P136-06N-HVV2BP
P136-06N-HVV2BP
    TRIPPLITE
    DISPLAYPORT 1.2 TO VGA/HDMI ALL-
P136-06N-HVV2BP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DisplayPort to VGA/HDMI All-in-One Converter Adapter, DP ver 1.2, 4K 30 Hz HDMI, 50 Pack MODEL NUMBER: P136-06N-HVV2BP Highlights ● 50-piece bulk pack of P13606N-HV-V2 DisplayPort 1.2 converter adapters ● HDMI port delivers UHD picture quality at 4K resolutions up to 3840 x 2160 @ 24/30 Hz ● VGA port supports HD video resolutions up to 1920 x 1200, including 1080p ● Compact unit fits easily into pocket, briefcase or laptop bag for use anywhere ● Plug-and-play operation with no software required for easy, immediate installation Applications ● Play video from your DP laptop or PC on a large display, such as an HDTV ● Access documents and websites across multiple displays ● Design and edit graphics files or production video on a larger monitor ● Using a DisplayPort laptop to deliver presentations in a classroom or conference room ● Display menus, ads, promos, directions and other digital signage applications on an HD monitor Passive adapter connects your DisplayPort (DP) computer to a VGA or HDMI display for playing 4K video without separate adapters. Features A Smart Solution for Displaying 4K Video in Business and Digital Signage ApplicationsThis set includes 50 P136-06N-HV-V2 DisplayPort 1.2 to VGA/HDMI passive adapters. Each adapter allows you to play high-definition or Ultra High Definition video with audio from your DisplayPort computer to a VGA or HDMI display. No more carrying around separate adapters for various monitors, projectors and televisions. The simple all-in-one solution for displaying content on a larger screen, these units are an easy, inexpensive way to play high-quality video in classrooms, conference rooms, trade shows and other on-the-road presentations. Ready to Use Right Out of the PackageIdeal for displaying video on a large monitor or digital sign, each adapter is perfectly sized for carrying in your pocket, briefcase, purse or laptop bag for convenient use anywhere. Just connect the male DP end to your computer’s DisplayPort and the female VGA or HDMI connector to a compatible cable to begin sharing audio/video signals. Only one display may be connected at a time. The plug-and-play P136-06N-HV-V2 requires no software, drivers or external power. Enjoy Outstanding Picture Quality up to 4K x 2KThe all-in-one unit contains separate female HD15 and HDMI ports. It supports video resolutions up to 1920 x 1200, including 1080p (HD15), and 4K x 2K (HDMI) at 24/30 Hz. System Requirements ● Source device with DisplayPort output and DP++ port for HDMI pass-through (must support audio to transmit audio signals) ● Display device with VGA or HDMI input Package Includes Passive Adapters Require DisplayPort++ for HDMI Pass ThroughBecause they are passive adapters, these units require that the connected source device have a DisplayPort++ (DP++) dual-mode port, which allows HDMI signals to pass through. Check your DisplayPort source’s documentation for compatibility. Specifications OVERVIEW 1/3 ● (50) P136-06N-HV-V2 DisplayPort 1.2 to VGA/HDMI All-in-One Converter Adapters ● Quick Start Guide 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332237675 Product Type Video Adapter Technology HDMI; DisplayPort; VGA/SVGA VIDEO Max Supported Video Resolution HDMI: 3840 x 2160 (4K) @ 30Hz; VGA: 1920 x 1200 @ 60Hz INPUT Product Length (in.) 5.9 Product Length (ft.) 0.49 PHYSICAL Color Black Material of Construction ABS, PVC Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 4.5mm Shipping Dimensions (hwd / in.) 4.50 x 16.00 x 18.00 Shipping Weight (kg) 2.27 Unit Dimensions (hwd / in.) 2.360 x 0.550 x 1.570 Unit Weight (lbs.) 0.1 Unit Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range 14° to 176°F (-10° to 80°C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 DISPLAYPORT (MALE) Side B - Connector 1 HD15 (FEMALE) Side B - Connector 2 HDMI (FEMALE) Connector Plating Nickel Contact Plating Gold; Nickel FEATURES & SPECIFICATIONS 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States HDCP Specification 1.4 Driver Required No STANDARDS & COMPLIANCE Product Compliance CE (Europe); FCC (USA); REACH; RoHS; UKCA; WEEE WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P136-06N-HVV2BP 价格&库存
很抱歉,暂时无法提供与“P136-06N-HVV2BP”相匹配的价格&库存,您可以联系我们找货
