PDU3V20D354B
PDU3V20D354B
    TRIPPLITE
    POWER OUTLET STRIPS
PDU3V20D354B 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 8.6/12.6kW 3-Phase Vertical PDU Strip, 208V Outlets (48 C13 & 6 C19), 0U Rack-Mount, Accessory for Select ATS PDUs MODEL NUMBER: PDU3V20D354B Highlights ● Required for select Tripp Lite 3phase ATS PDUs ● Offers 48 C13 and 6 C19 singlephase outlets ● Supports up to 8.6 or 12.6kW total output (depends on ATS PDU) ● Simplifies load balancing with interlaced, color-coded outlets ● Supports 0U toolless vertical rack mounting Required rack-mounted vertical outlet strip accessory for select Tripp Lite 3-phase auto-transfer switch (ATS) PDUs. Distributes AC power to high-density equipment racks in data centers and server rooms. Description The PDU3V20D354B 8.6/12.6kW 3-Phase Vertical Power Distribution Unit (PDU) Outlet Strip is a required accessory option for Tripp Lite's PDU330AT6L15, PDU330AT6L2130, PDU330AT6L1530, PDU350AT6H50 and other 3-phase auto-transfer switch (ATS) PDUs that specify compatibility with this model. It's ideal for high-density equipment racks in data centers and server rooms. When used with 208V ATS models with a 35A input rating (such as PDU350AT6H50), the PDU3V20D354B supports up to 12.6kW total output with 20A maximum full balanced load per phase combination output bank (L1-L2, L2-L3, L3-L1). When used with 208V ATS PDU models with a 24A input rating (such as PDU330AT6L2130, PDU330AT6L1530 or PDU330AT6L15), it supports up to 8.6kW total output with 13.9A maximum balanced load per phase combination output bank. The 48 C13 and 6 C19 single-phase outlets receive power from the the connected ATS PDU. The outlets are interlaced to help you balance loads by spreading connections across the phase combinations (L1-L2, L2-L3, L3-L1) throughout the rack. Each outlet is numbered and color-coded to help you keep track of connected devices and which phase combination powers each. The 2.5-ft. (0.76 m) power cord with 8position plug connects directly to the PDU's rear receptacle. The PDU3V20D354B's rugged all-metal housing mounts in compatible racks in seconds with no tools needed. Vertical 0U installation reduces cord clutter and improves airflow through the rack. Features Required Accessory for Select Tripp Lite ATS PDUs ● Compatible with PDU330AT6L15, PDU330AT6L2130, PDU330AT6L1530, PDU350AT6H50 and other select Tripp Lite 3-phase ATS PDUs ● Ideal for high-density equipment racks in data centers and server rooms ● Supports up to 12.6kW total output with 20A maximum per output bank when connected to 208V ATS models with a 35A input rating (such as PDU350AT6H50) ● Supports up to 8.6kW total output with 13.9A maximum per output bank when connected to 208V ATS models with a 24A input rating (such as PDU330AT6L2130, PDU330AT6L1530 or PDU330AT6L15) ● Heavy-duty 2.5-ft. (0.76 m) power cord plugs directly into the ATS PDU with a Unique 8-position plug Features 48 C13 and 6 C19 Outlets ● Single-phase 208V outlets are interlaced to help you balance loads by spreading connections across the phase combinations (L1-L2, L2-L3, L3-L1) throughout the rack ● Numbered and color-coded for easy identification of connected devices and which phase combination output bank powers them 1/3 Package Includes ● PDU3V20D354B 8.6/12.6kW 3Phase Vertical PDU Outlet Strip 1000 Eaton Boulevard Cleveland, OH 44122 United States Installs Easily in 0U of Rack Space ● Preinstalled mounting buttons for toolless vertical mounting in compatible racks ● Saves rack space, improves airflow and reduces cord clutter by locating outlets closer to connected devices ● Preinstalled ground screw for connecting devices that require chassis ground ● Heavy-duty all-metal housing provides durability and reliability in demanding high-density rack environments Specifications OVERVIEW UPC Code 037332190086 Accessory Type 0U Strip for 3-Phase ATS PDU Accessory Class PDU Accessories DISPLAY Accessories (Included) Mounting hardware INPUT Input Phase 3-Phase Maximum Input Amps 35 Input Cord Details Includes 7 conductor input plug for use with compatible Tripp Lite ATS PDU products only Input Cord Length (ft.) 2.5 Input Cord Length (m) 0.76 OUTPUT Output Capacity Details Supports up to 12.6kW total output; 20A max per output phase (L1-L2, L2-L3, L3-L1) when used with 35A max 208V input ATS models (such as PDU350AT6H50); Supports up to 8.6kW total output; 13.9A max per output phase (L1L2, L2-L3, L3-L1) when used with 24A max 208V input ATS models (such as PDU330AT6L2130, PDU330AT6L1530 and PDU330AT6L15); All configurations: 16A max per C19 outlet, 12A max per C13 outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (48) C13; (6) C19 Output Nominal Voltage 200; 208; 220; 230; 240 PHYSICAL Material of Construction Metal Form Factors Supported Vertical rackmount installation supported with toolless mounting in button-mount compatible racks PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 5.10 x 6.50 x 76.40 Shipping Dimensions (hwd / cm) 12.95 x 16.51 x 194.06 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (lbs.) 14.46 Shipping Weight (kg) 6.56 Unit Dimensions (hwd / in.) 70.000 x 2.200 x 2.220 Unit Dimensions (hwd / cm) 177.8 x 5.59 x 5.64 Unit Weight (lbs.) 9.26 Unit Weight (kg) 4.20 ENVIRONMENTAL Operating Temperature Range 0 to 50C (32 to 122F) Storage Temperature Range -15C to 60C (5 to 140F) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDU3V20D354B 价格&库存
很抱歉,暂时无法提供与“PDU3V20D354B”相匹配的价格&库存,您可以联系我们找货
