PDU3XV6G20
PDU3XV6G20
    TRIPPLITE
    11.5KW 3-PHASE BASIC PDU - 45 20
PDU3XV6G20 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 11.5kW 3-Phase Basic PDU - 45 208-240V Outlets (36 C13, 9 C19), IEC 309 16/20A Red 360-415V Input, 6 ft. Cord, 70 in. 0U, TAA Highlights ● Ideal no-frills PDU for telecom, security, audio/video and other network applications ● 36 C13 and 6 C19 single-phase outlets distribute AC power to connected equipment ● Switchless design helps prevent accidental shutdowns that can lead to costly downtime ● 6 ft. power cord with IEC 309 16/20A Red 3-phase input connects to AC source ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: PDU3XV6G20 Applications Deliver network-grade power to high-density equipment in networking, telecom, security, audio/video and sound reinforcement applications Delivers 208V-240V single-phase AC power to multiple loads from a utility outlet, generator or UPS system in a data center or network closet. Features 3-Phase 360-415V input / 208V-240V output PDU Distributes Network-Grade Power to Multiple Loads This basic PDU is an ideal no-frills unit for networking, telecom, security, audio/video and sound reinforcement applications. Recommended for small to mid-sized data centers, computer rooms and network closets, the PDU3XV6G20 features 36 C13 and six C19 (208-240V) outlets in three single-phase output load banks for connecting equipment. A six-foot (1.8-meter) cord with IEC 309 16/20A Red 360415V (3P+N+E) 3-phase input plug connects to your facility’s AC power source, generator or protected UPS system to distribute power to connected loads. Easy to Install Vertically in an EIA-Standard 19 in. Rack The 70-inch 0U PDU’s all-metal housing mounts vertically using the pre-installed toolless mounting buttons or the included brackets. Spare buttons are also included. Use the included PDUMVROTATEBRKT kit to install the PDU with outlets facing the rear for better airflow or equipment access. Cable retention brackets keep power cords organized and your rack free of clutter. The PDU’s switchless design helps prevent an accidental shutdown, which could lead to costly downtime. TAA-Compliant for GSA Schedule Purchases The PDU3XV6G20 is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and other federal procurement contracts. Specifications OVERVIEW UPC Code 037332255679 PDU Type Basic 1/3 Package Includes ● PDU3XV6G20 11.5kW 208V240V 3-Phase Basic PDU ● Cable retention brackets with installation hardware ● Rack-mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Input Phase 3-Phase PDU Input Voltage 360; 380; 400; 415 Recommended Electrical Service Three-phase 16A 360-415V service Maximum Input Amps 16 Maximum Input Amps Details Agency de-rated to 16A continuous PDU Plug Type IEC-309 16/20A RED (3P+N+E) Input Cord Length (ft.) 6 Input Cord Length (m) 1.83 OUTPUT Output Capacity Details 11.5kW (415/240V), 11.1kW (400/230V), 10.5kW (380/220V), 10kW (360/208V) total capacity; 16A max per output phase (L1-L2, L2-L3, L3-L1); 16A max per C19 outlet; 12A max (10A CE) per C13 outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (36) C13; (9) C19 Output Nominal Voltage 208-240V SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported Vertical rackmount installation supported with included mounting brackets; supports toolless mounting in buttonmount compatible racks PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 6.00 x 6.50 x 76.00 Shipping Weight (kg) 6.62 Unit Dimensions (hwd / in.) 70.000 x 2.200 x 1.930 Unit Dimensions (hwd / cm) 177.8 x 5.6 x 4.9 Unit Weight (lbs.) 9.00 Unit Weight (kg) 4.08 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range -22° to 122°F (-30° to 50°C) Relative Humidity 5% to 95% non-condensing Operating Elevation (ft.) 0-10,000 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Elevation (m) 0-3000 STANDARDS & COMPLIANCE Product Certifications CAN/CSA C22.2; UL 60950-1 Product Compliance RoHS; CE (Europe); FCC Part 15 Class A (USA); UKCA; Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDU3XV6G20 价格&库存
很抱歉,暂时无法提供与“PDU3XV6G20”相匹配的价格&库存,您可以联系我们找货
