P580-003-8K6
P580-003-8K6
    TRIPPLITE
    缆线组件 3.00'(914.40mm)
P580-003-8K6 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DisplayPort Cable with Latching Connectors (M/M), 8K 60 Hz, HDR, HBR3, 4:4:4, HDCP 2.2, Black, 3 ft. (0.9 m) Highlights ● Supports UHD resolutions up to 8K @ 60 Hz (4:4:4) for state-ofthe-art video quality ● Carries High Dynamic Range (HDR) signals for rich contrast and expanded color accuracy ● Complies with HDCP 2.2 standards to display up-to-date 4K video content ● Plug-and-play operation with no software required for easy, immediate installation MODEL NUMBER: P580-003-8K6 System Requirements Both source and display devices must be compatible with 8K standards to watch 8K video Package Includes P580-003-8K6 DisplayPort 1.4 Cable (M/M), 8K 60 Hz, Black, 3 ft. (0.9 m) 8K DisplayPort cable connects your source and display devices to transmit enhanced 8K Ultra HD audio/video with HDR and 4:4:4 chroma. Features DisplayPort 1.4 Cable Gets Your Gaming, Home Theater or Digital Signage Setup 8K-Ready This high-speed DisplayPort (DP) cable (M/M) securely connects source and display devices compatible with DP 1.4 audio/video signals. Backward compatible with all your existing DisplayPort devices, including Blu-ray players, game consoles and 4K televisions, the P580-003-8K6 is ideal for future-proofing your high-definition or Ultra HD application in anticipation of an 8K upgrade. Enjoy the Clarity of 4K/8K Video with Multi-Channel Audio and 4:4:4 Color The P580-003-8K6 supports 8K UHD resolutions up to 7680 x 4320 at 60 Hz with multi-channel sound. It’s compatible with DisplayPort 1.4 standards for HDR, providing a wide range of vibrant colors with richer contrast, brighter whites and deeper blacks. HDCP 2.2 compliance allows you to stream 4K content with no complications. This BT.2020-compatible cable also supports 4:4:4 chroma subsampling for top-level PC gaming or using your HDTV as a PC monitor. Invest in Quality Construction for Reliable Performance You’re expecting this 8K cable to last a long time, which is why it has been constructed with high-quality materials, such as a rugged PVC jacket. Contacts and connectors are gold-plated to resist corrosion. The male connectors latch securely to help prevent the cable from becoming accidentally disconnected and disrupting a continuous audio/video signal. Double shielding reduces line noise (EMI/RFI) that can disrupt signals traveling through the DisplayPort cord. Specifications OVERVIEW UPC Code 037332254108 Product Type Passive 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology DisplayPort Cable Type Passive VIDEO Max Supported Video Resolution 7680 X 4320 60HZ (8K) Max Supported Color Depth 24-bit True Color HDR Support Yes 3D Video Supported Yes Chroma Sub Sampling 4:4:4 EDID Support Yes Signal Transmission Bidirectional INPUT Bus Powered Yes PHYSICAL Color Black Material of Construction PVC Cable Jacket Color Black Connector Color Blue Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 6.8MM Wire Gauge (AWG) 30 Cable Length (ft.) 3 Cable Length (m) 0.91 Cable Length (in.) 36 Ferrite Core No Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Weight (kg) 0.08 Unit Dimensions (hwd / in.) 9.000 x 7.000 x 0.500 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% TO 90% RH, NON-CONDENSING Storage Humidity Range 0% TO 90% RH, NON-CONDENSING 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States COMMUNICATIONS EDID Compatible Yes Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 DISPLAYPORT (MALE) Side B - Connector 1 DISPLAYPORT (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector No FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No Integrated/Removable Cable No MST Support No Antibacterial No IP68 Rated No IP20 Rated No Fully Molded Connector Ends No Ohms No Integral Strain Relief No Impedance-Matched Twisted-Pair Construction No Scaler Function No IP67 Rated No Displayport Specification 1.4 HDCP Specification 2.2 DIN Mountable No STANDARDS & COMPLIANCE Product Certifications IEC/EN 62040 Product Compliance RoHS; CE (Europe); REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
P580-003-8K6 价格&库存
很抱歉,暂时无法提供与“P580-003-8K6”相匹配的价格&库存,您可以联系我们找货
P580-003-8K6
  • 1+234.209021+30.33826
  • 10+199.0233010+25.78048
  • 25+186.5622125+24.16634
  • 50+177.6611650+23.01334
  • 100+169.18638100+21.91556
  • 250+159.21924250+20.62446
库存:51
