PINV1500
PINV1500
    TRIPPLITE
    12VDC 电压输入 1.5 kW 连续功率输出 反相器 2 AC 插座 NEMA 5-15R(2) 适用于北美地区
PINV1500 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1500W Medium-Duty Compact Mobile Power Inverter with 2 AC/2 USB - 2.0A/Battery Cables MODEL NUMBER: PINV1500 Highlights ● Provides portable power for mobile devices, including phones and laptops ● Ideal for areas without regular power outlets, such as campsites or construction sites ● Dual NEMA 5-15R outlets deliver continuous output of 1500W for powering devices ● Dual USB charging ports keep smartphones, tablets and laptops at full capacity ● Rugged aluminum housing built to withstand rigors of travel and outdoor use Applications ● Converts 12V DC power from your vehicle’s battery into 120V AC and 5V DC power to operate and charge electronics while on the road. Power multiple electronic devices and tools from your car, truck, fleet vehicle, boat or RV Package Includes ● PINV1500 1500W Medium-Duty Compact Car Inverter Features ● Battery cable, red/black, 3 ft. Mobile Power Inverter Charges and Powers Multiple Electronic Devices in Your VehicleYou don’t have to be near your computer or an AC power source to keep your mobile devices fully charged and your power tools and small appliances operating. This 1500W mobile inverter converts 12V DC power from your car, truck, fleet vehicle, boat or RV’s battery into standard 120V AC power. Just connect the included battery cables between the inverter’s DC input terminals and the positive and negative terminals on your vehicle’s battery. ● Grounding cable, 3 ft. ● Owner’s manual Dual AC Outlets Provide Portable Power for Your Mobile ApplicationsThis compact power inverter provides a modified sine wave for use at remote locations, such as campgrounds, construction sites and mobile offices. Two NEMA 5-15R outlets deliver a continuous output of 1500 watts and a peak output of 3000 watts. That’s plenty to operate a variety of appliances and power tools, such as low-power lights, camping accessories, battery rechargers for small battery-operated power tools, and mobile office equipment. Dual USB Charging Ports Keep Your Devices at Full StrengthTwo 5V USB ports share 2.0 amps of charging capacity and remain active even when the inverter’s on/off switch is set to Off. This allows you to charge your smartphone, tablet, laptop, MP3 player or GPS unit without draining too much power from the vehicle’s battery. Includes the Latest Safety Features to Protect Your Equipment and BatteryAn on/off switch offers one-touch control over both AC outlets. If the power input from the vehicle’s battery drops below 10 volts or exceeds 16 volts, the mobile power inverter will automatically shut down. Green and red LEDs indicate normal and improper operation. Two load-controlled fans begin cooling automatically when the internal temperature rises to a certain level during extended use. An audible alarm sounds during excessively high or low voltage conditions. Brackets Included for Permanent MountingThe compact power inverter’s durable aluminum housing is designed to withstand the rigors of road trips, campouts, business trips and family vacations. Use the built-in mounting brackets and your own hardware to install the inverter permanently in a horizontal position. 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332225177 INPUT Recommended Electrical Service 12V DC Input Connection Type DC terminal post for battery cables with ring terminals Voltage Compatibility (VAC) 110; 120 Voltage Compatibility (VDC) 10-16 Input Cord Length (ft.) 3 Input Cord Length (m) 0.91 OUTPUT Frequency Compatibility 60 Hz Pure Sine Wave Output No Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 115V; 120V Output Receptacles (2) 5-15R Continuous Output Capacity (Watts) 1500 Peak Output Capacity (Watts) 3000 Output Voltage Regulation Maintains PWM sine wave output voltage of 120VAC (+/- 10%) Output Frequency Regulation 60Hz (+/- 3Hz) Overload Protection Yes Output Voltage (VDC) 5V BATTERY Expandable Runtime No Expandable Battery Runtime User-Supplied 12VDC battery system DC System Voltage (VDC) 12 Battery Access Terminal Post Battery Pack Accessory (Optional) User-Supplied;  98-121 , BP260 USER INTERFACE, ALERTS & CONTROLS Front Panel LEDs Single multi-color status LED for operation (Green) and fault conditions (RED) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Switches ON/OFF Rocker Switch Audible Alarm Low Battery, Short Circuit, Over-temperature, High DC Voltage, Low DC Voltage and Overload protection CHARGING Charging Ports / Amps (2) 2A PHYSICAL Material of Construction Aluminum, Steel Form Factors Supported Horizontal Floor, Wall-Mount Housing Color Black; Blue Receptacle Color Black Shipping Dimensions (hwd / in.) 6.89 x 5.70 x 2.55 Shipping Weight (kg) 0.69 Unit Dimensions (hwd / in.) 3.540 x 7.600 x 8.270 Unit Dimensions (hwd / cm) 15/14 x 10.59 x 5.99 Unit Weight (lbs.) 4.63 Unit Weight (kg) 2.10 ENVIRONMENTAL Relative Humidity 0-95% (non-condensing) Operating Temperature 32° to 104°F (0° to 40°C) FEATURES & SPECIFICATIONS Grounding Grounding lug grounds the inverter to vehicle or earth ground; ground cable included STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 107.1 (Canada); UL 458 Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PINV1500 价格&库存
很抱歉,暂时无法提供与“PINV1500”相匹配的价格&库存,您可以联系我们找货
