PDU121506
PDU121506
    TRIPPLITE
    1.8KW 120V SINGLE-PHASE BASIC PD
PDU121506 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1.8kW 120V Single-Phase Basic PDU - 13 NEMA 5-15R Outlets, 5-15P Input, 6 ft. Cord, 1U RackMount Highlights ● Ideal no-frills PDU for telecom, security, audio/video and other network applications ● 13 NEMA 5-15R outlets distribute AC power to connected equipment ● Switchless design helps prevent accidental shutdowns that can lead to costly downtime ● 6 ft. cord with NEMA 5-15P single-phase input connects to AC power source ● Flexible installation options include 1U and 0U rack, under counter and on wall MODEL NUMBER: PDU121506 Applications Deliver network-grade power to high-density equipment in networking, telecom, security, audio/video and sound reinforcement applications Delivers 120V single-phase AC power to multiple loads from a utility outlet, generator or UPS system in a high-density IT environment. Features Single-Phase 120V PDU Distributes Network-Grade Power to Multiple Loads This basic PDU is an ideal no-frills unit for networking, telecom, security, audio/video and sound reinforcement applications. Recommended for high-density IT environments, the PDU121506 features a single breakered load bank with 13 NEMA 5-15R outlets – 12 in the rear and one in front. A six-foot cord with NEMA 5-15P input plug connects to your facility’s AC power source, generator or protected UPS system to distribute power to connected loads. Up-to-Date Safety Features Protect Your Vital Equipment The switchless design helps prevent an accidental shutdown, which could lead to costly downtime. A 15A circuit breaker protects connected components from dangerous overloads. Versatile Installation Options Give You Plenty of Choices The reversible all-metal housing comes with mounting brackets for installation in 1U of space in an EIAstandard 19-inch rack. You can also reorient the brackets for permanent mounting under a counter or on a wall with user-supplied hardware. With a compatible rack and PDUSIDEBRKT accessory (sold separately), you can adapt the PDU121506 for vertical 0U rack-mounting as well. Specifications OVERVIEW UPC Code 037332255747 PDU Type Basic INPUT 1/3 Package Includes ● PDU121506 1.8kW 120V Single-Phase Basic PDU ● Rack-mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Input Phase Single-Phase PDU Input Voltage 120 Recommended Electrical Service Single-phase 15A 120V service Maximum Input Amps 15 PDU Plug Type NEMA 5-15P Input Cord Length (ft.) 6 Input Cord Length (m) 1.83 OUTPUT Output Capacity Details 1.8kW (120V) / 15A total capacity; 12A max per 5-15R outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (13) 5-15R Output Nominal Voltage 120V Overload Protection 15A Breaker USER INTERFACE, ALERTS & CONTROLS Switches No power switch SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported 1U rackmount, 0U vertical rackmount, wall-mount and undercounter installation supported Minimum Required Rack Depth (cm) 19.05 Minimum Required Rack Depth (inches) 7.5 Outlets Measurement (Center to Center) 30.2mm PDU Form Factor Horizontal (1U) Shipping Dimensions (hwd / in.) 2.20 x 20.40 x 9.30 Shipping Weight (kg) 2.22 Unit Dimensions (hwd / in.) 1.750 x 20.000 x 4.500 Unit Dimensions (hwd / cm) 4.44 x 44.5 x 11.4 Unit Weight (lbs.) 4.9 Unit Weight (kg) 2.22 ENVIRONMENTAL 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range -22° to 122°F (-30° to 50°C) Relative Humidity 5% to 95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 FEATURES & SPECIFICATIONS Grounding Grounding lug STANDARDS & COMPLIANCE Product Certifications RETIE (Colombia); CAN/CSA-22.2 No. 308-14 (Canada); NOM (Mexico); UL 1363 Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDU121506 价格&库存
很抱歉,暂时无法提供与“PDU121506”相匹配的价格&库存,您可以联系我们找货
