1000 Eaton Boulevard
Cleveland, OH 44122
United States
Safe-IT Antibacterial Hospital-Grade Power Cord,
5-15P to C13 - Green Dot, 13A, 125V, 16 AWG,
Black, 8 ft. Coiled Cord (2.4 m)
Highlights
Recommended for connecting
devices to power outlets outside
patient care vicinities
Made with antibacterial material
proven effective in inhibiting the
growth of E. coli and staph
Coiled cord extends to 8 ft. to
allow flexibility in placing
devices away from AC outlet
NEMA 5-15P-HG plug connects
to AC power; C13 plug connects
to device’s C14 inlet
Tested to ANSI/UL 62 and 817
and CAN/CSA C22.2 no. 21 and
49 standards
MODEL NUMBER: P006AB-C08-HG
Package Includes
P006AB-C08-HG Antibacterial
Hospital-Grade Power Cord, 5-15P
to C13, Black, 8 ft. Coiled (2.4 m)
Hospital-grade power cord with antibacterial properties connects your PC or other device with a C14 inlet
to a grounded AC outlet.
Features
Hospital-Grade Power Cable is a Safe Solution for Medical Facilities
This Safe-IT™ hospital-grade IEC power cord is designed for computers, mobile carts, printers, scanners,
monitors and other compatible hospital equipment with a three-pin C14 inlet. It features a C13 end for
connecting to a device and a NEMA 5-15P-HG plug for connecting to a hospital-grade AC power source
located outside patient care vicinities. The eight-foot (2.4-meter) length allows you great flexibility in
placing equipment with respect to the power outlet.
Provides Extra Protection Against Certain Bacteria
The connectors and PVC jacket are constructed using an antibacterial material that is effective in
inhibiting the growth of Escherichia coli (E. coli) and Staphylococcus aureus (staph). This added
protection makes this cable an ideal solution for medical environments, such as hospitals, laboratories
and clinics, and anywhere else that needs extra protection against bacteria.
Coiled Power Cord Allows You Freedom of Movement
The durable coiled cord fully extends to eight feet, giving you more freedom in placing the connected
devices where they are most needed at any given time. The cord resists tangles and knots, returning to its
retracted length when not in use, and it takes up less space when stored in its coiled state.
Designed and Tested to Strict Hospital-Grade Standards
This cord is tested to ANSI/UL 62 and 817 standards, as well as CAN/CSA C22.2 no. 21 and 49
standards, ensuring it’s a dependable power solution for hospital environments.
Specifications
OVERVIEW
UPC Code
037332266293
Device Compatibility
Mobile Cart; Computer; Printer; Monitor/HDTV; Server; UPS; PDU
Country/Region
North America
1/3
Cleveland, OH 44122
United States
INPUT
Maximum Input Amps
13
Voltage Compatibility (VAC)
125
PHYSICAL
Plug Color
Black
Cable Jacket Color
Black
Connector Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
FT2
Power Cord Jacket Type
SJT
Cable Outer Diameter (OD)
8.25mm
Number of Conductors
3
Wire Gauge (AWG)
16
Wire Gauge (OD - mm²)
1.31
Cable Length (ft.)
8
Cable Length (m)
2.44
Coiled Length (ft.)
2.25
Uncoiled Length (ft.)
8.67
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
ENVIRONMENTAL
Operating Temperature Range
-4° to 221°F (-20° to 105°C)
Storage Temperature Range
-4° to 140°F (-20° to 60°C)
Operating Humidity Range
20% to 80% RH, Non-Condensing
Storage Humidity Range
CONNECTIONS
Side A - Connector 1
NEMA 5-15P
Side B - Connector 1
IEC-320-C13
FEATURES & SPECIFICATIONS
Antibacterial
Yes
Angled Plug
No
High Voltage
No
Locking Plug
No
2/3
Cleveland, OH 44122
United States
Coiled Power Cord
Yes
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); cUL Listed; UL Listed
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“P006AB-C08-HG”相匹配的价格&库存,您可以联系我们找货
