S3MT-30KWR480V
S3MT-30KWR480V
    TRIPPLITE
    SMARTONLINE S3MT-SERIES 3-PHASE
S3MT-30KWR480V 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline S3MT-Series 3-Phase 30kVA Input (480V to 208V)/Output (208V to 480V) Isolation Transformers MODEL NUMBER: S3MT-30KWR480V Highlights ● Dual 30kVA/kW 480V transformers for government, healthcare and corporate settings ● Up to 97.5% efficiency with a quiet acoustic profile less than 65 dBA ● Resettable protection relay/switch and red alarm indicators warn against overheating ● Rugged stainless steel housing with compact footprint comes ready for installation ● Compatible with select 20–30kVA/kW S3M-Series 208V 3-phase UPS systems Applications Enclosure with step-down and step-up transformers offers line isolation and protection to the connected 3phase UPS and its load. Protect equipment in government, healthcare, manufacturing, corporate and other settings that have 480V electrical mains and 480V IT loads System Requirements Features Get Complete Step-Down/Step-Up and Isolation Protection S3MT-30KWR480V includes two transformers in a single cabinet: a 480V (Delta) to 208V (Wye) input isolation step-down transformer and a 208V (Wye) to 480V (Wye) output auto step-up transformer. It isolates the UPS and connected components from line surges and spikes caused by utility power disruptions that can damage equipment or corrupt data. The dual transformers are ideal for 4-wire (3Ph+N+PE) loads in government, manufacturing, healthcare and corporate settings with 480V electrical mains and 480V IT loads. Performs with High Efficiency up to 97.5% Not only is the S3MT-30KWR480V wrap-around transformer very efficient, with up to 97.5 percent efficiency, but it is also very quiet with a noise profile less than 65 dBA. Built-in circuit breakers on both transformers help prevent dangerous power overloads. Four ball-bearing cooling fans help prevent overheating. An overheat-sensing relay and switch combine with red alarm indicators to provide overtemperature warning and overheating protection. Small Footprint for Quick Installation in a Compact Space The compact footprint enables installation of the S3MT-30KWR480V with minimal space. The rugged stainless steel housing ships ready for immediate tower installation with a compatible 20–30kVA/kW S3MSeries 3-phase UPS system. Specifications OVERVIEW UPC Code 037332253194 Efficiency 96.5% @ 100% load 1/4 ● 20–30kVA/kW S3M-Series 208V 3-phase UPS system ● Not compatible with SUT20K or SUT30K Package Includes ● S3MT-30KWR480V 3-Phase 30kVA Input/Output Isolation Transformers ● (4) Bottom skirts ● (24) Screws ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Nominal Voltage / Frequency Input transfomers (T-in) 480V / Output transformer (T-out) 208V, 3-PH / 60Hz VA / Watt Capacity 30000 Transformer Type Dry type, Input step-down isolation transformer and Output step-up Auto Transformer INPUT Input Phase 3-Phase Nominal Input Voltage(s) Supported 480V 3-PH Delta UPS Input Connection Type Hardwire OUTPUT Output Capacity (VA) 30000 Output Capacity (kVA) 30 Nominal Output Voltage(s) Supported 480V 3-PH Wye Output Receptacles Hardwire PHYSICAL Primary Form Factor Tower Cooling Method 4 x BALL BEARING, 120MM (576 TOTAL CFM) Form Factors Supported Tower Shipping Dimensions (hwd / in.) 70.90 x 27.60 x 37.80 Shipping Weight (kg) 479.90 Unit Dimensions (hwd / in.) 63.000 x 23.600 x 33.500 Unit Dimensions (hwd / cm) 160 x 60 x 85 Unit Weight (lbs.) 961 Unit Weight (kg) 435.90 ENVIRONMENTAL Online Mode Heat Dissipation (BTU/Hr) @ Full Load 9829 INPUT TRANSFORMER Input Voltage 480V 3-PH Delta Input Voltage Range (-45%, +25%) for 40% load (-20%, +25%) for 100% load Input Amp(s) 51 A AC Input Configuration Delta AC Input Frequency 50/60 Frequency Range 40/70Hz 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Voltage Selection NONE Input Inrush Current 450 A VA Rating 30K Input Number of Phases 3PH AC Output Voltage (V) 120/208V 3-PH Wye AC Output Amps 113 A Output Number of Phases 3PH + N AC Output Configuration WYE Output Isolation Yes Output Breaker Rating 125 A Connection Type COPPER BAR LED Warning Light Functions The over-temperature warning LED light will turn ON when the output/secondary of the Input transformer reaches 160°C ±5°C and will turn OFF wthen the corresponding transfomer cools down to 125°C ±5°C Over Temperature Reset The transformers include an over-temperature protection relay and thermal switch on the secondary sides of the input (T-in) transformer and on the primary side of the output (T-out) transformer to protect the transformer from overheating. Thermal switches on input and output transformers will open the corresponding transformer breaker if either of the transformer reaches 155°C/311°F to 165°C/329°F. Once the transformer cools down to 120°C/248°F to 130°C/266°F, the corresponding warning LED light will turn OFF, and the corresponding transformer breaker maybe closed to restart operation. Efficiency @ Half Load 97.50% Efficiency @ Full Load 0.952 Heat Dissipation (BTU/Hr) @ Full Load 9829 Audible Noise (dBA @ 1m) 65dB max APPLICATIONS UPS Applications Mission Critical Applications OUTPUT TRANSFORMER Input Voltage 120/208V 3-PH Wye Input Voltage Range (-45%,+25%)for 40 % load (-20%,+25%)for 100 % load Input Amp(s) 87 A AC Input Configuration WYE AC Input Frequency 50/60 HZ Frequency Range 40-70HZ Input Inrush Current 1010 A Input Number of Phases 3PH+N VA Rating 30K AC Output Voltage (V) 480V 3-PH Wye AC Output Amps 36 A 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Number of Phases 3PH+N AC Output Configuration WYE Output Isolation No Output Breaker Rating 125 A Connection Type COPPER BAR LED Warning Light Functions The over-temperature warning LED light will turn ON when the input/primary of the Output transformer reaches 160°C ±5°C and will turn OFF wthen the corresponding transfomer cools down to 125°C ±5°C Over Temperature Reset The transformers include an over-temperature protection relay and thermal switch on the secondary sides of the input (T-in) transformer and on the primary side of the output (T-out) transformer to protect the transformer from overheating. Thermal switches on input and output transformers will open the corresponding transformer breaker if either of the transformer reaches 155°C/311°F to 165°C/329°F. Once the transformer cools down to 120°C/248°F to 130°C/266°F, the corresponding warning LED light will turn OFF, and the corresponding transformer breaker maybe closed to restart operation. Efficiency @ Half Load 97.50% Efficiency @ Full Load 0.952 Heat Dissipation (BTU/Hr) @ Full Load 9829 Audible Noise (dBA @ 1m) 65dB max STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Product Warranty Period (U.S. & Canada) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
S3MT-30KWR480V 价格&库存
很抱歉,暂时无法提供与“S3MT-30KWR480V”相匹配的价格&库存,您可以联系我们找货
