S3M10K-NIB
S3M10K-NIB
    TRIPPLITE
    3-PHASE 208/220/120/127V 10KVA/K
S3M10K-NIB 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 3-Phase 208/220/120/127V 10kVA/kW DoubleConversion UPS - Unity PF, No Internal Battery Modules Highlights ● Best-in-class footprint saves space in server room for revenue-generating equipment ● ENERGY STAR 2.0-certified efficiency up to 98% ECO, and up to 94% in online mode helps reduce utility and cooling costs ● Unity output power factor (1.0) allows support of more equipment without overloading ● Optional WEBCARDLXMINI network card allows costeffective remote management 24/7 ● Parallel capability provides increased capacity and redundancy up to 4 units MODEL NUMBER: S3M10K-NIB Applications ● Fit 10kVA/kW UPS in best-inclass footprint to save space for revenue-generating equipment ● Back up critical IT equipment and data in network, telecom, financial and light industrial applications ● Maintain server-room operations during all power conditions, including short blackouts On-line UPS supports the continuous availability of critical loads in a compact footprint without compromising runtime, reliability or functionality. Features Battery Backup and VFI Operation Protect Critical Loads The SmartOnline® S3M10K-NIB IGBT UPS supports the continuous availability of your most important operational and IT equipment loads through all power conditions, providing a compact backup power platform that’s easy to manage and inexpensive to operate. Sophisticated voltage- and frequencyindependent (VFI) operation and advanced IGBT rectifier technology with DSP control deliver reliable output power quality. Providing up to 10kVA/kW of clean, continuous power, this 3-phase UPS system is ideally suited for critical applications in banking, education, healthcare, government and manufacturing sectors. Best-in-Class Footprint for Easy Integration into Your Network Application The UPS market’s smallest footprint for 3-phase 208V systems lets you install the S3M10K-NIB in spaces that would otherwise have required expensive retrofitting. By achieving its compact size without compromising runtime, reliability or functionality, the S3M10K-NIB is recommended for data centers, colocation facilities and edge computing environments that require high efficiency, high performance and clean, reliable power protection, while preserving as much space as possible for revenue-generating server racks. Efficient Operation and Design Reduces Cost of Ownership ENERGY STAR 2.0-certified technology provides high operational efficiency to save on utility and cooling costs, as well as protect the environment. This UPS achieves up to 94% efficiency in double-conversion mode and up to 98% in ECO mode, reducing your power and cooling costs. Unity output power factor (1.0) lets you support more equipment. A low THDi (0.99 (maximum resistive load) THDi
S3M10K-NIB 价格&库存
很抱歉,暂时无法提供与“S3M10K-NIB”相匹配的价格&库存,您可以联系我们找货
