P783-010-U
P783-010-U
    TRIPPLITE
    DISPLAYPORT KVM CABLE KIT - DP,
P783-010-U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DisplayPort KVM Cable Kit - DP, USB, 3.5 mm Audio (3xM/3xM) + USB (M/M), 4K, 4:4:4, 10 ft. (3.05 m), Black Highlights ● Cuts cable clutter and saves money by combining essential KVM cables into just 2 ● 10-ft. (3.05 m) 3-in-1 DP, USB A/B and 3.5 mm audio cable connects KVM to your computer ● Delivers UHD picture quality at resolutions up to 3840 x 2160 (4K x 2K) @ 60 Hz ● Supports true 4:4:4 chroma subsampling to meet latest color standards ● 10-ft. (3.05 m) USB A/B cable included for KVM's CAC port (smart cards, scanners, etc.) MODEL NUMBER: P783-010-U Applications ● Connect a headless computer to a Tripp Lite KVM switch with CAC support ● Upgrade or replace worn or lost KVM cables ● Eliminate clutter and save money by replacing multiple cables with one new kit ● Extend the distance between the KVM switch and computer to 10 ft. DisplayPort KVM cable kit with DisplayPort, USB A/B and 3.5 mm plugs connects your computer to a Tripp Lite NIAP KVM Switch. Features 10-ft. (3.05 m) Cables Connect Your DisplayPort Computer to a NIAP KVM Switch with CACThis DisplayPort cable kit includes two 10-ft. (3.05 m) cables for connecting a computer to a KVM switch with a Common Access Card (CAC) port. The P783-010 features DisplayPort, USB A/B and 3.5 mm audio connectors on both ends for connecting your computer to a KVM switch. The U022-010 is a USB cable that connects to the KVM's CAC port for accessing smart cards, scanners and biometric readers, including fingerprint readers, to bolster security. Specifically Designed for Select KVMs to Save You Time and MoneyRecommended for the B002HD1AC4 or other compatible NIAP KVM. The DisplayPort cable supports video resolutions up to 3840 x 2160 (4K x 2K) at 60 Hz with true 4:4:4 chroma subsampling. The USB cables also support USB 2.0 data transfer speeds up to 480 Mbps. By combining several different cables into one convenient kit, you cut down on unnecessary clutter and costs. Specifications OVERVIEW UPC Code 037332241665 Accessory Type Cable Kit Technology DisplayPort Accessory Class KVM Switch Accessories VIDEO 1/3 System Requirements ● B002-HD1AC4 NIAP KVM or other compatible KVM switch Package Includes ● P783-010 DisplayPort KVM cable kit, 3 in 1 (M/M), 10 ft. ● U022-010 USB A/B cable (M/M), 10 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States Max Supported Video Resolution 3840 x 2160 @ 60Hz PHYSICAL Color Black Cable Jacket Color Black Cable Length (ft.) 10 Cable Length (m) 3.05 Cable Length (in.) 120 Shipping Dimensions (hwd / in.) 1.10 x 8.10 x 10.50 Shipping Dimensions (hwd / cm) 2.79 x 20.57 x 26.67 Shipping Weight (lbs.) 1.00 Shipping Weight (kg) 0.45 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 ENVIRONMENTAL Operating Temperature Range 14° to 122°F (-10° to 50°C) Storage Temperature Range 5° to 140°F (-15° to 60°C) Relative Humidity 0 ~ 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 3.5MM (MALE); DISPLAYPORT (MALE); USB A (MALE) Side A - Connector 2 USB A (MALE) Side B - Connector 1 3.5MM (MALE); DISPLAYPORT (MALE); USB B (MALE) Side B - Connector 2 USB B (MALE) Contact Plating Gold FEATURES & SPECIFICATIONS USB Specification USB 2.0 (up to 480 Mbps) Displayport Specification 1.2 HDCP Specification 2.2 STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P783-010-U 价格&库存
很抱歉,暂时无法提供与“P783-010-U”相匹配的价格&库存,您可以联系我们找货
