S3MT-60K600V
S3MT-60K600V
    TRIPPLITE
    SMARTONLINE S3MT-SERIES 3-PHASE
S3MT-60K600V 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline S3MT-Series 3-Phase 60kVA Input Isolation Transformer, 600V Delta to 208V Wye MODEL NUMBER: S3MT-60K600V Highlights ● Recommended for government, manufacturing, healthcare and corporate settings ● Up to 97.5% efficiency with a quiet acoustic profile less than 65 dBA ● Resettable protection relay/switch and red LED indicator warn against overheating ● Rugged stainless steel housing with compact footprint comes ready for installation ● Compatible with 50–60kVA/kW Tripp Lite S3M-Series 208V 3phase UPS systems Applications 60kVA/kW transformer provides 600V (Delta) to 208V (Wye) step-down and isolation protection to a 3phase UPS and its load. Protect healthcare, manufacturing, industrial, corporate and other IT equipment where the upstream power source is 600V and the load requires a 208V 3-phase UPS System Requirements Features Get Complete Step-Down/Step-Up and Isolation Protection Tripp Lite’s S3MT-60K600V 60kVA/kW transformer offers line isolation and protection to the connected 3phase UPS system and its load. It isolates the UPS and connected components from line surges and spikes caused by utility power disruptions that can damage equipment or corrupt data. The step-down input isolation transformer is ideal for 4-wire (3Ph+N+PE) IT loads in government, manufacturing, healthcare and corporate settings with a 600V electrical feed and 208/120V equipment. Performs with High Efficiency up to 97.5% Not only is the S3MT-60K600V very efficient, with up to 97.5 percent efficiency, but it is also very quiet with a noise profile less than 65 dBA. A built-in circuit breaker on the output side helps prevent dangerous power overloads. Four ball-bearing cooling fans help prevent overheating. An overheat-sensing relay and switch combine with a red LED indicator to provide over-temperature warning and overheating protection. Small Footprint for Quick Installation in a Compact Space The compact footprint enables installation of the S3MT-60K600V with minimal space. The rugged stainless steel housing ships ready for immediate tower installation with a compatible 50–60kVA/kW Tripp Lite S3M-Series 208V 3-phase UPS system. Specifications OVERVIEW UPC Code 037332253163 Efficiency 96.5% @ full load Nominal Voltage / Frequency 600V 3-PH / 60Hz VA / Watt Capacity 60000 1/3 50–60kVA/kW Tripp Lite S3MSeries 208V 3-phase UPS system Package Includes ● S3MT-60K600V 3-Phase 60kVA Input Isolation Transformer ● (4) Bottom skirts ● (24) Screws ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Transformer Type Dry type, Input step-down isolation transformer INPUT Input Phase 3-Phase Nominal Input Voltage(s) Supported 600V 3-PH Delta UPS Input Connection Type Hardwire OUTPUT Output Capacity (VA) 60000 Output Capacity (kVA) 60 Nominal Output Voltage(s) Supported 120/208V 3-PH Wye Output Receptacles Hardwire PHYSICAL Primary Form Factor Tower Cooling Method 4 x BALL BEARING, 120MM (576 TOTAL CFM) Form Factors Supported Tower Shipping Dimensions (hwd / in.) 55.10 x 27.60 x 37.80 Shipping Weight (kg) 407.78 Unit Dimensions (hwd / in.) 47.200 x 23.600 x 33.500 Unit Dimensions (hwd / cm) 120 x 60 x 85 Unit Weight (lbs.) 789 Unit Weight (kg) 357.88 ENVIRONMENTAL Online Mode Heat Dissipation (BTU/Hr) @ Full Load 7167 INPUT TRANSFORMER Input Voltage 600V 3-PH Delta Input Voltage Range (-45%, +25%) for 40% load (-20%, +25%) for 100% load Input Amp(s) 81 A AC Input Configuration Delta AC Input Frequency 50/60 Frequency Range 40/70Hz Voltage Selection NONE Input Inrush Current 710 A 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States VA Rating 60K Input Number of Phases 3PH AC Output Voltage (V) 120/208V 3-PH Wye AC Output Amps 225 A Output Number of Phases 3PH + N AC Output Configuration WYE Output Isolation Yes Output Breaker Rating 250 A Connection Type COPPER BAR LED Warning Light Functions The over-temperature warning LED light will turn ON when the output/secondary of the Input transformer reaches 160°C ±5°C and will turn OFF wthen the corresponding transfomer cools down to 125°C ±5°C Over Temperature Reset Efficiency @ Half Load 97.5% Efficiency @ Full Load 96.5% Heat Dissipation (BTU/Hr) @ Full Load 7167 Audible Noise (dBA @ 1m) 65dB max APPLICATIONS UPS Applications Mission Critical Applications OUTPUT TRANSFORMER Efficiency @ Half Load 97.5% Efficiency @ Full Load 96.5% WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Product Warranty Period (U.S. & Canada) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
S3MT-60K600V 价格&库存
很抱歉,暂时无法提供与“S3MT-60K600V”相匹配的价格&库存,您可以联系我们找货
