° to 221°F (-20° to 105°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Operating Humidity Range 20% to 80% RH, Non-Condensing Storage Humidity Range 20% to 80% RH, Non-Condensing CONNECTIONS Side A - Connector 1 NEMA 5-15P Side B - Connector 1 IEC-320-C13 FEATURES & SPECIFICATIONS Antibacterial Yes Angled Plug No High Voltage No Locking Plug No Coiled Power Cord No STANDARDS & COMPLIANCE 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Certifications CSA (Canada); cUL Listed; UL Listed Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P006AB-025-HG 价格&库存
很抱歉,暂时无法提供与“P006AB-025-HG”相匹配的价格&库存,您可以联系我们找货
P006AB-025-HG
  • 1+326.700671+42.26372
  • 10+289.8072810+37.49100
  • 25+276.3180925+35.74597
  • 50+266.5382550+34.48079
  • 100+257.10491100+33.26045
  • 250+247.85920250+32.06437
库存:18
