P022-015-13A15D
P022-015-13A15D
    TRIPPLITE
    15.00'(4.57m) 电源线 黑色 NEMA 5-15P,直角 至 NEMA 5-15R SJT
P022-015-13A15D 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Power Extension Cord, Right-Angle NEMA 5-15P to NEMA 5-15R - 13A, 120V, 16 AWG, 15 ft. (4.6 m), Black Highlights ● Recommended for powering computers, monitors and other essential peripherals ● Ideal for home/office applications, small server rooms and data centers ● Right-angle plug allows easier connection in confined or hardto-reach spaces ● Adds 15 ft. to your existing connection to provide more flexibility in placing devices ● Ideal replacement for worn-out or missing 15 ft. extension cord MODEL NUMBER: P022-015-13A15D Package Includes P022-015-13A15D Power Extension Cord, Right-Angle NEMA 5-15P to NEMA 5-15R, 15 ft. (4.6 m), Black 13-amp extension cord connects two devices with 5-15P/5-15R power connectors or extends your existing power connection. Features 15-Foot Extension Cord Connects Printers, Servers and Other Equipment This power extension cable is designed for small data center or office workstation applications that do not require a heavy-gauge connection. With a right-angle NEMA 5-15P plug on one end and a NEMA 5-15R receptacle on the other, this cord can be used to power a printer or monitor; attach a rack server to a UPS system or PDU; or extend an existing connection up to 15 feet (4.6 meters). The 15-foot length allows you great flexibility in placing equipment with respect to the power outlet. Right-Angle Plug Makes Connecting in Tight Spaces Easier The space-saving right-angle NEMA 5-15P connector is easy to install in confined spaces, such as behind your computer desk or workstation. The right-angle construction also relieves strain on the cable and connector and prevents the cable from bending awkwardly. Specifications OVERVIEW UPC Code 037332275240 Device Compatibility Computer; Monitor/HDTV; Printer; Server; UPS; PDU Country/Region North America INPUT Maximum Input Amps 13 Voltage Compatibility (VAC) 125 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Plug Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating FT2 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 8.3 mm Number of Conductors 3 Wire Gauge (AWG) 16 Wire Gauge (OD - mm²) 1.31 Cable Length (ft.) 15 Cable Length (m) 4.57 Shipping Dimensions (hwd / in.) 14.17 x 11.80 x 0.50 Shipping Dimensions (hwd / cm) 35.99 x 29.97 x 1.27 Shipping Weight (lbs.) 1.05 Shipping Weight (kg) 0.48 ENVIRONMENTAL Operating Temperature Range -4° to 140°F (-20° to 60°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Operating Humidity Range 20% TO 80% RH, Non-Condensing Storage Humidity Range 20% to 80% RH, Non-Condensing CONNECTIONS Side A - Connector 1 NEMA 5-15P - RIGHT ANGLE Side B - Connector 1 NEMA 5-15R FEATURES & SPECIFICATIONS Antibacterial No Angled Plug Yes High Voltage No Locking Plug No Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL Listed 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P022-015-13A15D 价格&库存
很抱歉,暂时无法提供与“P022-015-13A15D”相匹配的价格&库存,您可以联系我们找货
