SMART500RT1UN
SMART500RT1UN
    TRIPPLITE
    SMARTPRO 120V 500VA 300W LINE-IN
SMART500RT1UN 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 120V 500VA 300W Line-Interactive UPS, 1U, WEBCARDLX, USB, DB9, 6 Outlets Highlights ● Protects equipment against blackouts, brownouts, overvoltages, surges and line noise ● Keeps AC power running during blackouts to allow time for file saves and safe shutdown ● Maintains continuous 120V nominal output during brownouts and overvoltages ● Included WEBCARDLX network interface allows you 24/7 remote access from anywhere MODEL NUMBER: SMART500RT1UN Applications Rack-mount UPS offers complete power protection for small network applications, including telecom, security and digital signage. Features 500VA/300W/120V Battery Backup for PC Networks, Security Systems or Digital SignageThe SmartPro® line-interactive SMART500RT1UN UPS system with AVR provides reliable battery backup and AC power protection against blackouts, brownouts, overvoltages, surges and line noise that can damage valuable electronics or destroy data. The six-outlet 120V battery backup is ideal protection for rack-mount equipment in your server room or network closet. Allows Time to Back Up Critical Files During a Blackout Backup support allows you to work through short power failures and gives you enough time to safely save files and shut down your system in case of a prolonged blackout. Backup time varies according to load, but the line-interactive UPS system should keep a half load (150W) powered as long as 14 minutes and a full load (300W) up to three minutes. Included WEBCARDLX Network Interface Offers 24/7 AccessThe Java-free HTML5-based WEBCARDLX interface enables full remote access for site power and UPS status monitoring, configuration, control and email notifications via secure web browser, SNMP, telnet or SSH. It supports 10/100 Mbps auto-sensing for optimal communication with an Ethernet network. Optional EnviroSense2 modules (sold separately) provide a variety of environmental monitoring capabilities, including temperature and humidity conditions. Protocols supported include IPv4, IPv6, HTTP, HTTPS, SMTP, SNMPv1, SNMPv2, SNMPv3, telnet, SSH, FTP, DHCP and NTP. NEMA Outlets Protect Your Connected ComponentsSix 5-15R outlets provide battery backup, 567 joules of surge protection and voltage regulation for your crucial components. Five are UPS-supported, and one is surge-only to connect peripherals not requiring battery backup. One UPS-supported outlet is switchable, allowing you to power its connected device on and off remotely to reset or reboot it or to shed a less significant load to extend battery runtime for more critical equipment. Automatic Voltage Regulation (AVR) Corrects Low- and High-Voltage ConditionsAVR protects your equipment from incremental hardware damage, data loss and performance problems caused by brownouts and overvoltages. The SMART500RT1UN maintains regulated 120V nominal output during brownouts as low as 90V, while keeping the battery fully charged and ready to take over in case of power failure. The internal batteries are field-replaceable and hot-swappable. Premium Protection from EMI/RFI Line Noise Helps Your Equipment Perform BetterThis UPS 1/6 ● Deliver battery-derived AC output to connected equipment in a network closet or smallbusiness network ● Protect point-of-sale and VoIP networks against power surges and spikes ● Operate essential equipment during short-term power outages using battery backup power ● Shut down desktop PCs and other equipment without data loss during long-term power outages Package Includes ● SMART500RT1UN 120V 500VA 300W Line-Interactive UPS with 6 Outlets ● WEBCARDLX network management card ● Micro USB to USB-A ● USB cable ● DB9 cable ● EPO cable ● Rack-mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States system filters out disruptive electromagnetic and radio frequency interference that can inflict hardware damage or data loss. This EMI/RFI filtering also helps your connected components perform better and last longer. Designed for High Efficiency to Help You Save Money and Protect the EnvironmentA 96% efficiency rating reduces BTU emissions, energy consumption and, ultimately, your energy costs. LED Indicators and Audible Alarms Keep You InformedFive front-panel LEDs keep you apprised of line power, battery power, overload, voltage regulation and battery low/replace status at a glance. A multifunction alarm sounds to warn you of power failure, overload and low-battery conditions. Advanced Communications Ports Allow for Automatic Saves and ShutdownsRS-232 and HIDcompliant USB ports connect to a computer running free downloadable PowerAlert® software to enable safe unattended file saves and system shutdown in case of a prolonged power failure. The EPO port supports emergency shutdown in large facilities. Cables are included. Versatile Installation OptionsHardware is included for mounting the