P036-015-15A
P036-015-15A
    TRIPPLITE
    15.00'(4.57m) 电源线 黑色 IEC 320-C19 至 IEC 320-C20 SJT
P036-015-15A 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Power Extension Cord, C19 to C20 - Heavy-Duty, 15A, 250V, 14 AWG, 15 ft. (4.6 m), Black MODEL NUMBER: P036-015-15A Highlights ● Recommended for powering servers, routers and other highoutput network devices ● 15 ft. length allows great flexibility in placing devices in relationship to AC outlet ● C20 to C19 cord replaces or upgrades standard power cord provided by manufacturer ● Thick 14 AWG wire gauge supports high power levels required for larger equipment Package Includes P036-015-15A C19 to C20 HeavyDuty Extension Cord, 15 ft. (4.6 m), Black C19 to C20 15A heavy-duty extension cable connects high-output devices with C19/C20 power connectors, including blade server chassis. Features 15A C20-to-C19 Power Cable for Network Devices That Require a Heavy-Gauge Connection This heavy-duty extension cord features 14 AWG wire suitable for high power connections, making it a reliable solution for large server applications that require a higher-rated, heavier-gauge cable. This cord can be used to connect a server, router, network switch or blade server enclosure to a UPS system or PDU. It can also replace or upgrade the standard power cord provided by the device’s manufacturer. The 15-foot (4.6-meter) length allows you great flexibility in placing equipment with respect to the power outlet. Specifications OVERVIEW UPC Code 037332266811 Device Compatibility Server; Router; Network Switch; UPS; PDU Country/Region North America INPUT Maximum Input Amps 15 Voltage Compatibility (VAC) 250 PHYSICAL Plug Color Black Cable Jacket Color Black Cable Jacket Material PVC 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Rating FT2; VW-1 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 9.3mm Number of Conductors 3 Wire Gauge (AWG) 14 Wire Gauge (OD - mm²) 2.08 Cable Length (ft.) 15 Cable Length (m) 4.57 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 ENVIRONMENTAL Operating Temperature Range -4° to 140°F (-20° to 60°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 10% to 65% RH, Non-Condensing CONNECTIONS Side A - Connector 1 IEC-320-C20 Side B - Connector 1 IEC-320-C19 FEATURES & SPECIFICATIONS Antibacterial No Angled Plug No High Voltage Yes Locking Plug No Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL Listed Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P036-015-15A 价格&库存
很抱歉,暂时无法提供与“P036-015-15A”相匹配的价格&库存,您可以联系我们找货
