P035-010
P035-010
    TRIPPLITE
    10.00'(3.05m) 电源线 黑色 IEC 320-C20 至 IEC 320-C21 SJT
P035-010 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Power Cord, C20 to C21 - Heavy-Duty, 20A, 250V, 12 AWG, 10 ft. (3.05 m), Black MODEL NUMBER: P035-010 Highlights ● Recommended for powering switches, routers and other high-powered network devices ● 10 ft. (3.05 m) length allows great flexibility in placing devices in relationship to AC outlet ● C20 to C21 cord replaces or upgrades standard power cord provided by manufacturer ● Thick 12 AWG wire manages high power levels required for larger equipment Package Includes P035-010 Power Cord, C20 to C21, 10 ft. (3 m), Black C20 to C21 20A heavy-duty cable connects high-output devices with C19/C22 power connectors commonly found on high-powered IT equipment. Features 20A C20-to-C21 Power Cable for Network Devices That Require a Heavy-Gauge Connection This heavy-duty cord features 12 AWG wire suitable for high power connections, making it a reliable solution for large server applications that require a higher-rated, heavier-gauge cable. This cord can be used to connect a blade server, large router or network switch with a C22 inlet, usually found on highpowered, high-temperature (maximum pin 155°C/311°F) equipment, to a PDU or UPS system. It’s an ideal choice for upgrading or replacing the standard power cord provided by the device’s manufacturer. The 10-foot (3-meter) length allows you great flexibility in placing equipment with respect to the power outlet. Specifications OVERVIEW UPC Code 037332275011 Device Compatibility Network Switch; PDU; UPS Country/Region North America INPUT Maximum Input Amps 20 Voltage Compatibility (VAC) 250 PHYSICAL Color Black 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Plug Color Black Cable Jacket Color Black Connector Color Black Cable Jacket Material PVC Cable Jacket Rating FT2; VW-1 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 11mm Number of Conductors 3 Wire Gauge (AWG) 12 Wire Gauge (OD - mm²) 3.31 Cable Length (ft.) 10 Cable Length (m) 3.05 Cable Length (in.) 120 Shipping Dimensions (hwd / in.) 1.00 x 9.00 x 12.75 Shipping Dimensions (hwd / cm) 2.54 x 22.86 x 32.38 Shipping Weight (lbs.) 1.58 Shipping Weight (kg) 0.72 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 ENVIRONMENTAL Operating Temperature Range -4° to 140°F (-20° to 60°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Operating Humidity Range 10% to 65% RH, Non-Condensing Storage Humidity Range 10% to 65% RH, Non-Condensing CONNECTIONS Side A - Connector 1 IEC-320-C20 Side B - Connector 1 IEC-320-C21 FEATURES & SPECIFICATIONS Antibacterial No Angled Plug No High Voltage Yes Locking Plug No Coiled Power Cord No STANDARDS & COMPLIANCE 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Certifications cUL Listed; UL Listed Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P035-010 价格&库存
很抱歉,暂时无法提供与“P035-010”相匹配的价格&库存,您可以联系我们找货
