P568F-10M-8K6
P568F-10M-8K6
    TRIPPLITE
    缆线组件 32.8'(10.00m)
P568F-10M-8K6 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 8K HDMI Plenum-Rated Fiber Active Optical Cable (AOC) - 8K UHD @ 60 Hz, HDR, M/M, Black, 10 m (33 ft.) Highlights ● Supports UHD resolutions up to 8K @ 60 Hz (4:4:4) for heightened video quality ● Carries Dynamic HDR signals for rich contrast and expanded color accuracy ● Fiber optic strands transmit audio/video over longer distances than standard copper ● Dispels EMI/RFI line noise that can disrupt A/V signal and affect equipment performance ● Plenum rated for horizontal premise applications in air ducts and drop ceilings MODEL NUMBER: P568F-10M-8K6 Applications ● Watch 8K video from a compatible Blu-ray player, game console, laptop or tablet on a compatible television, monitor or projector ● Connect a Windows laptop to a conference table’s A/V box to give a video presentation on a large screen ● Play online or PC video games that display optimal graphics ● Send 8K video content to digital signs or point-of-sale displays ● Connect security cameras and other A/V surveillance equipment to a central display 8K fiber cable transmits enhanced UHD 8K video with Dynamic HDR and 4:4:4 color in home theater and digital signage applications. Features HDMI Cable Helps Your Gaming, Home Theater or Digital Signage Setup Get 8K-Ready This HDMI cable (M/M) securely connects laptops, tablets, PCs, Blu-ray players, game consoles or satellite/cable TV boxes to HDTVs, HD monitors, projectors or home theater receivers. Because the cable uses optical fiber, it can transmit HDMI signals longer distances with no latency or loss. It also eliminates any EMI/RFI line noise that can interfere with your audio/video signal and disrupt the performance of your connected equipment. Enjoy the Clarity of 8K Video with 7.1-Channel Surround Sound and 4:4:4 Color The P568F-10M-8K6 supports UHD 8K video resolutions and Dolby 7.1-channel surround sound. It supports Dynamic HDR, which maintains premium contrast and color in each scene or even each frame. HDCP 2.3 compliance allows you to stream the latest 4K Amazon and Netflix content with no complications. This cable also supports 4:4:4 chroma subsampling for top-level PC gaming or using your HDTV as a PC monitor. Take Advantage of the Most Advanced HDMI Features for Premier Picture Quality This 8K-ready cable allows your compatible hardware to deliver up-to-date HDMI features, such as eARC (enhanced Audio Return Channel), which passes full-resolution surround sound signals to your speakers without compressing them. QMS (Quick Media Switching) switches from one frame rate to another without the delay of a blank screen between them. ALLM (Auto Low Latency Mode), VRR (Variable Refresh Rate) and QFT (Quick Frame Transport) reduce latency, refresh rate and lag for a more vivid gaming experience. Advanced Fiber Cable Is Easier to Install than Copper Because the fiber cable is slimmer and more flexible than standard copper HDMI cables, the P568F-10M8K6 is easier to install around corners and in hard-to-reach spaces behind equipment. It draws power from the connected device, so no external power supply is needed to transmit the HDMI signal across the longer distances unique to fiber optic cabling. Note: the cable must be installed in the correct direction to function properly, so please check the Source and Display labels on the connectors before installation. Invest in Quality Construction for Reliable Performance You’re expecting this 8K cable to last a long time, which is why it has been constructed with high-quality 1/4 System Requirements ● Both source and display devices must be compatible with HDMI 2.1 standards to access HDMI 2.1 features ● Both source and display devices must be compatible with 8K standards to watch 8K video Package Includes P568F-10M-8K6 HDMI Fiber Active Optical Cable, M/M, Black, 10 m (33 ft.) 1000 Eaton Boulevard Cleveland, OH 44122 United States materials. Contacts are gold-plated to resist corrosion. Double shielding reduces line noise (EMI/RFI) that can disrupt signals traveling through the HDMI cord. The plenum-rated jacket has low smoke and flame characteristics, making it suitable for premise applications in ceilings, walls and ducts. Specifications OVERVIEW UPC Code 037332260932 Product Type Active Optical Cable (AOC) Technology HDMI VIDEO Video Input HDMI (MALE) Video Output HDMI (MALE) Max Supported Video Resolution 7680 x 4320 (8K) @ 60Hz Max 1280 x 720 (720p) Range (ft) 33 Max 1920 x 1080 (1080p) Range (ft) 33 Max 1920 x 1200 Range (ft) 33 Max 2560 x 1600 Range (ft) 33 Max 3840 x 2160 (4K@30Hz) Range (ft) 33 Max 3840 x 2160 (4K@60Hz) Range (ft) 33 Max 4096 x 2160 (4K) Range (ft) 33 Max 5120 x 2880 (5K) Range (ft) 33 Max 7680 x 4320 (8K@30Hz) Range (ft) 33 Max 7680 x 4320 (8K@60Hz) Range (ft) 33 Signal Range (ft) 33 Signal Range (m) 10 Max Supported Color Depth 48-bit HDR Support Yes 3D Video Supported Yes Chroma Sub Sampling 4:4:4 Maximum Signal Range (ft) 33 Maximum Signal Range (m) 10 Signal Transmission Unidirectional 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Bus Powered No POWER Power Over Cable (PoC) Support No PHYSICAL Color Black Material of Construction PVC Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating CMP Cable Outer Diameter (OD) 4.5 mm Cable Length (ft.) 33 Cable Length (m) 10.06 Cable Length (in.) 396 Ferrite Core Yes Number of Displays 1 Form Factor/Mounting Options Cable Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 ENVIRONMENTAL Operating Temperature Range 32° to 122°F (0° to 50°C) Storage Temperature Range -40° to 158°F (-40° to 70°C) Operating Humidity Range 10% to 80% RH, Non-Condensing Storage Humidity Range 10% to 80% RH, Non-Condensing COMMUNICATIONS EDID Compatible No IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported No CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 HDMI (MALE) 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Contact Plating Gold Latching or Gripping Connector No FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection Yes 10/100 Ethernet Extension Support No Antibacterial No IP68 Rated No IP20 Rated No Armored Cable No Driver Required No STANDARDS & COMPLIANCE Product Compliance CE (Europe); FCC (USA); REACH; RoHS; UKCA; WEEE WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
P568F-10M-8K6 价格&库存
很抱歉,暂时无法提供与“P568F-10M-8K6”相匹配的价格&库存,您可以联系我们找货
