PDUMV32HVNETLX
PDUMV32HVNETLX
    TRIPPLITE
    7.4KW SINGLE-PHASE SWITCHED PDU
PDUMV32HVNETLX 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 7.7kW Single-Phase Switched PDU with LX Platform Interface, 230V Output, IEC 309 32A Blue, 10 ft. (3.05 m) Cord, 0U, TAA Highlights ● 20 C13 and 4 C19 230V outlets distribute clean power to connected rack equipment ● Pre-installed WEBCARDLX with latest version of PADM20 for IPbased Auto Probe feature ● Remote power monitoring and control reduces on-site visits and maintenance costs ● 10-ft. (3.05 m) power cord with IEC 309 32A Blue (2P+E) input connects to compatible AC source ● Digital ammeter for on-site load monitoring helps prevent power overloads MODEL NUMBER: PDUMV32HVNETLX Applications ● Powering a data center with server racks running missioncritical applications ● Monitoring power loads from various computers, switches, servers and other networking equipment ● Maintaining a computer network in a commercial or industrial facility 0U PDU distributes, monitors and manages single-phase power in an IT or industrial environment. Features 0U PDU Distributes, Monitors and Manages Network-Grade AC PowerRecommended for data centers, server rooms and network closets, this 0U vertical PDU provides advanced network control and remote power monitoring with the ability to turn on, turn off, reboot or lock out power to each outlet. You can more efficiently manage network power consumption and properly balance loads without having to visit the site. Reducing the number of on-site visits can help lower the cost of data center maintenance. 24 Outlets Dispense Clean PowerDuring normal operation, 24 individually controllable outlets—20 C13 and four C19—distribute AC power to connected equipment. Each 230V outlet is accompanied by an LED that illuminates when the outlet is ramped up and ready to be used. The outlets are split into two load banks, each protected by a circuit breaker that trips if the bank's connected load exceeds its maximum load rating. Plug-lock insert sleeves are included to prevent connected cables from becoming accidentally dislodged. Digital Load Meter Helps Prevent Potentially Expensive OverloadsA digital ammeter reports the load for each outlet bank separately and the total connected load. Monitoring amperage helps ensure load levels remain well below maximum capacity with no danger of overload that could lead to costly downtime or damaged equipment. The firmware can be easily upgraded to ensure the PDU continues to perform at its best as connected equipment adds new features. Built-In LX Platform Network Management Card Allows Remote Access 24/7The built-in WEBCARDLX with the latest version of PowerAlert Device Manager firmware (PADM20) provides enhanced remote management capabilities, including customizable dashboard graphs to fit user preferences. The PADM20 upgrade and PowerAlert Element Manager (PAEM) software form a powerful tool for expanding maintenance functions in large installations, including firmware update checks and backup and restoration of device configurations. PADM20’s Auto Probe feature allows a PDU with switched loads to automatically reboot devices if a network communication failure is detected. This preserves uptime and minimizes the time and expense associated with on-site support.Easy to Install Vertically in an EIA-Standard 19 in. RackThe 0U PDU mounts vertically using the included toolless mounting buttons or the included brackets. Spare buttons are also included. Use the included PDUMVROTATEBRKT kit to install the PDU with outlets facing the rear for better airflow or equipment access. A 10-ft. (3.05 m) cord with IEC 309 32A Blue (2P+E) input plug connects the single-phase PDU to a compatible AC power source, generator or protected UPS system. 1/4 Package Includes ● PDUMV32HVNETLX 7.4kW Single-Phase Switched PDU ● (24) Plug-lock insert sleeves ● Rack-mounting hardware ● Spare mounting buttons ● PDUMVROTATEBRKT mounting bracket accessory ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States TAA-Compliant for GSA Schedule PurchasesThe PDUMV32HVNETLX is compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. 2-Year WarrantyThe PDUMV32HVNETLX is backed by a 2-year warranty, ensuring reliability and performance. Specifications OVERVIEW UPC Code 037332202352 PDU Type Switched INPUT Input Phase Single-Phase PDU Input Voltage 230 Recommended Electrical Service Single-phase 32A 230V service Maximum Input Amps 32 PDU Plug Type IEC-309 32A BLUE (2P+E) Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Output Capacity Details 7.7kW (240V), 7.4kW (230V), 7kW (220V), 6.7kW (208V), 6.4kW (200V) / 32A total capacity; 16A max per breakered outlet bank; 16A max per C19 outlet; 10A max per C13 outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (20) C13; (4) C19 Output Nominal Voltage 230V Overload Protection Two 20A circuit breakers protect 12 outlets each Customized Load Management Receptacles Each outlet is individually controllable via remote interface USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Digital display reports output amps in 3 separately metered loading segments (BANK 1: Outlets #1-12; BANK 2: Outlets #13-24; BANK 3: All outlets combined) Front Panel LEDs 24 power availability LEDs confirm power off/on status for each built-in outlet. Network Link/Activity Status LED (Yellow), Network Speed LED (Green); LX Platform status LED (Green) Switches Pushbutton control scrolls visual load meter display from bank 1, bank 2 and band 1&2 combined. LX Platform Interface: Recessed reset switch for interface reboot and factory reset SURGE / NOISE SUPPRESSION Automatic Shut-Off No 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Form Factors Supported 0U vertical rackmount. Includes mounting brackets. Supports toolless mounting in button-mount compatible racks PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 5.43 x 6.57 x 73.31 Shipping Dimensions (hwd / cm) 13.79 x 16.69 x 186.21 Shipping Weight (lbs.) 16.71 Shipping Weight (kg) 7.58 Unit Dimensions (hwd / in.) 4.250 x 2.200 x 69.920 Unit Dimensions (hwd / cm) 177,6 x 5,6 x 10,8 Unit Weight (lbs.) 12.51 Unit Weight (kg) 5.67 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range -22° to 122°F (-30° to 50°C) Relative Humidity 5% to 95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 COMMUNICATIONS PowerAlert Software LX Platform Interface: PowerAlert Device Manager Communications Cable RJ45-to-DB9 configuration/console Access cable Network Monitoring Port RJ45 Network port, RJ45 Serial Config/Console Access port; USB A port supports a variety of Envirosense2 environmental and control modules. See Accessories>Management Hardware section for more information about these modules. SNMP Compatibility Pre-installed LX platform interface provides remote monitoring via Java-free HTML5 web interface, telnet, SSH and SNMP management systems Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet) FEATURES & SPECIFICATIONS High Availability PDU Features Auto Probe Monitoring and Reboot (included); Auto Load Shedding STANDARDS & COMPLIANCE Product Certifications EN 60950-1 Product Compliance RoHS; CE (Europe); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
PDUMV32HVNETLX 价格&库存
很抱歉,暂时无法提供与“PDUMV32HVNETLX”相匹配的价格&库存,您可以联系我们找货
