1000 Eaton Boulevard
Cleveland, OH 44122
United States
DisplayPort 1.4 Cable with Latching Connectors,
8K (M/M), Black, 1 ft. (0.31 m)
MODEL NUMBER: P580-001-V4
Highlights
Supports UHD resolutions up to
8K @ 30 Hz (4:2:0) for
enhanced video without latency
Supports High Dynamic Range
(HDR) for richer contrast and
expanded color accuracy
Latching DisplayPort connectors
prevent cable from coming loose
accidentally
Plug-and-play operation with no
software required for easy,
immediate installation
Applications
Watch 8K video from a
compatible Blu-ray player, game
console, laptop or tablet on a
compatible television, monitor or
projector
8K DisplayPort cable connects your DisplayPort 1.4-compatible source and display devices to transmit
enhanced 8K UHD audio/video with HDR.
Connect a Windows laptop to a
conference table’s A/V box to
give a video presentation on a
large screen
Play online or PC video games
that display optimal graphics
Features
Send 8K video content to digital
signs or point-of-sale displays
DisplayPort 1.4 Cable Gets Your Gaming, Home Theater or Digital Signage Setup 8K-ReadyThis
high-speed DisplayPort cable (M/M) securely connects source and display devices compatible with
DisplayPort 1.4 audio/video signals. Backward compatible with all your existing DisplayPort devices,
including Blu-ray players, game consoles and 4K televisions, the P580-001-V4 is ideal for future-proofing
your high-definition or UHD A/V application in anticipation of an 8K upgrade. It flawlessly handles data
transfer speeds up to 32 Gbps.
Enjoy the Clarity of 4K/8K Video with 4:2:0 ColorThe P580-001-V4 supports 8K UHD video resolutions
up to 7680 x 4320 at 30 Hz. It’s compatible with DisplayPort 1.4 standards for carrying HDR signals, which
provide a wide range of vibrant colors with richer contrast, brighter whites and deeper blacks. HDCP 2.2
compliance and 4:2:0 chroma subsampling allow you to stream 4K Amazon and Netflix content with no
complications.
Latching Connectors Help Prevent Accidental Disconnection and Expensive DowntimeHaving a
cable come loose accidentally can mean costly and time-consuming signal loss. The latching DisplayPort
connectors help you avoid such danger, protecting your audio/video transmission by maintaining a secure
link without failure. The latching cable is also invaluable when moving equipment in a rack or removing
equipment from tight areas, ensuring the cord always stays connected.
Specifications
OVERVIEW
UPC Code
037332255105
Product Type
Passive Cable
Technology
DisplayPort
Cable Type
Passive
1/4
System Requirements
Both source and display devices
must be compatible with 8K
standards to watch 8K video
Package Includes
P580-001-V4 DisplayPort 1.4
8K, M/M, Black, 1 ft.
Cleveland, OH 44122
United States
VIDEO
Max Supported Video Resolution
7860 x 4320 (8K) @ 30Hz
Max Supported Color Depth
36-bit Deep Color
HDR Support
Yes
3D Video Supported
Yes
Chroma Sub Sampling
4:2:0
Signal Transmission
Bidirectional
INPUT
Bus Powered
Yes
PHYSICAL
Color
Black
Material of Construction
PVC, ABS
Cable Jacket Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
4.8 mm
Wire Gauge (AWG)
32
Cable Length (ft.)
1
Cable Length (m)
0.30
Cable Length (in.)
12
Ferrite Core
No
Minimum Bend Radius
48mm
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Weight (kg)
0.04
ENVIRONMENTAL
Operating Temperature Range
32° to 113°F (0° to 45°C)
Storage Temperature Range
-40° to 158°F (-40° to 70°C)
Operating Humidity Range
10% to 85% RH, Non-Condensing
Storage Humidity Range
5% to 90% RH, Non-Condensing
COMMUNICATIONS
EDID Compatible
Yes
Consumer Electronics Control (CEC)
Supported
No
2/4
Cleveland, OH 44122
United States
CONNECTIONS
Side A - Connector 1
DISPLAYPORT (MALE)
Side B - Connector 1
DISPLAYPORT (MALE)
Connector Plating
Nickel
Contact Plating
Gold
Connector Style
Straight
Latching or Gripping Connector
Yes
FEATURES & SPECIFICATIONS
EMI/RFI Line Noise Protection
Yes
Integrated/Removable Cable
No
MST Support
Yes
Antibacterial
No
IP68 Rated
No
IP20 Rated
No
Fully Molded Connector Ends
No
Ohms
No
Integral Strain Relief
No
Impedance-Matched Twisted-Pair
Construction
No
Scaler Function
No
IP67 Rated
No
Armored Cable
No
Ethernet Support
No
Displayport Specification
1.4
HDCP Specification
2.2
DIN Mountable
No
STANDARDS & COMPLIANCE
Product Certifications
IEC/EN 62040
Product Compliance
CE (Europe); FCC (USA); REACH; RoHS; UKCA; WEEE
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
3/4
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“P580-001-V4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+183.171661+23.72714
- 10+155.6895210+20.16724
- 25+145.9395525+18.90428
- 50+138.9742550+18.00203
- 100+132.34366100+17.14314
- 250+124.06533250+16.07080
- 500+118.15195500+15.30481
