PDU3EVSR6G60
PDU3EVSR6G60
    TRIPPLITE
    3-PHASE PDU SWITCHED 10KW 200/20
PDU3EVSR6G60 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 14.5kW 200-240V 3PH Switched PDU - LX Interface, Gigabit, 30 Outlets, IEC 309 60A Blue Input, LCD, 1.8 m Cord, 0U 1.8 m Height, TAA MODEL NUMBER: PDU3EVSR6G60 Highlights ● 14.5kW 200-240V 3-phase switched 0U PDU ● 30 individually controllable outlets—24 C13, 6 C19 ● Pre-installed GbE-capable WEBCARDLX with latest version of PADM20 for IP-based Auto Probe feature ● IEC 309 60A Blue PDU input with 1.8 m power cord ● Touchscreen LCD with mobile access option via QR code Package Includes 14.5kW 3-phase PDU with multi-function touchscreen LCD distributes, monitors and manages AC power. Built-in Java-free network interface helps you remotely monitor load levels to prevent overloads that cause downtime. Description The PDU3EVSR6G60 14.5kW 3-Phase Switched Power Distribution Unit provides advanced network control and remote power monitoring with the ability to turn on, turn off, reboot or lock out power to each outlet. By reducing the frequency of on-site visits, these advanced remote capabilities can save you money and reduce downtime. The 0U PDU features 30 switched outlets (24 C13 and 6 C19) with included plug-lock insert sleeves to prevent cables from becoming accidentally disconnected. A 6-ft. (1.83 m) cord with IEC 309 60A Blue plug connects the PDU to a compatible AC power source, generator or protected UPS. The built-in Java-free HTML5-based LX Platform network interface enables full remote access for PDU status monitoring and email notifications via secure web browser, SNMP, telnet, SSH, or CLI. It supports 10/100/1000 Mbps auto-sensing for optimum communication with an Ethernet network. Optional EnviroSense2 modules (sold separately) provide a variety of environmental monitoring capabilities. Protocols supported include IPv4, IPv6, HTTP, HTTPS, SMTP, SNMPv1, SNMPv2, SNMPv3, telnet, SSH, FTP, DHCP and NTP. A color touchscreen LCD lets you toggle between menus to monitor input current level per phase, output current per load bank and per outlet with ±1% billing-grade accuracy, environmental sensor data and network information. It also generates a unique QR code to allow access to the switchable PDU through a mobile device. Features Distributes, Monitors and Manages Network-Grade AC Power14.5kW 200-240V switched PDU with 3phase inputRecommended for network applications requiring individual outlet control, load shedding and remote monitoring of critical network componentsIEC 309 60A Blue plug with 6-ft. (1.83 m) cord connects to compatible AC power sourceFirmware upgrades support future product enhancements 30 Switched Outlets Distribute AC Power24 C13 and 6 C19 outlets split into 3 separately breakered load banksIndividual outlets can be remotely controlled to power up, power down, reboot or lock out devicesPlug-lock insert sleeves prevent cables from becoming accidentally disconnected Color Touchscreen LCDReports network data, including IP address, input current level per phase, and output current per load bank and per outlet with ±1% billing-grade accuracyGenerates unique QR code for read-only access to PowerAlert® Device Manager via mobile deviceFull access available by logging into 1/4 ● PDU3EVSR6G60 14.5kW 3Phase Switched PDU ● Built-in LX Platform interface ● Configuration cable ● (30) Plug-lock insert sleeves ● Rack-mounting hardware ● PDUMVROTATEBRKT mounting bracket accessory ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States PowerAlert Device Manager via browser as user with read/write credentials Built-In GbE-Capable LX InterfacePre-installed WEBCARDLX with the latest version of PowerAlert Device Manager firmware (PADM20) provides enhanced remote management capabilitiesPADM20 and PowerAlert Element Manager (PAEM) form a powerful tool for expanding maintenance functions in large installations, including firmware update checks and backup and restoration of device configurationsIPbased Auto Probe detects lost connectivity and restores service autonomously Broad Communications CompatibilitySupports IPv4, IPv6, HTTP, HTTPS, SMTP, SNMPv1, SNMPv2, SNMPv3, telnet, SSH, FTP, DHCP and NTPSupports automatic and manual assignment of IP address Easy 0U Installation in EIA-Standard 19 in. RacksMounts vertically using included toolless buttons or rack-mounting bracketsIncluded PDUMVROTATEBRKT