PDUBHV201U
PDUBHV201U
    TRIPPLITE
    200-250V 16A SINGLE-PHASE HOT-SW
PDUBHV201U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 200-250V 16A Single-Phase Hot-Swap PDU with Manual Bypass - 5 C13 and 1 C19 Outlets, 2 C20 Inlets, 1U Rack/Wall Highlights ● Ideal for supporting critical IT equipment that require 24/7/365 uptime ● Transfers connected components to utility power with no downtime during UPS maintenance ● Dual C20 inlets support connection to separate UPS and utility input power sources ● ECO mode saves power by shutting down controlled outlet bank in certain conditions ● Mounts into 1U of rack space or onto wall using included mounting hardware MODEL NUMBER: PDUBHV201U Applications Bypass PDU maintains continuous power to connected equipment during scheduled UPS maintenance or replacement. ● Set the bypass switch to UPS during normal operation, so connected equipment can receive fulltime conditioned power ● Set the bypass switch to Utility to bypass the UPS and provide connected equipment with unfiltered power during UPS maintenance or replacement ● Enable ECO Switching to save power by shutting down one load bank when the device connected to the master outlet is powered off or in lowconsumption mode Features Bypass PDU Recommended for Maintaining Continuous Power During UPS Maintenance Keeping mission-critical data center equipment operating at its optimal level often means scheduled maintenance. But what if you are unable to afford the costly downtime involved in powering down for regular upkeep? This 200–250V 16A single-phase hot-swap PDU works in conjunction with your UPS system to keep everything running 24/7/365. It allows you to manually transfer connected equipment to utility power via the PDU’s bypass switch, permitting maintenance or equipment replacement with no interruption of performance. Package Includes Features Dual Inputs and a Manual Transfer Switch for Uninterrupted Operation The PDUBHV201U features two C20 inlets that connect to separate UPS and utility input power sources with user-supplied power cables or the included C19-to-C20 cables. The manual transfer switch allows PDU output power to flow from either input. Flip the switch to Bypass to replace the UPS and flip back to Normal once the maintenance or UPS replacement is complete. Equipment connected to the outlets will continue to operate without interruption. Optional ECO Switching Feature Enables Cost-Cutting Power Savings By enabling the ECO power saving feature, you can power off a single bank of four controlled C13 outlets all at once when the devices connected to the master C13 and C19 outlets are powered off or go into a low-power consumption mode. Mounts into 1U of Rack Space or on a Wall Use the included mounting hardware to install the PDUBHV201U’s all-metal housing into 1U of space in an EIA-standard 19-inch rack. You may also use the mounting brackets to secure the PDU to a wall. Specifications OVERVIEW 1/3 ● PDUBHV201U 200–250V 16A Hot-Swap PDU ● (2) C19-to-C20 power cables ● Mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332262455 PDU Type Hot-Swap INPUT Input Phase Single-Phase PDU Input Voltage 200; 208; 220; 230; 240; 250 Recommended Electrical Service Works with 200-250V UPS systems with C20 compatible input cabling Maximum Input Amps 16 Maximum Input Amps Details Agency de-rated to 16A continuous PDU Plug Type (2) IEC-320 C20 Input Cord Details Set of two 1.4m C19-to-C20 power cables included; Supports user supplied alternate cabling Input Cord Length (ft.) 6 Input Cord Length (m) 1.83 OUTPUT Output Capacity Details 3.2kW (200V), 3.5kW (220V), 3.7kW (230V), 3.8kW (240V), 4kW (250V) / Total capacity 10A / 16A Max per C19 outlet / 10A max per C13 outlet Frequency Compatibility 50 / 60 Hz Output Receptacle Details Set of 6 output receptacles are arranged in two groups to support the optional ECO Power-Saving feature; Two MASTER-outlets (1 C13 & 1 C19) provide optional current-sense capability that when enabled, automatically powers off the bank of 4 C13 CONTROLLABLE GROUP-outlets when the devices connected to the two MASTER-outlets are power off or enter a low power sleep mode consuming a total of 20W or less (±5W) Output Receptacles (5) C13; (1) C19 Output Nominal Voltage 200-250V USER INTERFACE, ALERTS & CONTROLS Front Panel LEDs Front panel LEDs report UTILITY Input Power ON (green), BYPASS-MODE Switch Setting (yellow), MASTER Outlet Power ON (green), CONTROLLABLE GROUP Outlets Power ON (green) Switches 2 position Manual Transfer switch offers Break-Before-Make transfer between UPS and Utility operating modes with less than 8 milliseconds (typical) transfer time; Additional switch offers ENABLE/DISABLE control of the ECO Power-Saving feature SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported Includes installation accessories for wall mount and 1U horizontal rackmount installation in 2 or 4 post equipment racks PDU Form Factor Horizontal (1U) Shipping Dimensions (hwd / in.) 5.10 x 8.00 x 21.30 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (kg) 2.90 Unit Dimensions (hwd / in.) 1.730 x 17.240 x 3.940 Unit Dimensions (hwd / cm) 4.39 x 43.79 x 10.01 Unit Weight (lbs.) 5.2 Unit Weight (kg) 2.36 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range -22° to 122°F (-30° to 50°C) Relative Humidity 5% to 95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 FEATURES & SPECIFICATIONS High Availability PDU Features Manual Hot-Swap Bypass STANDARDS & COMPLIANCE Product Certifications CAN/CSA C22.2; NOM (Mexico); UL 62368-1 Product Compliance RoHS; CE (Europe); UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUBHV201U
物料型号:PDUBHV201U 器件简介:该PDU适用于需要24/7/365持续运行的关键IT设备,允许在UPS维护期间将连接的组件转换到公用电源,无需停机。 引脚分配:具有5个C13和1个C19输出插座,2个C20输入插座。 参数特性:支持200-250V的单相电源输入,最大输入电流16A,具有ECO模式以节省电力。 功能详解:包括手动旁路开关,允许在UPS维护或更换期间维持对连接设备的连续供电。还包括可选的ECO开关功能,当主C13和C19插座的设备关闭或进入低功耗模式时,可以关闭一个C13输出组。 应用信息:在正常操作期间将旁路开关设置为UPS,以便连接的设备可以接收全时调节电源。在UPS维护或更换期间,将旁路开关设置为公用事业,以提供未经过滤的电源。 封装信息:金属外壳,支持1U机架或墙面安装。
PDUBHV201U 价格&库存
很抱歉,暂时无法提供与“PDUBHV201U”相匹配的价格&库存,您可以联系我们找货
