P567-01M
P567-01M
    TRIPPLITE
    缆线组件 HDMI-A 公头转 DisplayPort 公头和 USB A 公头 3.28'(1.00m)
P567-01M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States HDMI to DisplayPort Active Adapter Cable (M/M) 4K, USB Power, Black, 1 m (3.3 ft.) MODEL NUMBER: P567-01M Highlights ● Supports UHD resolutions up to true 4K @ 30 Hz (4:4:4) for crystal-clear video ● Ideal for lectures, presentations, trade shows, digital signage and home theaters ● Bus-powered through USB connection to source; USB-A connector included ● Works with all HDMI sources and all major operating systems, including Windows ● Plug-and-play operation with no software required for easy, immediate installation Applications Connects a DisplayPort monitor or projector to the HDMI port on your Blu-ray player, computer, media server or other A/V source. Features Active Adapter Cable Connects a 4K Monitor to Your Computer or Media Server This all-in-one video converter cable lets you transmit 4K video with digital audio from the HDMI port on your Blu-ray player, satellite/cable box, computer or media server to your 4K DisplayPort-enabled monitor, projector or television. It’s recommended for home theater systems, digital signage, trade show displays and conference room presentations. You can continue using your existing DisplayPort monitor without the expense of a new HDMI display to match your source device. Transmits Crystal-Clear True 4K Video with Audio and 4:4:4 Color The P567-01M supports Ultra HD video resolutions up to 4096 x 2160 (4K x 2K) at 30 Hz with rich, full 7.1-channel surround sound, 36-bit Deep Color, HDCP 1.4 and 4:4:4 chroma subsampling for top-level PC gaming or using your HDTV as a PC monitor. Additionally, this cable transmits EDID information to ensure optimal display compatibility. Ready to Use Right from the Package, So You Can Plug and Play Immediately The plug-and-play cable requires no drivers or external power. The bus-powered cable receives any necessary extra power from the source device via the included USB-A connector. It is compatible with all HDMI sources and all major operating systems, including Windows, macOS and Linux. It is backward compatible with 1080p displays, so you can use the cable with older equipment. Specifications OVERVIEW UPC Code 037332261144 Product Type Active Cable Technology HDMI; DisplayPort Cable Type Active 1/3 ● Stream 4K movies and other programming from a Blu-ray player, game system or cable box to an HDTV ● Add a second monitor to your PC for multitasking purposes or editing video ● Upgrade the video quality of your digital signage to true 4K System Requirements ● Source device with HDMI output (Blu-ray player, computer, media server, etc.) ● Display device with DisplayPort input (monitor, television, projector, etc.) Package Includes ● P567-01M HDMI to DisplayPort 1.2 Active Adapter Cable, Black, 1 m (3.3 ft.) ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States VIDEO Max Supported Video Resolution 4096 x 2160 (4K) @ 30Hz Max Supported Color Depth 36-bit Deep Color HDR Support No Chroma Sub Sampling 4:4:4 AUDIO Audio Specification 7.1 Channel Surround Sound INPUT Bus Powered Yes PHYSICAL Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 6.0mm Wire Gauge (AWG) 30 Cable Length (ft.) 3.3 Cable Length (m) 1.01 Cable Length (in.) 39.6 Shipping Dimensions (hwd / in.) 0.91 x 6.50 x 5.32 Shipping Weight (kg) 0.07 ENVIRONMENTAL Operating Temperature Range 32° to 158°F (0° to 70°C) Storage Temperature Range 14° to 176°F (-10° to 80°C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing Power Provided to Connected Device(s) USB-A: 5V/0.5A (2.5W) COMMUNICATIONS EDID Compatible Yes CONNECTIONS 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Side A - Connector 1 HDMI (MALE) Side B - Connector 1 DISPLAYPORT (MALE); USB A (MALE) Connector Plating Gold Contact Plating Gold FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection Yes IP68 Rated No IP20 Rated No Fully Molded Connector Ends No Displayport Specification 1.2 HDCP Specification 1.4 Driver Required No STANDARDS & COMPLIANCE Product Compliance CE (Europe); FCC (USA); REACH; RoHS; UKCA; WEEE WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P567-01M 价格&库存
很抱歉,暂时无法提供与“P567-01M”相匹配的价格&库存,您可以联系我们找货
