S3M100K-100K4T
S3M100K-100K4T
    TRIPPLITE
    3-PHASE 208V UPS + INPUT ISOLATI
S3M100K-100K4T 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 3-Phase 208V UPS + Input Isolation Transformer Kit - 480V Delta to 208V Wye, 100kVA/kW, External Batteries Required Highlights ● Recommended for government, manufacturing, healthcare and corporate settings ● ENERGY STAR 2.0-certified UPS efficiency up to 98% helps reduce utility/cooling costs ● Unity output power factor (1.0) allows support of more equipment without overloading ● Optional WEBCARDLXMINI network card allows costeffective remote management 24/7 ● Rugged steel housings with compact footprint come ready for installation MODEL NUMBER: S3M100K-100K4T Applications ● Fit transformer, UPS and batteries in best-in-class footprint to save space for revenue-generating equipment ● Protect healthcare, manufacturing, corporate and other IT equipment where the upstream power source is 480V and the load requires a 208V 3phase UPS ● Maintain server-room operations during all power conditions, including short blackouts Combines an input transformer with a UPS to provide 480V to 208V step-down and isolation protection and clean, reliable backup power to support connected loads. Features 100kVA/kW 3-Phase UPS System and Input Isolation Transformer Combined into One Kit This SmartOnline® kit for 208V IT loads combines S3M100K 208/220/120/127V Double-Conversion UPS system and S3MT-100K480V Input Isolation Transformer into one convenient package. The input transformer connects to the UPS system’s input to provide 3-phase voltage step-down and isolation from 480V (Delta) to 208V (Wye). That clean, reliable 208V backup power passes through the UPS system to support your critical loads. The S3M100K-100K4T combo kit is ideally suited for vital applications in banking, education, healthcare, government and manufacturing sectors. Battery Backup and VFI Operation Protect Critical Loads The IGBT UPS supports the continuous availability of your most important operational and IT equipment loads through all power conditions, providing a compact backup power platform that’s easy to manage and inexpensive to operate. Sophisticated voltage- and frequency-independent (VFI) operation and advanced IGBT rectifier technology with DSP control deliver reliable output power quality. Complete Step-Down and Isolation Protection That Prevents Power Disruption The input transformer offers line isolation and protection to the UPS system and its load. It isolates the UPS and connected components from line surges and spikes caused by utility power disruptions that can damage equipment or corrupt data. Best-in-Class Footprint for Easy Integration into Your Network Application The compact design lets you install the steel housings in spaces that would otherwise have required expensive retrofitting. By achieving their condensed size without compromising runtime, reliability or functionality, this combination UPS/transformer kit is recommended for data centers, colocation facilities and edge computing environments that require high efficiency, high performance and clean, reliable power protection, while preserving as much space as possible for revenue-generating server racks. Efficient UPS Operation and Design Reduces Cost of Ownership The UPS features ENERGY STAR 2.0-certified technology that provides high operational efficiency to save on utility and cooling costs, as well as protect the environment. It achieves 94% efficiency in doubleconversion mode and up to 98% in ECO mode, reducing your power and cooling costs. Unity output power factor (1.0) lets you support more equipment. A low THDi (
S3M100K-100K4T 价格&库存
很抱歉,暂时无法提供与“S3M100K-100K4T”相匹配的价格&库存,您可以联系我们找货
