PS5G3USB
PS5G3USB
    TRIPPLITE
    5-OUTLET POWER STRIP WITH USB-A
PS5G3USB 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 5-Outlet Power Strip with USB-A Charging Schuko Outlets, 220-250V, 16A, 3 m Cord, Schuko Plug, White Highlights ● 5 Schuko outlets distribute power to appliances, tools, lighting and other electronics ● Right-angle Schuko plug permits connection in confined or hardto-reach spaces ● 2 USB-A ports share 2.1A of power for charging phones, tablets and other mobile devices ● On/off switch gives you convenient one-touch control over all connected devices ● 16A circuit breaker shuts down all outlets for safety in case of overload MODEL NUMBER: PS5G3USB Applications ● Distribute power to computer equipment and other devices in an office, workbench, retail or telecom environment ● Charge a smartphone and tablet without taking up available AC outlets 5-outlet power strip with USB-A ports distributes electricity to home and office electronics and charges your mobile devices. Package Includes Features ● 42.5 cm Power Strip Delivers Electricity to 5 Devices at the Same TimeCompatible with standard electrical equipment, this Protect It!® power strip features five Type F Schuko outlets and a durable white plastic housing. It is ideal for powering almost anything with a compatible plug, including computers and mobile devices to appliances and power tools. Charges 2 Mobile Devices with 2.1A of Shared PowerIn addition to AC outlets, this power strip provides USB charging for up to two mobile devices, including smartphones, tablets and e-readers. The USB-A ports eliminate the need for AC adapters for charging cords, leaving outlets available for AC equipment. Designed to Give You Flexibility in Placing the Power Strip Where It’s Most NeededThe power strip features a space-saving right-angle Schuko plug that helps you connect to a wall outlet located behind furniture that is placed flush against the wall. The plug is attached to a 3-meter power cord, which gives you more choices in placing the power strip away from the connected AC outlet. Premium Safety Features Designed for Protecting Your Valuable EquipmentThe PS5G3USB features a lighted on/off switch that provides one-touch control over all connected devices. In the event of an overload, a 16-amp circuit breaker immediately shuts down the power strip to prevent equipment damage. The high-impact plastic housing is designed for the rigors of everyday use. Specifications OVERVIEW UPC Code 037332251657 Product Type Power Strip 1/3 PS5G3USB 5-Outlet Power Strip, German Type F Schuko Outlets, White 1000 Eaton Boulevard Cleveland, OH 44122 United States Charging Form Factor Strip Device Compatibility Phone; Tablet; Amazon Kindle INPUT Nominal Input Voltage(s) Supported 230V AC Recommended Electrical Service 230V (220-250V) Voltage Compatibility (VAC) 220-250 Input Plug Type French Input Cord Length (ft.) 9.8 Right-Angle Plug Yes Input Cord Length (m) 2.99 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (5) Schuko Type F Circuit Breaker (amps) 16 Overload Protection Combo power switch and circuit breaker Outlet Orientation Right-angled Right-Angle Outlets Yes USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes Switches Two position power switch CHARGING Number of Charging Ports 2 Charging Method USB Charging Port Type USB A (FEMALE) Charging Ports / Amps (2) 2.1A SURGE / NOISE SUPPRESSION Automatic Shut-Off No DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Telephone/DSL Protection No PHYSICAL Color White Material of Construction Plastic Power Cord Color White Housing Color White Mounting Holes or Slots Yes Receptacle Color White Shipping Dimensions (hwd / in.) 17.00 x 3.50 x 2.40 Shipping Dimensions (hwd / cm) 43.18 x 8.89 x 6.10 Shipping Weight (lbs.) 1.80 Shipping Weight (kg) 0.82 Unit Dimensions (hwd / in.) 16.700 x 3.100 x 2.000 FEATURES & SPECIFICATIONS Rotatable Outlets No Antimicrobial No Built-In Circuit Breaker Yes STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PS5G3USB 价格&库存
很抱歉,暂时无法提供与“PS5G3USB”相匹配的价格&库存,您可以联系我们找货
