P164-000-KPBK8K
P164-000-KPBK8K
    TRIPPLITE
    插件 HDMI 插座 转 HDMI 插座 黑色
P164-000-KPBK8K 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States HDMI Keystone/Panel-Mount Coupler (F/F) - 8K 60 Hz, Black MODEL NUMBER: P164-000-KPBK8K Highlights ● Supports UHD resolutions up to 8K @ 60 Hz (4:4:4) for heightened video quality ● Supports High Dynamic Range (HDR) for richer contrast and expanded color accuracy ● Gold-plated connectors and contacts for maximum conductivity and minimum data loss ● Keystone coupler includes panel-mount adapter for securing to a podium or kiosk ● Designed for 8K cabling, but backward compatible with previous HDMI generations System Requirements 8K equipment and cables required to achieve 8K resolutions Snaps into a wall plate or panel to connect two HDMI cables and create one longer connection with no drop-off in video quality. Features Extend Your HDMI Connection Without Buying a Longer Cable This HDMI coupler (F/F) extends your 8K audio/video application by connecting two 8K-capable HDMI cables to create one longer connection. The keystone coupler features molded gold-plated connectors to ensure top signal transfer. It is compatible with all HDMI cables, so you can use the coupler with older equipment, but 8K cables are necessary to achieve 8K resolutions. Enjoy the Clarity of 8K Video with HDR and 4:4:4 Color The P164-000-8K6 supports Ultra HD 8K video resolutions up to 7680 x 4320 at 60 Hz with 36-bit Deep Color. High Dynamic Range (HDR) provides a wide range of vibrant colors with richer contrast, brighter whites and deeper blacks that pop on your 4K or 8K display. HDCP 2.2 compliance allows you to stream 4K Amazon and Netflix content with no complications. This coupler also supports 4:4:4 chroma subsampling for top-level PC gaming or using your HDTV as a PC monitor. Comes with Versatile Installation Options The HDMI coupler’s keystone design snaps easily into a wall plate or panel cutout. An optional panel mount adapter is included for installing the coupler on a podium or kiosk. Specifications OVERVIEW UPC Code 037332269584 Technology HDMI VIDEO Max Supported Video Resolution 7680 x 4320 (8K) @ 60Hz 1/3 Package Includes P164-000-KPBK8K HDMI Keystone/Panel-Mount Coupler (F/F) 1000 Eaton Boulevard Cleveland, OH 44122 United States Max Supported Color Depth 36-bit Deep Color HDR Support Yes 3D Video Supported No Chroma Sub Sampling 4:4:4 PHYSICAL Color Black Material of Construction PVC, ABS Unit Dimensions (hwd / in.) 0.580 x 0.640 x 1.140 Unit Dimensions (hwd / mm) 14.7 x 16.3 x 29 Unit Packaging Type Polybag Unit Weight (lbs.) 0.03 Unit Weight (kg) 0.01 ENVIRONMENTAL Operating Temperature Range 14° to 122°F (-10° to 50°C) Storage Temperature Range 5° to 140°F (-15° to 60°C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 HDMI (FEMALE) Side B - Connector 1 HDMI (FEMALE) Contact Plating Gold FEATURES & SPECIFICATIONS IP68 Rated No IP20 Rated No HDCP Specification 1.4; 2.2 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH; Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P164-000-KPBK8K 价格&库存
很抱歉,暂时无法提供与“P164-000-KPBK8K”相匹配的价格&库存,您可以联系我们找货
P164-000-KPBK8K
  • 1+135.231441+17.49426
