PDUV30
PDUV30
    TRIPPLITE
    2.9KW 120V SINGLE-PHASE BASIC PD
PDUV30 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2.9kW 120V Single-Phase Basic PDU - 24 NEMA 5-15/20R Outlets, L5-30P Input, 10 ft. Cord, 63.75 in. 0U Rack Highlights ● Ideal no-frills PDU for telecom, security, audio/video and other network applications ● 24 NEMA 5-15/20R outlets distribute AC power to connected equipment ● Switchless design helps prevent accidental shutdowns that can lead to costly downtime ● 10 ft. cord with NEMA L5-30P single-phase input connects to AC power source ● 63.75 in. 0U PDU with included mounting hardware installs in rack or under counter MODEL NUMBER: PDUV30 Applications Deliver network-grade power to high-density equipment in networking, telecom, security, audio/video and sound reinforcement applications Delivers 120V single-phase AC power to multiple loads from a utility outlet, generator or UPS system in a data center or network closet. Features Single-Phase 120V PDU Distributes Network-Grade Power to Multiple Loads This basic PDU is an ideal no-frills unit for networking, telecom, security, audio/video and sound reinforcement applications. Recommended for small to mid-size data centers, computer rooms and network closets, the PDUV30 features two breakered load banks, each with 12 NEMA 5-15/20R outlets for connecting equipment. A 10-foot cord with NEMA L5-30P input plug connects to your facility’s AC power source, generator or protected UPS system to distribute power to connected loads. Up-to-Date Safety Features Protect Your Vital Equipment The switchless design helps prevent an accidental shutdown, which could lead to costly downtime. Dual 20A circuit breakers protect connected components from dangerous overloads. Versatile Installation Options Give You Plenty of Choices The 63.75-inch 0U PDU mounts vertically in an EIA-standard 19-inch rack using the included toolless mounting buttons or the included mounting brackets with user-supplied hardware. You may also use the brackets to secure the PDU to the underside of a counter with the addition of two user-supplied screws. Bolt-down retention brackets keep power cords organized and your rack free of clutter. Specifications OVERVIEW UPC Code 037332255792 PDU Type Basic INPUT 1/3 Package Includes ● PDUV30 2.9kW 120V SinglePhase Basic PDU ● (2) Plug retention brackets with installation hardware ● Rack-mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Input Phase Single-Phase PDU Input Voltage 120 Recommended Electrical Service Single-phase 30A 120V service Maximum Input Amps 24 Maximum Input Amps Details Agency de-rated to 24A continuous PDU Plug Type NEMA L5-30P Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Output Capacity Details 2.88kW (120V) / 24A total capacity; 20A max per breakered load bank; 16A max per outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (24) 5-15/20R Output Nominal Voltage 120V Overload Protection Two 20A breakers protect 12 outlets each SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Aluminum Form Factors Supported 0u vertical installation in equipment racks, plus under-counter and wallmount PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 2.90 x 4.90 x 65.00 Shipping Weight (kg) 4.54 Unit Dimensions (hwd / in.) 63.750 x 2.190 x 3.750 Unit Dimensions (hwd / cm) 162 x 5.7 x 9.5 Unit Weight (lbs.) 8 Unit Weight (kg) 3.63 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range -22° to 122°F (-30° to 50°C) Relative Humidity 0% to 95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Certifications RETIE (Colombia); CAN/CSA-C22.2 No. 62368-1 (Canada); NOM (Mexico); UL 62368-1 Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUV30 价格&库存
很抱歉,暂时无法提供与“PDUV30”相匹配的价格&库存,您可以联系我们找货
