PSSS2C
PSSS2C
    TRIPPLITE
    MOUNTING CLAMPS FOR TRIPP LITE P
PSSS2C 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Mounting Clamps for PS- and SS-Series BenchMount Power Strips - Pack of 2 MODEL NUMBER: PSSS2C Highlights ● C-clamps fit edges up to 2.25 inches thick on desks, tables and workbenches ● Built-in mounting clips accommodate PS- and SSseries power strips ● Support for horizontal mounting; no drilling required ● Clamps add flexibility and portability to new installations and retrofits ● Heavy-duty steel construction provides strength and durability Applications Clamps have built-in clips to securely mount Tripp Lite PS- and SS-series bench-mount power strips without the need for drilling holes. ● Mount power strips to the edge of a workbench for easy access to outlets ● Install power strips at a trade show booth without drilling ● Mount power strips to a desk without damaging its surface Package Includes Features C-Clamps Securely Mount Power Strips without DrillingNow it’s possible to mount PS- and SS-series bench-mount power strips without drilling into walls or workbenches. Sold in a pack of two, the PSSS2C C-clamps attach to the edge of a desk, table, workbench or other solid, flat surface up to 2.25 inches thick. Slide the clamps onto the edge of your surface, hand tighten the adjustment knobs to secure and then snap your power strip into the built-in mounting clips. For optimal support, use at least two clamps for power strips 36 inches and shorter. For power strips longer than 36 inches, use an additional clamp every 12 to 18 inches. Add Flexibility to Power Strip InstallationsThe PSSS2C clamps are perfect for installations where drilling mounting holes is not possible or desirable. There are no mounting fasteners, so you can reposition the power strip installation quickly. The built-in mounting clips allow you to replace a power strip without removing the clamps from the mounting surface. Made of heavy-duty steel, the clamps withstand the rigors of daily use. Retrofit Existing Installations to Improve Access to OutletsYou can change the mounting of a power strip you already own to improve access to the outlets or to avoid drilling new holes when relocating the strip. The built-in mounting clips are designed for use with PS- and SS-series bench-mount power strips. (Compatibility with other power strips depends on the strip’s dimensions; the mounting clips are not adjustable.) Specifications OVERVIEW UPC Code 037332241818 Accessory Type Mounting Accessories Accessory Class Power Strip Accessories 1/2 (2) PSSS2C Mounting Clamps for Bench-Mount Power Strips 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Input Cord Length (ft.) 0 Input Cord Length (m) 0.00 Integrated Cord Clip No OUTPUT Right-Angle Outlets No PHYSICAL Color Black Material of Construction Steel Mounting Holes or Slots No Shipping Dimensions (hwd / in.) 1.90 x 3.80 x 6.50 Shipping Dimensions (hwd / cm) 4.83 x 9.65 x 16.51 Shipping Weight (lbs.) 0.62 Shipping Weight (kg) 0.28 Unit Dimensions (hwd / in.) 4.800 x 1.700 x 1.600 Unit Dimensions (hwd / cm) 12.19 X 4.32 X 4.06 Unit Weight (lbs.) 0.56 Unit Weight (kg) 0.25 FEATURES & SPECIFICATIONS Antimicrobial No STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
PSSS2C 价格&库存
很抱歉,暂时无法提供与“PSSS2C”相匹配的价格&库存,您可以联系我们找货
