S3MT-20K480V
S3MT-20K480V
    TRIPPLITE
    SMARTONLINE S3MT-SERIES 3-PHASE
S3MT-20K480V 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline S3MT-Series 3-Phase 20kVA Input Isolation Transformer, Delta 480V to 208V Wye, TAA Highlights ● Recommended for government, manufacturing, healthcare and corporate settings ● Up to 96.5% efficiency with a quiet acoustic profile less than 65 dBA ● Resettable protection relay/switch and red LED indicator warn against overheating ● Rugged stainless steel housing with compact footprint comes ready for installation ● Compatible with 10–20kVA/kW Tripp Lite S3M-Series 3-phase UPS systems MODEL NUMBER: S3MT-20K480V Applications Protect healthcare, manufacturing, corporate and other IT equipment where the upstream power source is 480V and the load requires a 208V 3-phase UPS 20kVA/kW transformer provides 480V (Delta) to 208V (Wye) step-down and isolation protection to a 3phase UPS and its load. Package Includes ● S3MT-20K480V 3-Phase 20kVA Input Isolation Transformer ● Owner’s manual Features Get Complete Step-Down and Isolation Protection and Prevent Power Disruption Tripp Lite’s S3MT-20K480V 20kVA/kW transformer offers line isolation and protection to the connected 3phase UPS system and its load. It isolates the UPS and connected components from line surges and spikes caused by utility power disruptions that can damage equipment or corrupt data. The step-down input isolation transformer is ideal for 4-wire (3Ph+N+PE) IT loads in government, manufacturing, healthcare and corporate settings with a 480V electrical feed and 208/120V equipment. Performs with High Efficiency up to 96.5% Not only is the S3MT-20K480V very efficient, with up to 96.5 percent efficiency, but it is also very quiet with a noise profile less than 65 dBA. A built-in circuit breaker on the output side helps prevent dangerous power overloads. Two ball-bearing cooling fans help prevent overheating. An overheat-sensing relay and switch combine with a red LED indicator to provide over-temperature warning and overheating protection. Small Footprint for Quick Installation in a Compact Space The compact footprint enables installation of the S3MT-20K480V with minimal space. The rugged stainless steel housing ships ready for immediate installation with a compatible 10–20kVA/kW Tripp Lite S3M-Series 3-phase UPS system. Specifications OVERVIEW UPC Code 037332253132 Efficiency 95% @ full load 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Nominal Voltage / Frequency 480V 3-PH / 60Hz VA / Watt Capacity 20000 Transformer Type Dry type, Input step-down isolation transformer INPUT Input Phase 3-Phase Nominal Input Voltage(s) Supported 480V 3-PH Delta UPS Input Connection Type Hardwire OUTPUT Output Capacity (VA) 20000 Output Capacity (kVA) 20 Nominal Output Voltage(s) Supported 120/208V 3-PH Wye Output Receptacles Hardwire PHYSICAL Primary Form Factor Tower Cooling Method 2 x BALL BEARING, 120MM (288 TOTAL CFM) Form Factors Supported Tower Shipping Dimensions (hwd / in.) 54.80 x 22.20 x 37.80 Shipping Weight (kg) 219.99 Unit Dimensions (hwd / in.) 47.200 x 17.400 x 33.500 Unit Dimensions (hwd / cm) 120 x 44.2 x 85 Unit Weight (lbs.) 430 Unit Weight (kg) 195.04 ENVIRONMENTAL Online Mode Heat Dissipation (BTU/Hr) @ Full Load 3413 INPUT TRANSFORMER Input Voltage 480V 3-PH Delta Input Voltage Range (-45%, +25%) for 40% load (-20%, +25%) for 100% load Input Amp(s) 35 A AC Input Configuration Delta AC Input Frequency 50/60 Frequency Range 40/70Hz 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Voltage Selection NONE Input Inrush Current 300 A VA Rating 20K Input Number of Phases 3PH AC Output Voltage (V) 120/208V 3-PH Wye AC Output Amps 75 A Output Number of Phases 3PH + N AC Output Configuration WYE Output Isolation Yes Output Breaker Rating 80 A Connection Type TERMINAL BLOCK LED Warning Light Functions The over-temperature warning LED light will turn ON when the output/secondary of the Input transformer reaches 160°C ±5°C and will turn OFF wthen the corresponding transfomer cools down to 125°C ±5°C Over Temperature Reset If the secondary side of the input transformer reaches temperatures of or higher than 160°C ± 5°C, i.e. a range of 155°C to 165°C (311°F to 329°F), an over-temperature protection relay and thermal switch will activate and will open the breaker on secondary side of the transformer. Once the transformer temperature has cooled down to 125°C ± 5°C, i.e. a range of 120°C to 130°C ( 248°F to 266°F) the warning LED light will turn OFF, and you may manually reactivate (close) the output breaker on the transformer to restart normal operation. Efficiency @ Half Load 0.965 Efficiency @ Full Load 0.95 Heat Dissipation (BTU/Hr) @ Full Load 3413 Audible Noise (dBA @ 1m) 65dB max APPLICATIONS UPS Applications Mission Critical Applications OUTPUT TRANSFORMER Efficiency @ Half Load 0.965 Efficiency @ Full Load 0.95 STANDARDS & COMPLIANCE Product Compliance Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Product Warranty Period (U.S. & Canada) 2-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
S3MT-20K480V 价格&库存
很抱歉,暂时无法提供与“S3MT-20K480V”相匹配的价格&库存,您可以联系我们找货
