P785-DPKIT06
P785-DPKIT06
    TRIPPLITE
    DISPLAYPORT KVM CABLE KIT FOR TR
P785-DPKIT06 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DisplayPort KVM Cable Kit for B005-DPUA2-K and B005-DPUA4 KVM, 4K DP, USB 3.2, 3.5 mm, 6 ft. (1.8 m) MODEL NUMBER: P785-DPKIT06 Highlights ● Includes 6 ft. (1.83 m) DisplayPort, USB 3.2 Gen 1 A/B and two 3.5 mm stereo audio cables in one kit ● Supports Ultra HD resolutions up to true 4K @ 60 Hz for crystal-clear video ● Latching DisplayPort plugs maintain constant A/V signal without accidental disconnections ● Supports USB 3.2 Gen 1 data transfer speeds up to 5 Gbps (10x faster than USB 2.0) ● For use with B005-DPUA2-K and B005-DPUA4 KVM switches Applications ● Convenient cable kit connects a computer or server with DisplayPort, USB and/or 3.5 mm ports to a compatible Tripp Lite KVM switch. System Requirements ● Computer with USB, DisplayPort and/or 3.5 mm ports ● B005-DPUA2-K or B005-DPUA4 KVM switch Features 6-ft. (1.83 m) Cables Connect Your Computer's DisplayPort, USB and Audio Ports to a KVM SwitchThis DisplayPort cable kit includes four cables for connecting your computer to a KVM switch. Recommended for the B005-DPUA2-K and B005-DPUA4 KVM switches, the kit saves you money by combining necessary cables into one convenient bunch. DisplayPortThe DisplayPort cable lets you view the video content of your computer via the console's connected monitor. It supports Ultra HD True 4K video resolutions up to 4096 x 2160 (4K x 2K) at 60 Hz. Latching Connectors Help Prevent Accidental Disconnection and Expensive DowntimeHaving a cable come loose accidentally can mean costly and time-consuming signal loss. The latching DisplayPort connectors help you avoid such danger, protecting your audio/video transmission by maintaining a secure link without failure. The latching cable is also invaluable when moving equipment in a rack or removing equipment from tight areas, ensuring the cord always stays connected. USBThe USB cable connects the KVM switch's USB-B port to your computer's USB-A port. It enables you to control all connected computers from one centralized keyboard/mouse, while also accessing external flash drives, printers, scanners or other devices connected to the switch's USB peripheral ports. The cable supports USB 3.2 Gen 1 data transfer speeds up to 5 Gbps. 3.5 mm AudioTwo 3.5 mm stereo cables connect external multimedia speakers, a microphone or headphones. Quality Construction Provides Superior Signal TransferIntegral strain relief gives the cables extra flexibility, reduces stress and helps the cables move freely without cracking or breaking loose from the connectors. Foil and braid shielding delivers reliable, error-free signal quality and protection from EMI/RFI line noise that can distort or destroy data. Specifications 1/3 Connect a computer and audio equipment, such as speakers and a microphone, to your Tripp Lite KVM switch Package Includes ● P580-006 DisplayPort cable (M/M), 6-ft. (1.83 m) ● U322-006 USB-A to USB-B cable (M/M), 6-ft. (1.83 m) ● (2) P312-006 3.5 mm audio cables (M/M), 6-ft. (1.83 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332257024 Accessory Type Cable Kit Technology DisplayPort; Stereo Audio Accessory Class KVM Switch Accessories VIDEO Max Supported Video Resolution 4096 x 2160 @ 60 Hz Max Supported Color Depth 24-bit True Color HDR Support No Chroma Sub Sampling 4:4:4 AUDIO Audio Specification Stereo Audio PHYSICAL Color Black; Blue Material of Construction PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) USB: 4.8MM; AUDIO: 3.0MM; DISPLAYPORT: 6.5MM Wire Gauge (AWG) USB: 30/28; AUDIO: 28; DISPLAYPORT: 30 Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Shipping Dimensions (hwd / in.) 10.00 x 8.00 x 0.50 Shipping Weight (kg) 0.24 ENVIRONMENTAL Operating Temperature Range 14° to 122°F (-10° to 50°C) Storage Temperature Range 5° to 140°F (-15° to 60°C) Operating Humidity Range 0 TO 90% RH, Non-Condensing Storage Humidity Range 0 TO 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 DISPLAYPORT (MALE) Side A - Connector 2 USB 3.0 A (MALE) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Side A - Connector 3 (2) 3.5MM (MALE) Side B - Connector 1 DISPLAYPORT (MALE) Side B - Connector 2 USB 3.0 B (MALE) Side B - Connector 3 (2) 3.5MM (MALE) FEATURES & SPECIFICATIONS USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) Displayport Specification 1.2 HDCP Specification 2.2 STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P785-DPKIT06 价格&库存
很抱歉,暂时无法提供与“P785-DPKIT06”相匹配的价格&库存,您可以联系我们找货
