RBC72S
RBC72S
    TRIPPLITE
    REPLACEMENT BATTERY CARTRIDGE
RBC72S 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Replacement Battery Cartridge for Select 72V SmartOnline UPS Systems MODEL NUMBER: RBC72S Highlights ● Replacement internal battery for select UPS systems ● Rugged leakproof construction ● No maintenance required ● Wide range of operating temperatures ● Preassembled and prewired for immediate installations Package Includes ● Extends the battery life of select Tripp Lite SmartOnline UPS systems. Description The RBC72S Replacement Battery Cartridge breathes new life into select UPS systems whose internal batteries are expired or not working. Built to function in a wide range of operating temperatures, the RBC72S has been carefully screened and certified to restore your UPS system’s runtime performance to its original specifications. The leakproof, no-maintenance RBC72S comes preassembled and prewired for quick and easy installation in your UPS system. Reusable packaging holds expired batteries for delivery to the nearest recycling center. Compatible with SU3000RTXL2U (LED display to the right of front bezel), SU3000RTXLCD2U, SU3000LCD2UHV, SUINT3000LCD2U, SUINT3000RTXL2U (LED display to the right of front bezel) and other models recommending its use. Features Replacement Internal Battery for Select UPS Systems ● Screened and certified to restore UPS system’s runtime performance to original specs ● compatible with SU3000RTXLCD2U, SU3000LCD2UHV, SUINT3000LCD2U and other models recommending its use ● Preassembled and prewired for immediate installation ● Designed for a wide range of operating temperatures ● Rugged leakproof construction ● No maintenance required ● Reusable packaging for delivering expired batteries to recycling center Specifications OVERVIEW UPC Code 037332189172 BATTERY 1/2 RBC72S Replacement 72V Battery Cartridge 1000 Eaton Boulevard Cleveland, OH 44122 United States DC System Voltage (VDC) 72 Included Battery Set Contains (6) 12V 9AH sealed lead acid batteries Typical Battery Lifespan 3 to 5 years, depending on UPS operating conditions PHYSICAL Shipping Dimensions (hwd / in.) 3.78 x 9.06 x 19.30 Shipping Dimensions (hwd / cm) 9.60 x 23.01 x 49.02 Shipping Weight (lbs.) 40.12 Shipping Weight (kg) 18.20 Unit Dimensions (hwd / in.) 2.660 x 8.340 x 17.910 Unit Dimensions (hwd / cm) 6.76 x 21.18 x 45.49 Unit Weight (lbs.) 37.26 Unit Weight (kg) 16.90 ENVIRONMENTAL Relative Humidity 0-95% non-condensing Operating Elevation (ft.) 10,000 ft. Storage Elevation (ft.) 10,000 ft. Operating Elevation (m) 3,000 m Storage Elevation (m) 3000 m STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 18-month limited warranty Product Warranty Period (International) 1-year limited warranty Product Warranty Period (Mexico) 1-year limited warranty Product Warranty Period (Puerto Rico) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
RBC72S 价格&库存
很抱歉,暂时无法提供与“RBC72S”相匹配的价格&库存,您可以联系我们找货
RBC72S
    库存:6
