PINV3000
PINV3000
    TRIPPLITE
    12VDC 电压输入 3 kW 连续功率输出 反相器 4 AC 插座 NEMA 5-20R(2),5-15R(2) 适用于北美地区
PINV3000 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 3000W Heavy-Duty Mobile Power Inverter with 4 AC/2 USB - 2.0A/Battery Cables MODEL NUMBER: PINV3000 Highlights ● Provides portable power for mobile devices, including phones and laptops ● Ideal for areas without regular power outlets, such as campsites or construction sites ● Four 5-15/20R GFCI outlets deliver continuous output of 3000W for powering devices ● Two USB charging ports supply 2A to keep smartphones and tablets at full capacity ● Rugged aluminum housing built to withstand rigors of travel and outdoor use Applications ● Converts 12V DC power from your vehicle’s battery into 120V AC and 5V DC power to operate and charge electronics while on the road. Features Heavy-Duty Power Inverter Charges and Powers Multiple Electronic Devices in Your VehicleYou don’t have to be near your computer or an AC power source to keep your mobile devices fully charged and your power tools and small appliances operating. This 3000W mobile inverter converts 12V DC power from your car, truck, fleet vehicle, boat or RV’s battery into standard 120V AC power. Just connect the included battery cables between the inverter’s DC input terminals and the positive and negative terminals on your vehicle’s battery. 4 GFCI-Protected AC Outlets Provide Portable Power for Your Mobile ApplicationsThis power inverter provides a modified sine wave for use at remote locations, such as campgrounds, construction sites and mobile offices. Four NEMA 5-15/20R outlets deliver a continuous output of 3000 watts and a peak output of 6000 watts. That’s plenty to operate a variety of appliances and power tools, such as lowpower lights, camping accessories, battery chargers for small battery-operated power tools, and mobile office equipment. All outlets have OSHA-compliant GFCI (Ground-Fault Circuit Interrupter) protection to shield you from electrical hazards in case of excessive fault current. USB Charging Ports Keep Your Devices at Full StrengthTwo USB-A charging ports share 2 amps of charging capacity and remain active even when the inverter’s on/off switch is set to Off. This allows you to charge your smartphone, tablet, laptop, MP3 player or GPS unit without draining too much power from the vehicle’s battery. Includes the Latest Safety Features to Protect Your Equipment and BatteryAn on/off switch offers one-touch control over all AC outlets. If the power input from the vehicle’s battery drops below 10 volts or exceeds 16 volts, the mobile power inverter will automatically shut down. Green and red LEDs indicate normal and improper operation. The temperature controlled fans begin cooling automatically when the internal temperature rises to a certain level during extended use. An audible alarm sounds during excessively high or low voltage conditions. Remote Control Panel Allows Power Control from 20 ft. AwayA remote panel is included to extend on/off control over AC power output from a remote location. The wired panel connects to the PINV3000’s RJ11 port and can be permanently installed inside your vehicle with user-supplied hardware. This allows you to mount the inverter somewhere out of sight, like inside compartment or cabinet, and be able to operate it from your vehicle’s dashboard. The panel’s green LED confirms the inverter is powered on. 1/4 Power multiple electronic devices and tools from your car, truck, fleet vehicle, boat or RV Package Includes ● PINV3000 3000W Heavy-Duty Mobile Car Inverter ● PINVRM wired remote panel w/20 ft. cable ● Battery cable, red/black, 3 ft. ● Grounding cable, 3 ft. ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Brackets Included for Permanent MountingThe heavy-duty power inverter’s durable aluminum housing is designed to withstand the rigors of road trips, campouts, business trips and family vacations. Use the built-in mounting brackets and your own hardware to install the inverter permanently in a horizontal position. Specifications OVERVIEW UPC Code 037332225153 INPUT Recommended Electrical Service 12V DC Input Connection Type DC terminal posts for battery cables with ring terminals Voltage Compatibility (VAC) 110; 120 Voltage Compatibility (VDC) 10-16 Input Cord Length (ft.) 3 Input Cord Length (m) 0.91 OUTPUT Frequency Compatibility 60 Hz Output Receptacle Details The four GFCI protected outlets support 15A or 20A equipment plugs. Pure Sine Wave Output No Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 115V; 120V Output Receptacles (4) 5-15/20R Continuous Output Capacity (Watts) 3000 Peak Output Capacity (Watts) 6000 Output Voltage Regulation Maintains PWM sine wave output voltage of 120VAC (+/- 10%) Output Frequency Regulation 60Hz (+/- 3Hz) Overload Protection Yes Output Voltage (VDC) 5V BATTERY Expandable Runtime No Expandable Battery Runtime User-Supplied 12VDC battery system DC System Voltage (VDC) 12 Battery Access Terminal Post 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Battery Pack Accessory (Optional) User-Supplied,  98-121 , BP260 USER INTERFACE, ALERTS & CONTROLS Front Panel LEDs Single multi-color status LED for operation (Green) and fault conditions (RED), GFCI protection status LED (Green); PINVRM connection status LED (Green); GFCI status LEDS (Green) Switches Inverter: ON/OFF/REMOTE Rocker Switch; Optional PINVRM wired remote panel: ON/OFF push-button switch. Audible Alarm Low Battery, Short Circuit, Over-temperature, High DC Voltage, Low DC Voltage and Overload protection CHARGING Charging Ports / Amps (2) 2A PHYSICAL Material of Construction Aluminum, Steel Cooling Method Temperature Controlled Fans Form Factors Supported Horizontal Floor or Horizontal Wallmount Housing Color Black; Blue Receptacle Color White Unit Dimensions (hwd / in.) 4.600 x 10.470 x 14.410 Unit Dimensions (hwd / cm) 11.68 x 26.59 x 36.60 Unit Weight (lbs.) 11.29 Unit Weight (kg) 5.12 ENVIRONMENTAL Relative Humidity 10-95% (non-condensing) Operating Temperature 32° to 104°F (0° to 40°C) FEATURES & SPECIFICATIONS Grounding Grounding lug grounds the inverter to vehicle or earth ground; ground cable included STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 107.1 (Canada); UL 458 Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Optional Coverage 1-Year standard warranty extension Extended Warranties WEXT1E 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
PINV3000 价格&库存
很抱歉,暂时无法提供与“PINV3000”相匹配的价格&库存,您可以联系我们找货