UPS in 1U of space in an EIAstandard 19-inch 2-port or 4-post rack or in an upright tower position. The 10-foot (3.1-meter) power cord with NEMA 5-15P plug connects to any compatible AC outlet. Specifications OVERVIEW UPC Code 037332224170 UPS Type Line-Interactive INPUT Input Phase Single-Phase Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 10A UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 500 Output Capacity (kVA) 0.5 Output Capacity (Watts) 300 Output Capacity (kW) 0.3 Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -14%, +16% 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Voltage Regulation (Battery Mode) +/- 5% UPS Output Receptacles (Surge Suppression Only) 5 UPS outlets, 1 surge-only outlet Load Management Receptacles One switchable single-outlet 5-15R load bank Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 120V Output Receptacles (6) 5-15R Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 3 min. (300W) Runtime Half Load (min.) 14 min. (150W) Expandable Runtime No DC System Voltage (VDC) 12 Battery Recharge Rate (Included Batteries) Less than 12 hours to 90% Battery Access Battery access door Internal UPS Replacement Battery Cartridge IMPORTANT BATTERY REPLACEMENT INFORMATION > Use Tripp Lite RBC12V-1U replacement battery for  SMART500RT1U  models with Series Number AG-03AA listed on the UPS nameplate (sold starting in 2021); For all prior versions of  SMART500RT1U , use Tripp Lite  RBC62-1U  replacement battery; Contact Tripp Lite customer service for additional information Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with input voltage as low as 90 Undervoltage Correction Input voltages between 90 and 105 are boosted by 14% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch Audible Alarm Audible alarm indicates power-failure, overload and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States EMI / RFI AC Noise Suppression Yes AC Suppression Joule Rating 567 AC Suppression Response Time Instantaneous PHYSICAL Primary Form Factor Rackmount; Tower Rack Height 1U Included Mounting Accessory Description Included mounting brackets provide front-rail installation in 2 or 4 post racks, plus upright tower configurations Installation Form Factors Supported with Included Accessories 2 post 19 inch rackmount; 2 post front mount; 4 post 19 inch rackmount; Tower Minimum Required Rack Depth (cm) 38.10 Minimum Required Rack Depth (inches) 15 Primary UPS Depth (mm) 286 Primary UPS Height (mm) 44 Primary UPS Width (mm) 440 Shipping Dimensions (hwd / in.) 15.40 x 4.80 x 22.10 Shipping Weight (kg) 9.48 UPS Housing Material Steel UPS Power Module Dimensions (hwd, in.) 1.73 x 17.32 x 11.26 UPS Power Module Weight (kg) 7.18 UPS Power Module Weight (lbs.) 15.84 Unit Weight (lbs.) 17.600 Unit Weight (kg) 7.98 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 48 AC Mode Efficiency Rating (100% Load) 97% Battery Mode Heat Dissipation (BTU/Hr) @ Full Load 360 Audible Noise 45 dBA maximum, front side 1m COMMUNICATIONS 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Network Management Cards  WEBCARDLXE  Network Monitoring Port Description Pre-installed WEBCARDLX provides remote monitoring and control via HTML5 web interface, telnet, SSH and SNMP management systems PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network UPS Tools (NUT) Compatibility NUT compatible. See a full list of NUT compatible Tripp Lite UPS systems at https://networkupstools.org/stablehcl.html?manufacturer=Tripp%20Lite Network Management Card Description Network management card included Communications Interface DB9 Serial; EPO (emergency power off); Pre-installed network card; Slot for SNMP/Web interface; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time 4 milliseconds (AC to battery); 7 milliseconds (Battery to AC) Low Voltage Transfer to Battery Power (Setpoint) 90 High Voltage Transfer to Battery Power (Setpoint) 139 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring and Reboot (included); Automatic Voltage Regulation (AVR); Hot swappable batteries; Remote management; Surge/noise protection Grounding Details Back panel grounding lug APPLICATIONS UPS Applications High-End Desktop/Small Network; Retail/Point of Sale; Hospitality STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class B (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year warranty, 3 year with registration. Note: Registration is required for 3-year warranty. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
SMART500RT1UN
物料型号为LM5110,它是一款由德州仪器生产的同步升压/降压/反相开关稳压器。
器件简介指出LM5110集成了功率开关、同步整流器、电流检测放大器、振荡器、具有可编程软启动和截止功能的PWM控制器、以及一个低压降稳压器。
引脚分配方面,LM5110包含1个误差放大器引脚、1个反馈引脚、1个使能引脚、1个定时引脚等。
参数特性包括输入电压范围为4.5V至60V,输出电压范围为0.8V至60V,最大输出电流为3A。
功能详解中提到LM5110具有优异的线路和负载瞬态响应,低静态电流,以及低噪声输出。
应用信息显示LM5110可用于便携式电池供电设备、工业电源、汽车电源和电信电源等。
封装信息表明LM5110有多种封装形式,如TSSOP-28、QFN-28等。
SMART500RT1UN 价格&库存
很抱歉,暂时无法提供与“SMART500RT1UN”相匹配的价格&库存,您可以联系我们找货
SMART500RT1UN
库存:1
SMART500RT1UN
    库存:6
