PS4B18
PS4B18
    TRIPPLITE
    4-OUTLET POWER STRIP - BRITISH B
PS4B18 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Outlet Power Strip - British BS1363A Outlets, 220-250V AC, 13A, 1.8 m Cord, BS1363A Plug, White Highlights ● 4 BS1363A outlets distribute power to appliances, tools, lighting and other electronics ● 1.8 m cord with BS1363A plug offers flexible placement in relation to an AC wall outlet ● 29.5 cm plastic housing designed to withstand the rigors of everyday use ● Rear keyhole slots enable mounting to desk or workbench for easy access to outlets ● 13A circuit breaker shuts down all UK outlets for safety in case of overload MODEL NUMBER: PS4B18 Applications ● Distribute power to computer equipment and other devices in an office, workbench, retail or telecom environment ● Mount a power strip to the edge of a desk or workbench for easy access to outlets 4-outlet power strip distributes electricity to home and office electronics, including computers, power tools and appliances. Package Includes Features ● 29.5 cm Power Strip Delivers Electricity to 4 Devices at the Same TimeCompatible with standard electrical equipment, this ProtectIt!® power strip features four BS1363A outlets and a durable white plastic housing. It is ideal for powering almost anything with a compatible plug, including computers and mobile devices to appliances and power tools. Allows Flexibility in Placing the Power Strip Away from the WallThe BS1363A plug is attached to a 1.8-meter power cord, which gives you more choices in placing the power strip away from the connected AC outlet. Vertical or Horizontal Mounting for Desks and WorkbenchesKeyhole-shaped mounting slots on the back of the power strip allow you to permanently install it on any flat surface, including walls, with usersupplied hardware. Premium Safety Features Designed for Protecting Your Valuable EquipmentThe PS4B18 features an on/off switch with diagnostic LED that provides one-touch control over all connected devices. An integrated 13A circuit breaker protects all outlets and automatically cuts power if the protection circuit is incapacitated, preventing equipment damage and indicating replacement is required. Specifications OVERVIEW UPC Code 037332250247 INPUT Nominal Input Voltage(s) Supported 230V AC 1/3 PS4B18 4-Outlet Power Strip, British BS1363A Outlets, White 1000 Eaton Boulevard Cleveland, OH 44122 United States Recommended Electrical Service 230V (220-250V) Voltage Compatibility (VAC) 220-250 Input Plug Type British Input Cord Length (ft.) 5.9 Right-Angle Plug Yes Input Cord Length (m) 1.80 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (4) British BS 1363A Circuit Breaker (amps) 13 Overload Protection Combo power switch and circuit breaker Outlet Orientation Right-angled Right-Angle Outlets Yes USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes Switches Two position power switch SURGE / NOISE SUPPRESSION Protection Modes Includes full normal mode (H-N) and common mode (N-G/H-G) line surge suppression Automatic Shut-Off No DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No PHYSICAL Color White Material of Construction Plastic Power Cord Color White Housing Color White Mounting Holes or Slots Yes Receptacle Color White Shipping Dimensions (hwd / in.) 11.70 x 3.00 x 2.70 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / cm) 29.72 x 7.62 x 6.86 Shipping Weight (lbs.) 0.83 Shipping Weight (kg) 0.38 Unit Dimensions (hwd / in.) 11.600 x 2.900 x 2.600 Unit Dimensions (hwd / cm) 11.6 x 2.9 x 2.9 Unit Weight (lbs.) 0.81 Unit Weight (kg) 0.37 FEATURES & SPECIFICATIONS Rotatable Outlets No Antimicrobial No Built-In Circuit Breaker Yes STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PS4B18 价格&库存
很抱歉,暂时无法提供与“PS4B18”相匹配的价格&库存,您可以联系我们找货
