1000 Eaton Boulevard
Cleveland, OH 44122
United States
Serial ATA (SATA) Right-Angle Signal Cable
(7Pin/7Pin-Up), 12-in. (30.48 cm)
MODEL NUMBER: P941-12I
Highlights
Connect your high-speed Serial
ATA device to a Serial ATA
controller
Features 7Pin Straight and 7Pin
Right-Angle Up connectors
Angled connector ideal for
situations in which space is at a
premium, and reduces stress /
excessive bending on the cable
SATA III (6Gbps) / SATA II
(3Gbps) / SATA I (1.5Gbps)
Compliant
Cable is shielded to protect
against EMI/RFI
Applications
controller
Compatible with Serial ATA
Hard Drives, Blu-ray/DVD/CD
Drives and other Serial ATA
devices
Features
System Requirements
Connect your high-speed Serial ATA device to a Serial ATA controller
Features 7Pin Straight and 7Pin Right-Angle Up connectors
SATA device
Angled connector ideal for situations in which space is at a premium, and reduces stress / excessive
SATA controller
Data transfer rates are
dependent upon the version of
SATA supported by your device
and controller
SATA III (6Gbps) / SATA II (3Gbps) / SATA I (1.5Gbps) Compliant
Cable is shielded to protect against EMI/RFI
Package Includes
Specifications
OVERVIEW
UPC Code
037332184399
Technology
SATA/eSATA
PHYSICAL
Color
Red
Cable Jacket Color
Red
Cable Outer Diameter (OD)
2.2 +/- 0.10 mm
1/2
Serial ATA (SATA) Right Angle
Signal Cable (7Pin/7Pin-Up) 12in.
Cleveland, OH 44122
United States
Cable Length (ft.)
1
Cable Length (m)
0.30
Cable Length (in.)
12
Cable Length (cm)
30.48
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
Shipping Weight (lbs.)
0.04
Shipping Weight (kg)
0.02
CONNECTIONS
Side A - Connector 1
7 PIN SATA STRAIGHT (MALE)
Side B - Connector 1
7 PIN SATA (MALE) - RIGHT ANGLE UP
STANDARDS & COMPLIANCE
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“P941-12I”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+30.355841+3.78031
- 10+27.5678710+3.43311
- 25+26.1089325+3.25143
- 50+25.5018150+3.17582
- 100+24.28737100+3.02458
- 250+21.25150250+2.64651
- 500+20.64432500+2.57090
- 1000+17.608381000+2.19283
- 2500+16.394012500+2.04160
