PS5F3USB
PS5F3USB
    TRIPPLITE
    5-OUTLET POWER STRIP WITH USB CH
PS5F3USB 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 5-Outlet Power Strip with USB Charging - French Type E Outlets, 220-250V, 16A, 3 m Cord, Type E Plug, White Highlights ● 5 French Type E outlets distribute power to appliances, tools and other electronics ● Right-angle Type E plug permits connection in confined or hardto-reach spaces ● 2 USB-A ports share 2.1A of power for charging phones, tablets and other mobile devices ● 43 cm plastic housing designed to withstand the rigors of everyday use ● 16A circuit breaker shuts down all outlets for safety in case of overload MODEL NUMBER: PS5F3USB Applications ● Distribute power to computer equipment and other devices in an office, workbench, retail or telecom environment ● Charge a smartphone and tablet without taking up available AC outlets 5-outlet power strip with USB-A ports distributes electricity to home and office electronics and charges your mobile devices. Package Includes Features ● 43 cm Power Strip Delivers Electricity to 5 Devices at the Same TimeCompatible with standard electrical equipment, this Protect It!® power strip features five French Type E outlets and a durable white plastic housing. It is ideal for powering almost anything with a compatible plug, including computers and mobile devices to appliances and power tools. Charges 2 Mobile Devices with 2.1A of Shared PowerIn addition to AC outlets, this power strip provides USB charging for up to two mobile devices, including smartphones, tablets and e-readers. The USB-A ports eliminate the need for AC adapters for charging cords, leaving outlets available for AC equipment. Designed to Give You Flexibility in Placing the Power Strip Where It’s Most NeededThe power strip features a space-saving right-angle Type E plug that helps you connect to a wall outlet located behind furniture that is placed flush against the wall. The plug is attached to a 3-meter power cord, which gives you more choices in placing the power strip away from the connected AC outlet. Premium Safety Features Designed for Protecting Your Valuable EquipmentThe PS5F3USB features an on/off switch that provides one-touch control over all connected devices. In the event of an overload, a 16-amp circuit breaker immediately shuts down the power strip to prevent equipment damage. Specifications OVERVIEW UPC Code 037332251497 Product Type Power Strip Charging Form Factor Strip 1/3 PS5F3USB 5-Outlet Power Strip, French Type E Outlets, White 1000 Eaton Boulevard Cleveland, OH 44122 United States Device Compatibility Phone; Tablet; Amazon Kindle INPUT Nominal Input Voltage(s) Supported 230V AC Recommended Electrical Service 230V (220-250V) Voltage Compatibility (VAC) 220-250 Input Plug Type French Input Cord Length (ft.) 9.8 Right-Angle Plug Yes Input Cord Length (m) 2.99 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (5) French/Belgian Circuit Breaker (amps) 16 Overload Protection Combo power switch and circuit breaker Outlet Orientation Right-angled Right-Angle Outlets Yes USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes Switches Two position power switch CHARGING Number of Charging Ports 2 Charging Method USB Charging Port Type USB A (FEMALE) Charging Ports / Amps (2) 2.1A SURGE / NOISE SUPPRESSION Automatic Shut-Off No DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color White Material of Construction Plastic Power Cord Color White Housing Color White Mounting Holes or Slots Yes Receptacle Color White Shipping Dimensions (hwd / in.) 17.00 x 3.50 x 2.40 Shipping Dimensions (hwd / cm) 43.18 x 8.89 x 6.10 Shipping Weight (lbs.) 1.80 Shipping Weight (kg) 0.82 Unit Dimensions (hwd / in.) 16.700 x 3.100 x 2.000 FEATURES & SPECIFICATIONS Rotatable Outlets No Antimicrobial No Built-In Circuit Breaker Yes STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PS5F3USB
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光隔离型光电开关,具有高灵敏度和高响应速度,适用于各种工业自动化控制领域。
3. 引脚分配:EL817共有6个引脚,分别为Vcc、Out、GND、L1、L2和Ve。
4. 参数特性:工作电压为5V,工作电流为10mA,响应时间为1ms,隔离电压为2.5kV。
5. 功能详解:EL817通过光电转换实现信号的隔离传输,提高系统的抗干扰能力。
6. 应用信息:EL817广泛应用于工业自动化、医疗设备、通信设备等领域。
7. 封装信息:EL817采用DIP6封装。
PS5F3USB 价格&库存
很抱歉,暂时无法提供与“PS5F3USB”相匹配的价格&库存,您可以联系我们找货
