P970-U2M2
P970-U2M2
    TRIPPLITE
    连接器 适配器 用于 SFF8639
P970-U2M2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States U.2 to M.2 Adapter for M.2 PCIe NVMe SSD, SFF8639 MODEL NUMBER: P970-U2M2 Highlights ● Supports B+M Key SATA and M-Key NVMe M.2 SSDs in 2242, 2260 and 2280 sizes ● Connects to your PC via U.2 (SFF-8639) compatible interface on motherboard ● Compatible with PCE-U2-PX4 to assemble NVMe M.2 SSD into PCIe port ● Works with PCIe 3.0 motherboards; backward compatible with 2.0 and 1.0 ● Plug-and-play operation with no external power required for easy installation System Requirements ● Computer with available U.2 port on its motherboard ● M.2 modules like B+M Key SATA M.2 SSD and M-Key NVMe M.2 SSD (2242, 2260 and 2280 SSD sizes) when combined with PCE-U2-PX4 ● Windows 7 and above or macOS High Sierra and above Mounts an M.2 NVMe SSD inside your PC or server to increase data transfer speed and internal storage. Features Improves Your Computer’s or Server’s Performance and Storage Capabilities This U.2 to M.2 adapter connects a B+M Key SATA M.2 SSD or M-Key NVMe M.2 SSD (2242, 2260 or 2280 size) to your computer’s or server’s U.2 (SFF-8639) compatible host interface on the motherboard. This conversion lets you add terabytes (TB) of internal storage space and enhance your PC’s read/write speeds. The adapter is compatible with PCI Express (PCIe) 3.0 motherboards. It is also backward compatible with earlier 2.0 and 1.0 versions. Add an Optional Adapter for Expanded Functionality The P970-U2M2 adapter card is compatible with PCE-U2-PX4 U.2 to PCIe adapter (sold separately) to convert the PCIe port into an M.2 SSD module. The P970-U2M2 easily slots into place in the PCE-U2PX4 to effortlessly expand the storage capabilities of a computer that only has a PCIe port on its motherboard. Just Plug and Play with No External Power Needed The adapter is compatible with Windows (7 and higher) and macOS (High Sierra and higher). No additional software is needed. The hub-powered adapter also requires no external power. Specifications OVERVIEW UPC Code 037332279521 Drives Supported B-Key, B+M Key, M-Key (NVMe) M.2 SSD: 2242, 2260, 2280 Device Compatibility Computer Technology PCIe; SATA/eSATA INPUT 1/2 Package Includes ● P970-U2M2 U.2 to M.2 Adapter ● SSD mounting hardware ● Quick Start Guide 1000 Eaton Boulevard Cleveland, OH 44122 United States Bus Powered Yes PHYSICAL Color Black Unit Dimensions (hwd / in.) 3.900 x 2.600 x 0.220 Unit Dimensions (hwd / cm) 9.9 x 6.6 x 0.55 Unit Dimensions (hwd / mm) 3.9 x 2.6 x 0.22 ENVIRONMENTAL Operating Temperature Range 50° to 158°F (10° to 70°C) Storage Temperature Range 32° to 149°F (0° to 65°C) Relative Humidity 10% to 80% RH CONNECTIONS Number of Ports 2 FEATURES & SPECIFICATIONS SATA Version SATA I (1.5 Gbps); SATA II (3 Gbps); SATA III (6 Gbps) STANDARDS & COMPLIANCE Product Certifications EN 55032 Product Compliance CE (Europe); FCC Part 15 Class B (USA); REACH; RoHS3; UKCA; WEEE WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P970-U2M2 价格&库存
很抱歉,暂时无法提供与“P970-U2M2”相匹配的价格&库存,您可以联系我们找货
