PDUV20-72
PDUV20-72
    TRIPPLITE
    1.9KW 120V SINGLE-PHASE BASIC PD
PDUV20-72 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2kW 100-127V Single-Phase Basic PDU - 36 NEMA 5-15/20R Outlets, L5-20P Input (5-20P Adapter), 15 ft. Cord, 72 in. 0U Rack Highlights ● Ideal no-frills PDU for telecom, security, audio/video and other network applications ● 36 NEMA 5-15/20R outlets distribute AC power to connected equipment ● Lighted power switch with protective cover helps prevent accidental shutdowns ● 15 ft. cord with L5-20P input (and 5-20P adapter) connects to AC power source ● 72 in. 0U PDU with included mounting brackets installs in rack or under counter MODEL NUMBER: PDUV20-72 Applications Deliver network-grade power to high-density equipment in networking, telecom, security, audio/video and sound reinforcement applications Delivers 120V single-phase AC power to multiple loads from a utility outlet, generator or UPS system in a data center or network closet. Features Single-Phase 100-127V PDU Distributes Network-Grade Power to Multiple Loads This basic PDU is an ideal no-frills unit for networking, telecom, security, audio/video and sound reinforcement applications. Recommended for small to mid-sized data centers, computer rooms and network closets, the PDUV20-72 features 36 NEMA 5-15/20R outlets for connecting equipment. A 15-foot cord with L5-20P input plug (and included 5-20P adapter) connects to your facility’s AC power source, generator or protected UPS system to distribute power to connected loads. Up-to-Date Safety Features Protect Your Vital Equipment A lighted on/off switch is protected by a transparent plastic cover to help prevent an accidental shutdown that could lead to costly downtime. A 20A circuit breaker protects connected components from dangerous overloads. Versatile Installation Options Give You Plenty of Choices The 72-inch 0U PDU mounts vertically in an EIA-standard 19-inch rack using the included toolless mounting buttons or the included mounting clips and hardware. You may also use the clips to secure the PDU to a wall, counter or other flat, secure surface. Bolt-down retention brackets keep power cords organized and your rack free of clutter. Specifications OVERVIEW UPC Code 037332255822 PDU Type Basic INPUT 1/3 Package Includes ● PDUV20-72 1.9kW 100-127V Single-Phase Basic PDU ● L5-20P to 5-20P input plug adapter ● Plug retention brackets with installation hardware ● Rack-mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Input Phase Single-Phase PDU Input Voltage 100; 120; 125; 127 Recommended Electrical Service Single-phase 20A 120V service Maximum Input Amps 16 Maximum Input Amps Details Agency de-rated to 16A continuous PDU Plug Type NEMA 5-20P; NEMA L5-20P Input Cord Length (ft.) 15 Input Cord Length (m) 4.57 OUTPUT Output Capacity Details 2.03kW (127V), 1.92kW (120V), 1.6kW (100V) / 16A total capacity; 16A max per outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (36) 5-15/20R Output Nominal Voltage 100-127V Overload Protection 20A circuit breaker USER INTERFACE, ALERTS & CONTROLS Switches Lighted on/off switch with integrated transparent saftey cover SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Aluminum Form Factors Supported Vertical PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 2.40 x 6.65 x 75.79 Shipping Weight (kg) 3.48 Unit Dimensions (hwd / in.) 72.470 x 1.500 x 1.640 Unit Dimensions (hwd / cm) 184.1 x 4.2 x 3.81 Unit Weight (lbs.) 6.14 Unit Weight (kg) 2.79 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range -22° to 122°F (-30° to 50°C) Relative Humidity 5% to 95% non-condensing 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 60950-1 Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUV20-72 价格&库存
很抱歉,暂时无法提供与“PDUV20-72”相匹配的价格&库存,您可以联系我们找货
