P568-50M-FBR
P568-50M-FBR
    TRIPPLITE
    缆线组件 164.0'(50.00m)
P568-50M-FBR 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4K HDMI Fiber Active Optical Cable (AOC) - 4K 60 Hz, HDR, 4:4:4 (M/M), 50 m MODEL NUMBER: P568-50M-FBR Highlights ● Supports UHD resolutions up to 4K (4:4:4) for crystal-clear video ● Carries High Dynamic Range (HDR) signals for rich contrast and expanded color accuracy ● Fiber optic strands transmit audio/video over longer distances than standard copper ● Dispels EMI/RFI line noise that can disrupt A/V signal and affect equipment performance ● Plug-and-play cable draws power from connected device for easy, immediate installation Applications ● Watch 4K video content from a Blu-ray player, game console, laptop or tablet on an Ultra HD television, monitor or projector ● Connect a Chromebook or MacBook to a conference table’s A/V box to give a video presentation on a large screen ● Send Ultra HD content to digital signs or point-of-sale displays ● Connect security cameras and other A/V surveillance equipment to a central display Fiber HDMI cable creates crystal-clear 4K video/audio connections with 4:4:4 color for home theaters and digital signage. Features 4K HDMI Cable Connects Home Theater, Gaming & Digital Signage Components This 4K HDMI cable securely connects HDMI-enabled laptops, tablets, PCs, Blu-ray players, game consoles or satellite/cable TV boxes to HDTVs, HD monitors, projectors or home theater receivers. Because the cable uses optical fiber, it can transmit HDMI signals longer distances with no latency or loss. It also eliminates any EMI/RFI line noise that can interfere with your audio/video signal and disrupt the performance of your connected equipment. Package Includes ● Enjoy the Clarity of 4K HDMI Video with Multi-Channel Audio, HDR and 4:4:4 Color This HDMI cable supports Ultra HD video resolutions up to 4K for crystal-clear picture and sound. High Dynamic Range (HDR) provides a wide range of vibrant colors with richer contrast, brighter whites and deeper blacks that pop on your 4K display. It also supports 4:4:4 chroma subsampling for top-level PC gaming or using your HDTV as a PC monitor, as well as 3D, 48-bit Deep Color, DTS-HD Master Audio and Dolby True HD. Advanced Fiber Cable Is Easier to Install than Copper Because the fiber cable is slimmer and more flexible than standard copper HDMI cables, the P568-50MFBR is easier to install around corners and in hard-to-reach spaces behind equipment. It draws power from the connected device, so no external power supply is needed to transmit the HDMI signal across the longer distances unique to fiber optic cabling. Note: The cable must be installed in the correct direction to function properly, so check the Source and Display labels on the connectors before installation. Specifications OVERVIEW UPC Code 037332236876 Product Type Active Optical Cable (AOC) Technology HDMI 1/4 P568-50M-FBR High-Speed HDMI Fiber Active Optical Cable, M/M, Black, 50 m (164 ft.) 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Type Active VIDEO Video Input HDMI (MALE) Video Output HDMI (MALE) Max Supported Video Resolution 3840 x 2160 (4K) @ 60Hz Max 1280 x 720 (720p) Range (ft) 164 Max 1920 x 1080 (1080p) Range (ft) 164 Max 1920 x 1200 Range (ft) 164 Max 2560 x 1600 Range (ft) 164 Max 3840 x 2160 (4K@30Hz) Range (ft) 164 Max 3840 x 2160 (4K@60Hz) Range (ft) 164 Max Supported Color Depth 48-bit Deep Color HDR Support Yes 3D Video Supported Yes Chroma Sub Sampling 4:4:4 Maximum Signal Range (ft) 164 Maximum Signal Range (m) 50 EDID Support Yes Signal Transmission Bidirectional AUDIO Audio Specification Stereo Audio INPUT Bus Powered No POWER Power Over Cable (PoC) Support No USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Black Cable Jacket Color Black Connector Color Silver 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 4.8 mm Wire Gauge (AWG) 30 Cable Length (ft.) 164 Cable Length (m) 50.00 Cable Length (in.) 1968 Ferrite Core No Minimum Bend Radius 48mm Number of Displays 1 Form Factor/Mounting Options Cable Shipping Dimensions (hwd / in.) 3.45 x 6.50 x 6.50 Shipping Weight (lbs.) 3.80 Shipping Weight (kg) 1.72 ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range -40° to 176°F (-40° to 80°C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing COMMUNICATIONS EDID Compatible No IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No 10/100 Ethernet Extension Support No MST Support No Built-In Equalizer No Antibacterial No IP68 Rated No IP20 Rated No Armored Cable No Ethernet Support Yes HDCP Specification 2.2; 1.4 Driver Required No STANDARDS & COMPLIANCE Product Compliance CE (Europe); FCC (USA); REACH; RoHS; UKCA; WEEE WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
P568-50M-FBR 价格&库存
很抱歉,暂时无法提供与“P568-50M-FBR”相匹配的价格&库存,您可以联系我们找货
P568-50M-FBR
    库存:1
