PS5G15
PS5G15
    TRIPPLITE
    5-OUTLET POWER STRIP - GERMAN TY
PS5G15 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 5-Outlet Power Strip - German Type F Schuko Outlets, 220-250V, 16A, 1.5 m Cord, Schuko Plug, White Highlights ● 5 Schuko outlets distribute power to appliances, tools, lighting and other electronics ● Right-angle Schuko plug permits connection in confined or hardto-reach spaces ● 33 cm plastic housing designed to withstand the rigors of everyday use ● On/off switch gives you convenient one-touch control over all connected devices ● 16A circuit breaker shuts down all outlets for safety in case of overload MODEL NUMBER: PS5G15 Applications ● Distribute power to computer equipment and other devices in an office, workbench, retail or telecom environment Package Includes 5-outlet power strip distributes electricity to home and office electronics, including computers, power tools and appliances. Features 33 cm Power Strip Delivers Electricity to 5 Devices at the Same TimeCompatible with standard electrical equipment, this Protect It!® power strip features five Type F Schuko outlets and a durable white plastic housing. It is ideal for powering almost anything with a compatible plug, including computers and mobile devices to appliances and power tools. Designed to Give You Flexibility in Placing the Power Strip Where It’s Most NeededThe power strip features a space-saving right-angle Schuko plug that helps you connect to a wall outlet located behind furniture that is placed flush against the wall. The plug is attached to a 1.5-meter power cord, which gives you more choices in placing the power strip away from the connected AC outlet. Premium Safety Features Designed for Protecting Your Valuable EquipmentThe PS5G15 features a lighted on/off switch that provides one-touch control over all connected devices. In the event of an overload, a 16-amp circuit breaker immediately shuts down the power strip to prevent equipment damage. The high-impact plastic housing is designed for the rigors of everyday use. Specifications OVERVIEW UPC Code 037332251626 INPUT Nominal Input Voltage(s) Supported 230V AC Recommended Electrical Service 230V (220-250V) Voltage Compatibility (VAC) 220-240 1/3 ● PS5G15 5-Outlet Power Strip, German Type F Schuko Outlets, White 1000 Eaton Boulevard Cleveland, OH 44122 United States Input Plug Type German Input Cord Length (ft.) 4.9 Right-Angle Plug Yes Input Cord Length (m) 1.49 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (5) Schuko Type F Circuit Breaker (amps) 16 Overload Protection Combo power switch and circuit breaker Outlet Orientation Right-angled Right-Angle Outlets Yes USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) No Switches Two position power switch SURGE / NOISE SUPPRESSION Automatic Shut-Off No DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No PHYSICAL Color White Material of Construction Plastic Power Cord Color White Housing Color White Mounting Holes or Slots Yes Receptacle Color White Shipping Dimensions (hwd / in.) 13.00 x 2.80 x 2.20 Shipping Dimensions (hwd / cm) 33.02 x 7.11 x 5.59 Shipping Weight (lbs.) 0.95 Shipping Weight (kg) 0.43 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Dimensions (hwd / in.) 13.000 x 2.800 x 2.000 FEATURES & SPECIFICATIONS Rotatable Outlets No Antimicrobial No Built-In Circuit Breaker Yes STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PS5G15 价格&库存
很抱歉,暂时无法提供与“PS5G15”相匹配的价格&库存,您可以联系我们找货