allows mounting with rear-facing outlets TAA-CompliantCompliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332212863 PDU Type Switched INPUT Input Phase 3-Phase PDU Input Voltage 200; 208; 220; 230; 240 Recommended Electrical Service Three-phase 60A 200-240V service Maximum Input Amps 35 Maximum Input Amps Details Agency de-rated to 35A continuous PDU Plug Type IEC-309 60A BLUE (3P+E) Input Cord Length (ft.) 6 Input Cord Length (m) 1.83 OUTPUT Output Capacity Details 14.5kW (240V), 13.9kW (230V), 13.3kW (220V), 12.6kW (208V), 12.1kW (200V) total capacity; 20A max per breakered outlet bank; 16A max per C19 outlet; 12A max per C13 outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (24) C13; (6) C19 Output Nominal Voltage 200-240V Overload Protection Three 20A circuit breakers, 1 per outlet bank Customized Load Management Receptacles Each outlet is individually controllable via remote interface USER INTERFACE, ALERTS & CONTROLS 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Reported Load Segments Reports input current per phase (L1, L2, L3), plus output current for each output load bank (20A balanced max per banks B1-B3) and individual output receptacle (1-30); Outlets are color-coded and labeled for phase and load bank identification; L1-L2 feeds light-gray outlets (B1); L2-L3 feeds black outlets (B2); L3-L1 feeds dark-gray outlets (B3) Front Panel LCD Display Touchscreen LCD reports NETWORK DATA (IP address, Subnet Mask, Gateway, MAC Address, Device Name, Model, Serial Number), INPUT PHASE DATA (Amperage, Wattage, Voltage per phase, plus Unbalance percentage), LOAD BANK DATA (Amperage, Wattage, Voltage per load bank, plus total PDU output in watts), OUTLET DATA (Amperage, Wattage per outlet), CONFIGURATION DATA (Listing of current configuration settings), ENVIRONMENTAL DATA (Reports data and status of E2 sensor modules; Sensor options are available for temperature and humidity, plus input and output dry contacts), MOBILE ACCESS (Generates a unique QR code to view reported PDU details on a mobile device) Front Panel LEDs One LED for each output receptacle offers power availability information: GREEN (Power ON, load bank capacity 80%), RED (Power OFF/undervoltage), RED FLASHING (Power OFF/breaker trip), LED OFF (Power OFF). Network Activity (Green): Flashes for network activity. Link/Network Speed (Yellow): On steady for any speed. Switches LX Platform Interface: Recessed reset switch for interface reboot and factory reset Current Measurement Accuracy (Amps) +/-1% Voltage Measurement Accuracy (Volts) +/-1% Power Measurement Accuracy (Watts) +/-1% SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported Vertical rackmount installation supported with included mounting brackets; supports toolless mounting in buttonmount compatible racks PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 6.89 x 9.65 x 75.87 Shipping Dimensions (hwd / cm) 17.50 x 24.51 x 192.71 Shipping Weight (lbs.) 27.08 Shipping Weight (kg) 12.28 Unit Dimensions (hwd / in.) 70.000 x 2.170 x 2.860 Unit Dimensions (hwd / cm) 177.8 x 5.5 x 7.3 Unit Weight (lbs.) 20.01 Unit Weight (kg) 9.08 ENVIRONMENTAL Operating Temperature Range 32° to 122°F (0° to 50°C) Storage Temperature Range -22° to 140°F (-30° to 60°C) Relative Humidity 5% to 95% non-condensing Operating Elevation (ft.) 0-10,000 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Elevation (m) 0-3000 COMMUNICATIONS PowerAlert Software LX Platform Interface: PowerAlert Device Manager Communications Cable USB B-to-USB A Configuration/Console Access cable Network Monitoring Port RJ45 Network port, RJ45 Config/Console Access port; 2x USB A ports supports a variety of Envirosense2 environmental and control modules. See Accessories>Management Hardware section for more information about these modules. USB B port (Configuration & Console Access) SNMP Compatibility SNMP V1, V2c, V3 Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet); 1 Gbps (Gigabit) Communications Interface Pre-installed network card; RS-232; USB FEATURES & SPECIFICATIONS High Availability PDU Features Auto Probe Monitoring and Reboot (included); Auto Load Shedding STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 60950-1 (Canada); NOM (Mexico); UL 60950-1 Product Compliance RoHS; FCC Part 15 Class A (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
PDU3EVSR6G60 价格&库存
很抱歉,暂时无法提供与“PDU3EVSR6G60”相匹配的价格&库存,您可以联系我们找货
